2010 Turbo Tacoma
Discussion in '2nd Gen. Builds (2005-2015)' started by toon714, Jan 13, 2012.
  1. Sep 5, 2012 at 5:26 PM
    #161
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  2. Sep 5, 2012 at 5:44 PM
    #162
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    :yay: Can you lock them up and put the power to the ground, or do you roast every gear?
  3. Sep 5, 2012 at 6:11 PM
    #163
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    subed!! i wanna see how insane your truck gets
  4. Sep 6, 2012 at 11:54 AM
    #164
    toon714
    toon714 [OP] Well-Known Member
    toon
    So. Cali to H-town
    2010 turbo lowered prerunner
    garret Gt 35R front mount turbo, TR lowering kit, Work wheels, all the go fast goodies!
    Thank you kindly sir! :)
  5. Sep 6, 2012 at 11:57 AM
    #165
    toon714
    toon
    So. Cali to H-town
    I cant grab any traction. With the current street tires I have nitto invo.
    Gonna be getting a set of nitto nt05r will be alot better. Sticker tires.
    No traction 1st and 2nd gear. Lol
    I also got a set of m/t slicks thats for the track. :)
  6. Sep 6, 2012 at 1:00 PM
    #166
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    so whens this track day coming? Interested to see 1/4 mile times and 0-60 times with the slicks
  7. Sep 7, 2012 at 8:08 AM
    #167
    toon714
    toon
    So. Cali to H-town
    if i have time i will go today.
    but the weather is hot as hell even at nite in houston.
    seeing low 100s to high 90s intake temps.
    wouldnt be nice condition in this hot ass weather.
  8. Sep 7, 2012 at 8:09 AM
    #168
    toon714
    toon
    So. Cali to H-town
    prolly baytown.
    sealy track sux. the prep on the track sux and its scary there.
    many wrecks happens in sealy.
  9. Sep 7, 2012 at 9:26 AM
    #169
    Large
    Large Red
    Beautiful.
  10. Sep 7, 2012 at 9:26 AM
    #170
    Large
    Large Red
    Question, does the intercooler interfere with the radiator cooling the engine ?
  11. Sep 7, 2012 at 9:30 AM
    #171
    Aw9d
    Aw9d That one guy
  12. Sep 7, 2012 at 10:15 AM
    #172
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    On the pulls I have done with him, making some 40-90 acceleration vids, His water temps stayed right at 186*. That was after 4 or so pulls.
    I would say it doesn't restrict it to badly. ;)
  13. Sep 7, 2012 at 10:27 AM
    #173
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you go tonight, I which I hope you do, I will have to join.
    I will guess high 12's if you can get your take-off down right. 13.3-13.5 if not spot on. Heck, i got 13.5 with no traction on those INVO's and a bad transmission. So you better get at least 13.5 bro. :p
  14. Sep 7, 2012 at 10:49 AM
    #174
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Hope he takes it easy on the launches.
  15. Sep 7, 2012 at 11:15 AM
    #175
    toon714
    toon
    So. Cali to H-town
    thank you sir.
    nope the intercooler doesnt interfere with the radiator.
    im still using my stock thermostat. i see about 186-188 temps.
    should be doing a torspd cooler thermostat mod upgrade soon. :)
  16. Sep 7, 2012 at 11:15 AM
    #176
    toon714
    toon
    So. Cali to H-town
    ahha thank you sir. :)
  17. Sep 7, 2012 at 11:17 AM
    #177
    toon714
    toon
    So. Cali to H-town
    im debating bro....
    scared that my stock valve body gonna give out on me.
    too much power!! :eek:
  18. Sep 7, 2012 at 11:17 AM
    #178
    toon714
    toon
    So. Cali to H-town
    i agree with u sir.
  19. Sep 7, 2012 at 11:53 AM
    #179
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Time for more mods.....;) I still need to hit up the 1/4 too.
  20. Sep 28, 2012 at 6:19 PM
    #180
    Headcase
    Headcase Active Member
    Mitchell
    Medina
    '10 Access Cab Manual-5 2.7L
    245 70 R 17's on Aluminum stuffed into the wheel wells
    Sweet Ride Bro!
    How many inches of clearance do you have lock to lock around the tires? Where does it come closest turned either way?
    I'm trying to decide how low to go and your wheel tire set up is cose to wha I'm looking for.
    Thx
    Any
