2010 taco issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woodygg, Apr 8, 2010.
  1. Apr 8, 2010 at 7:32 AM
    woodygg
    woodygg [OP] Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    Question...
    I'm planning on purchasing a DC 4X4 automatic this year...
    I may wait to get a 2011 model (am going to try and find out from a friend of a friend who's a VP at toyota when they're coming out and if there's any changes - I know a lot of people here would like to know)...
    however, my questions is, what common issues/problems are there on the current models (if any)? i mean issues that seem to pop up too often, not a one off issue... (I know they're reliable, etc. that's why I'm planning on buying one - I'm only asking about known issues, IF ANY).
    I see the tsb (sp?) issue mentioned - I'm not quite sure what that is, but I assume the new models have that already fixed?
    Ect...
    Thanks in advance!
  2. Apr 8, 2010 at 8:01 AM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    The later model years, such as the 2010 usually have the kinks worked out. They are machines and failure is always a possiblity. The first model years are always a gamble because the designs are new.
  3. Apr 8, 2010 at 8:09 AM
    Wolfman
    Wolfman Well-Known Member
    Paradise, TX
    2010 PreRunner SR5
    I would be aware of the radio. They have a high failure rate, and Toyota has not yet found a new supplier. As for frame rust that has plagued the first gen Tacomas, only time will tell if 2nd gen models are going to be afflicted, as it took a long time for that defect to appear.
    I like mine so far. I simply would have liked for mine to not have been a "forced" purchase.
  4. Apr 8, 2010 at 8:15 AM
    woodygg
    So Cal
    04 DC Tacoma 4x4
    the radio, huh? well at least that's easy to replace... under warranty or an aftermarket.
    i listened to their 'high end' radio... not impressed whatsoever. in fact, i was bummed it sounded so bad as you pay quite a bit for it.
  5. Apr 8, 2010 at 8:22 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    just make sure you get the rear spring tsb before you sign anything
  6. Apr 8, 2010 at 8:31 AM
    10silvertaco
    10silvertaco Well-Known Member
    Brent
    no longer own Tacoma, now own 2011 Outback
    I brought my truck last August and had no problem ever since. I know there will be some minor problem in the future. Nothing new with every brand of vehicle, nothing perfect.
  7. Apr 8, 2010 at 8:39 AM
    JESSMAN
    JESSMAN Well-Known Member
    Jesse
    Reno Nv
    08 tacoma
    ARB BUMPER WARN M 8000 LIGHT FORCE LIGHTS Bill 5100 DOWNY FRONT LIFT RANCHO OLD MAN E REAR and JERRY CAN IN THE BED
    I got my Tacoma in 02/08 4x4 DC and it's great!!:D Everything works great!
  8. Apr 8, 2010 at 9:16 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    yea most problems are worked out, but the dealer said I still have to get my gas pedal modified, rear tsb, and my mats fixed:(
  9. Apr 8, 2010 at 10:26 AM
    DontPanic
    DontPanic Well-Known Member
    VA
    2010 tacoma (automatic I assume):
    Rear springs too soft for any towing or hauling. - TSB
    Incorrect 2-1 downshift map. -TSB
    Steering linkage play. -no official fix
    Front brake-pad rattle. -no official fix (reinstall with disc quiet)
    Soft/Spongy brakes - no official fix ("normal" per toyota), various remedies proposed by board members.
    Noisy idle from engine - "normal"
    Some 2010s have front driveshaft recall.
    Most of the longer wheelbase Tacos exhibit driveline shudder on takeoff.
    Audio failures as per above.
    The manual transmissions have a pesky TO bearing issue.
    Others can pick up and complete the list.
    Overall good trucks for sure but certainly not the paragons of quality they are held up as. There is no way I'd let a gum snapper with a sawsall cut my pedal - that is not a fix in my eyes. If you run weathertechs it is a non-issue.
