2010 Tacoma dash noise/rattle
Discussion in 'New Members' started by ofaulkner, Jan 7, 2013.
  1. Jan 7, 2013 at 6:59 PM
    ofaulkner
    ofaulkner [OP] New Member
    Dash Rattle
    Anyone have this problem? Dealer can not reproduce noise-they say they fixed it by removing the radio and "insulating". No help!!
  2. Jan 7, 2013 at 7:09 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Lay your hand on your driver side fender and see if it will move (just slightly) forward and back. In my case the fender was loose! A little tighten of the bolts and the bang went away. Good luck and welcome!
  3. Jan 7, 2013 at 7:14 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The hamster that powers your truck could have died on the job.
    On serious note, which side is the rattle coming from? There is a known issue with a wiring harness rattling against the dash plastic behind the glove box.
  4. Jan 8, 2013 at 8:02 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    If your truck was purchased used, maybe something that the previous owner did is loose? If all the lower panels, glove box (center counsel) were removed you could get someone to drive the truck while you put your hands on everything you can until you find the rattle. Just a thought.
