2010 taco cold weather issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo freak, Feb 10, 2011.
  1. Feb 10, 2011 at 6:16 PM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    So here is the deal. I have noticed this problem when starting in cold weather (At or below 32 degrees). When I first start the truck it idles way down really rough and threatens to cut out. This last about 3-5 seconds and returns to normal. Is this ok for a new fuel injected engine? To me it starts like my old caborated jeep. Should I check this out or leave it alone? And yes I checked for water in fuel and refilled so that's not the issue. Thanks
  2. Feb 10, 2011 at 6:47 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
  3. Feb 10, 2011 at 6:50 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    how far down does it throttle down?????
  4. Feb 10, 2011 at 6:54 PM
    andrew862
    andrew862 Well-Known Member
    Andrew
    Fayetteville, NY
    DCLB 4x4 Limited
    Downey SST Tonneau, DeeZee Bed Mat, TRD Exhaust, ScangaugeII
    My truck does just the opposite, as do most newer engines. On a cold start the engine runs higher RPMS than idle until it warms up or is put in gear. If your engine stumbles or misses and does not rev up after a cold start there may be something wrong. Have you checked the plugs? On a really cold morning mine takes a few extra cranks to start but runs strong once started.
  5. Feb 10, 2011 at 7:05 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Yes it idles low and rough than jumps up high which I know is normal, just when it first turns over thats the issue
  6. Feb 10, 2011 at 7:06 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Get checked something is out of spec.
  7. Feb 10, 2011 at 7:41 PM
    mattygabe
    mattygabe Well-Known Member
    Western PA
    2011 Access Cab SR5
    Access Limited Soft Rollup Tonneau Cover
    Sounds like something is amiss, something with the fuel system... Most newer engines are able to account for the colder temperatures, and with you being in Mobile, you can't possibly be in such cold weather that it's making it do that.
  8. Feb 10, 2011 at 7:56 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    ^^yea and it's only when it's really cold which is 32 around here lol
  9. Feb 10, 2011 at 9:28 PM
    TWLTRD11
    TWLTRD11 Well-Known Member
    Baltimore, MD
    '11 Double Cab TRD Sport
    Mine does the exact same thing. No worries about running high/low rpms much. Just usually takes more than one try. I was wondering about this since it only has 1000 miles on it so far.
  10. Feb 10, 2011 at 9:35 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    You give it a little gas?
  11. Feb 11, 2011 at 1:20 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    its go a bad maf or something. I don't know how toyota enriches the mix, but it does, yours isn't.. or it is, without some other sensor/switch working properly. Mine was doing the opposite new, disconnected the battery and reconnected it before bothering to bring it to the dealer and it fixed it.
    Pull your codes? take it to the dealer if warranted, or find someone that's efi smart. There don't seem to be many problems with the engine on these trucks, I never see anyone talking about it to refer you to.
    Most people won't have a clue.
  12. Feb 11, 2011 at 4:39 AM
    mattygabe
    Western PA
    2011 Access Cab SR5
    I recently learned that cars sometimes do have codes in them, but may not show the check engine light because the codes haven't "matured", i.e. the problem has to occur multiple times in a certain time span before the computer realizes something has failed. So you may have a developing problem with the MAF that just hasn't "matured" yet, perhaps.
  13. Feb 11, 2011 at 4:59 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    It was about 3degree's F this morning when I started mine and all I noticed was a slightly harder crank. You should take to dealer. They will prob want to hold it overnight so they can start it in the morning.
  14. Feb 11, 2011 at 5:15 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Alright thanks for the answers! Might be a sensor sounds like the idle is having trouble compensating at first but then catches up. Keep going !
  15. Feb 11, 2011 at 5:16 AM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    32 is a freaking heat wave from where I come from. -6 this morning and she started without a hitch and rpms never fluctuated. Something is not right with your truck.
  16. Feb 11, 2011 at 5:22 AM
    brow
    brow Well-Known Member
    Andy
    Minnesota
    17' MGM DCLB SR5 4x4
    -25 here yesterday morning and she cranked over pretty good, running the normal high rpm's for a few minutes. I would get it checked out, low rpm's shouldn't be happening at first start
  17. Feb 11, 2011 at 8:39 AM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I haven't noticed any problems with mine this winter. We have had some days down into the low 20's so far.
