2010 Tacoma TSB/ Needle Bearing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blackpig1957, Aug 9, 2010.
  1. Aug 9, 2010 at 5:26 PM
    blackpig1957
    blackpig1957 [OP] New Member
    I have a 2010 Tacoma with a funky noise at idle when pushing the clutch in. I've been told there is a TSB that addresses this issue and that it has to do with the needle bearing in the transfer case. Would anyone happen to have a copy of it?
  2. Aug 9, 2010 at 5:46 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Sorry man, but I don't think the transfer case has anything to do with you getting noise when you push in the clutch. Check the linkage joints and lube them try that first.
  3. Aug 9, 2010 at 7:37 PM
    lIlOtAcO
    lIlOtAcO Well-Known Member
    Chad
    Jax, FL.
    2010 S/C PreRunner SR5
    Brand FlippiN New
    does it do it at just idle once the clutch is pushed in the noise goes away? And just when the a/c compressor is cycling on and off?
  4. Aug 9, 2010 at 8:11 PM
    Gyprat
    Gyprat Active Member
    2010 4 cyl, SR5, Manual
    Don't mean to hijack this thread. Mine does that. Kinda sounds like a diesel engine when AC compressor kicks in. The noise goes away once the clutch is pushed in.
    Any idea what makes this noise? It's been doing this since day one.
  5. Aug 10, 2010 at 11:24 AM
    2.7taco
    Texas
    Its just the engine lugging down. Nothing to worry about, mine does it too.
