2010 Tacoma DC 4x4 TRD OR
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NickCat11, Mar 22, 2010.
  1. Mar 22, 2010 at 5:54 PM
    NickCat11
    NickCat11 [OP] Member
    Hello Everyone,
    I know this has been beaten to death but I'm just looking for some opinions. I am getting a new Tacoma (specs in title) on Saturday. The dealership I went to didn't have the color so they are getting it in Saturday. Before I purchase the truck (sign the final papers) should I ask them to do the transmission flash and the harsh ride upgrade before finalizing? What do you think? Thanks in advance.
  2. Mar 22, 2010 at 6:00 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    Just make sure that the TSB has been done. Do a search and read up on it before you go in and look over the truck. If all looks good.... Go and enjoy your new Taco..
    And welcome to TW.
    :wave:
  3. Mar 22, 2010 at 6:03 PM
    harvick29
    harvick29 Well-Known Member
    ask and demand, hit another dealer and see if they would do it for you, i ended up getting a it done, along with a bunch of freebies, by going toyota agait toyota, your spending the money, and they want your buisness, metion you looked at other makes, and the issues that toyota is having. i used all of it to get a the truck i wanted. aks about the accessories. ask about tailgate lock, ect, see what you can get for free, good luck
  4. Mar 22, 2010 at 6:06 PM
    NickCat11
    I'm assuming you mean both TSB's, correct?
  5. Mar 22, 2010 at 6:10 PM
    Blackshirts
    TX
    09 PreRunner
    Stuff
    If I am wrong someone correct me. The driveshaft is what you are talking about for the 4X4s right. I am not sure but that might be a recall and im sure they would of fixed that before the sell of the Taco. Second the TSB is for the 2010 is for the leaf springs. And I am sure they have fixed that too. But I would make sure.
  6. Mar 22, 2010 at 6:17 PM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Outside of using it as a negotiation tool during the purchase, a dealer will not perform a TSB problem unless the customer complains of the specific problem covered by said TSB.
  7. Mar 22, 2010 at 6:24 PM
    NickCat11
    So what do you think I should do? Is there a possibility that both things have been done or since it's a new truck most likely not?
  8. Mar 22, 2010 at 6:34 PM
    trd09
    trd09 Well-Known Member
    Chuck
    MA
    09 TRD Sport AC 4x4
    4-leaf TSB, 5100s @ 1.75, Flowmaster 40, Undercover Tonneau, K&N drop-in, Nittos, NGK Iridiums, OME N182s
    Make it a term of the sale.
    The rear leaf tsb should be easy because just say you haul heavy loads frequently and you need the part.
    The tranny tsb takes less than an hour so worst comes to worst get it done down the road if they resist (and it's not horrible before the upgrade either).
    Get the truck and enjoy it!
  9. Mar 22, 2010 at 6:46 PM
    Swell Taco
    Swell Taco New Member
    NH
    2010 TRD Off Road
    Tube Steps Front Skid Plate
    I'm in the same boat. Picking up my new AC TRD OR this Sat. Read all the other threads regarding the tran & spring TSB's; they are very good. I'm going to drive it for a bit and determine if those items need to be addressed. Not all new tacos are lemons....good luck!
