2010 Tacoma Tire Chains
Discussion in 'Off-Roading & Trails' started by RCASHDOLLAR, Sep 22, 2011.
  1. Sep 22, 2011 at 7:13 AM
    RCASHDOLLAR
    RCASHDOLLAR [OP] New Member
    Colorado
    TRD Tacoma
    I use my truck to go elk hunting here in Colorado and can't get chains on the front tires. If you've ever been in mud and snow and only have chains on the rear you're in for a tough time. Any suggestions?
  2. Sep 22, 2011 at 7:22 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Welcome to TW!
    I've always heard that it's not recommended to have chains on the front tires.
    Fink
  3. Sep 22, 2011 at 7:22 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    The manual says to only put them on the rear, and in my 13 years in the military, I've never seen chains on the front, or would have needed them.
    Frank
  4. Sep 22, 2011 at 7:43 AM
    RCASHDOLLAR
    Colorado
    TRD Tacoma
    Yes the manual does say that. Here in Colorado tire chains on all 4 tires are a must in the high country when there is mud and snow. If you are only going to chain up 2 tires the front is where you want them. I had them on the rear last year and was on fairly level ground and had to get over to make room for another truck and slid into a slight ditch and needed them to pull me out.
  5. Sep 22, 2011 at 7:47 AM
    Fink
    Orlando, FL
    In that case, is it simply a clearance issue when the chains are on (rubbing the front valence, rear fender liner, etc.)?
    Fink
  6. Sep 22, 2011 at 8:26 AM
    RCASHDOLLAR
    Colorado
    TRD Tacoma
    There is a suspension support that is about a 1/2" away from the tire and this prevents the use of chains. I love my truck but this is really a big deal when you're miles from pavement and a foot of snow or more hits. Trust me- you can have chains on the rear and really aggressive tires and have problems. I use to have a Nissan and with chains on all 4 tires it was nearly unstoppable.
  7. Sep 22, 2011 at 8:30 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    How about wheel spacers to give you enough clearance for the use of chains on the front? Or aftermarket wheels with different backspacing?
  8. Sep 22, 2011 at 8:39 AM
    Fink
    Orlando, FL
    Bingo.
    I would just go with wheel spacers - go with the smallest spacer possible to get you the clearance you need.
    Fink
  9. Sep 22, 2011 at 1:25 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    You'll either have to run spacers in the front or get different wheels with a lower offset. Your other option is 35"+ tires and air them down to 2psi. You won't need chains unless it's ice you're driving through.
  10. Sep 22, 2011 at 3:17 PM
    MountainDog
    MountainDog Well-Known Member
    Aurora, CO
    2012 4x4 Double Cab Off Road
    Vinyl floor; 265/75/16 Duratracs; SnugTop Rebel
    On my '94 with 31's there isn't clearance for chains in the front either. I've always just chained the rear since I didn't want to put spacers on just to use chains a few times a year. I haven't done it, but I've thought about finding some lower profile cable chains to put on the front. Not as good, but probably better than nothing.
  11. Sep 22, 2011 at 6:42 PM
    RCASHDOLLAR
    Colorado
    TRD Tacoma
    I'll look into the spacers. Thanks guys.
