2010 Turbo Tacoma
Discussion in '2nd Gen. Builds (2005-2015)' started by toon714, Jan 13, 2012.
  1. Dec 16, 2012 at 3:04 PM
    #281
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I would have killed for those on the track yesterday. Looks good bro!
  2. Dec 16, 2012 at 3:48 PM
    #282
    toon714
    toon714 [OP] Well-Known Member
    toon
    So. Cali to H-town
    2010 turbo lowered prerunner
    garret Gt 35R front mount turbo, TR lowering kit, Work wheels, all the go fast goodies!
    Yes sirvthey do look good and feel great!
    Ill have my airbags again. Once ibfind a set of 09+ trd seats.
    Just need the sensor inside the seat.
    Ya I gave krish a lil ride along. Cpuldnt do.much. kuz it was too.wet outside.
    Once I hit boost the truck where break loose and I have to let off.
    But I think krish got a lil feel of wat the truck can do. Haha
  3. Dec 16, 2012 at 3:51 PM
    #283
    toon714
    toon
    So. Cali to H-town
    thx bro.
    I know youll love these seats since u went to the track.
    It holda u in place!
  4. Dec 16, 2012 at 4:15 PM
    #284
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    Dude that is sweet. I don't have a taco yet..... Hopefully get financed for one. I'm lookin at an 01 trd. However I was thinking how cool it would be to put the stock Garrett t-25 back in my car and take the Mitsubishi TD-04/15g to put in the truck if I get it haha probly won't though. I'll miss my turbo though.... Btw I'm surprised your running that little psi. I guess the motor wasn't designed for it. But the t25 in my car stock runs 13 psi. Tuned its 19. The td04 I'm running 25-29psi... On a 2.0 motor, my buddy has a 2.8?l v6 car with the td04 and he runs about 13psi I think. Good luck though that's freaking awsome.
  5. Dec 16, 2012 at 5:08 PM
    #285
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yeah. These engines don't like high boost numbers like those you mentioned, without internals. Rods and ring lands just aren't strong enough from the factory. But even at 8.7 psi from the GT35R, it is still making right near 400 whp and plenty more torque. Some internals and beefed up transmission, and I have a feeling that 600 from his setup will be super easy to attain.
    Now....if only he does it. No pressure. ;)
  6. Dec 18, 2012 at 9:00 AM
    #286
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    so all you need to do is transfer over the bag sensors? no lights on the dash?
  7. Dec 18, 2012 at 9:05 AM
    #287
    Findus11
    Findus11 Well-Known Member
    Durango
    07 Taco
    dude. SICK TRUCK! This has probably already been asked before but at what rpm do you hit full boost? How's the lag?
  8. Dec 18, 2012 at 11:46 AM
    #288
    toon714
    toon
    So. Cali to H-town
    Yes. u nees to take out the butt sebsor inside the seat. Amd diconnect the harness from the oem seats. 05-08 seats are done way ezer than the 09+ seats.
    Kuz the butt sensor is right under the oem seat. But the 09+ sensor is deep inside the cushion. So the only to get tk that sensor is to cut into the oem seats and take out the sensor to make the airbags work.
    My airbags are off at the moment. Im on a look out for a set of 09+ seats so I can take out the sensor.
  9. Dec 18, 2012 at 11:46 AM
    #289
    toon714
    toon
    So. Cali to H-town
    I hit full boost at 2900rpm. I have 0 lag with my setup. :)
  10. Dec 18, 2012 at 11:47 AM
    #290
    toon714
    toon
    So. Cali to H-town
    U know thats my goal bro! 600+rwhp double cab daily driver is wat im aiming for.
    Just a lil more cash to.save up. Shoukd be ordering internals. :)
  11. Dec 18, 2012 at 1:24 PM
    #291
    Findus11
    Durango
    07 Taco
    boss.
  12. Dec 18, 2012 at 8:12 PM
    #292
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Don't like how it works?
  13. Dec 18, 2012 at 8:27 PM
    #293
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You're right. Won't load when I click the link either. Maybe something is wrong with their server?
  14. Dec 18, 2012 at 8:41 PM
    #294
    DOUBLEJTACOMA
    DOUBLEJTACOMA Active Member
    Jeremy
    Jasper, Alberta
    Blacked out SR5
    -Black Halo Projector Headlights with HIDs -Black Billet Grille -Night Shaded Tail Lights -Exhaust (Magnaflow) -URD 2.7L Supercharger (soon, may need help)
    What do you do for work Toon? If you don't mind me asking...
  15. Dec 18, 2012 at 8:46 PM
    #295
    toon714
    toon
    So. Cali to H-town
    Im a pimp. I pimp hoes for my mod money for my truck. :)
    Lol jk. Im a contractor/landscaping. Own my own business.
  16. Dec 18, 2012 at 8:47 PM
    #296
    toon714
    toon
    So. Cali to H-town
    Its working now...
    Also ur gonna lower ur truck!?
    DO IT! Get rid of ur lift and get go fast parts. :p
  17. Dec 18, 2012 at 11:38 PM
    #297
    rcfreak201
    rcfreak201 Well-Known Member
    This truck is nuts...that is all. lol
    Seats look good bro nice meeting you!
  18. Dec 19, 2012 at 4:13 AM
    #298
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Bolo the pimp. Ha
  19. Dec 19, 2012 at 8:37 AM
    #299
    Lucario Runner
    Robert
    06 Toyota 4Runner
    lololol
  20. Dec 19, 2012 at 10:41 AM
    #300
    toon714
    toon
    So. Cali to H-town
    shit I will never to be like bolo the pimp. Lol
    Hes too.swool. And ill never get that swool to be pimpin like that.
