2010 X-Runner Turbo Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Hacktacular, Mar 1, 2017.
  1. Mar 1, 2017 at 8:07 PM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Vroom vroom mutha fuka.
    ChadsPride likes this.
  2. Mar 1, 2017 at 8:07 PM
    #42
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    :help:I'm:rofl:and I cant get up!
  3. Mar 1, 2017 at 8:09 PM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    :laugh:
  4. Mar 1, 2017 at 8:09 PM
    #44
    Hacktacular
    Robert
    That I am not sure of but I assume so. You know the story or else I would reach out and ask...lol
  5. Mar 1, 2017 at 8:11 PM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup. I will reload his and check it, to double check. I swore, than when i uploaded the GM coolant sensor, the values didn't change.
  6. Mar 1, 2017 at 8:29 PM
    #46
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
  7. Mar 1, 2017 at 8:33 PM
    #47
    Hacktacular
    Robert
    MrCrowntown[QUOTED] likes this.
  8. Mar 1, 2017 at 8:34 PM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Must have!
    MrCrowntown likes this.
  9. Mar 1, 2017 at 11:18 PM
    #49
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Ohhhh you're the guy who bought Clifford's kit? I think we're 2 of 3 people who have the power Fab kit. Welcome to TW!
    yota243 and Torspd like this.
  10. Mar 1, 2017 at 11:42 PM
    #50
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    @Torspd on a 2 wheel drive can a T56 or equivalent bolt right in? I must have an automatic and prefer overdrive since I drive the truck all over and back... lol
    Hacktacular[OP] likes this.
  11. Mar 1, 2017 at 11:51 PM
    #51
    PNW BlueReaper
    PNW BlueReaper Slowly but Surely
    Aaron
    Kent, WA
    05 DCSB Indigo Ink Tacoma
    Wish i had the money to buy and install a turbo. This is simply amazing.
  12. Mar 2, 2017 at 4:38 AM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yes-ish. The crossmember needs to be slightly altered (mounting holes raised and extended rearward) and the drive shaft needs to be lengthened. 2wd that is PreRunner / 4x4 platform.
    On a 5 lug, the kit comes completely ready, minus driveshaft.
    For AWD, contact www.RSGear.com and they have a tranfercase, with driverside output. Bolt up the whole thing, and adapt the front drive shaft's length and mating flange.
    nfs257[QUOTED] likes this.
  13. Mar 2, 2017 at 4:39 AM
    #53
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sad original story, but the kit has a happy home, runs great, and surprises the heck out of people. :devil:
  14. Mar 2, 2017 at 6:40 AM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Mar 2, 2017 at 8:39 AM
    #55
    MrCrowntown
    Alyn
    Ky
    Theres an S1 sequential shift adapter for a t56 too. They're just getiing into production, I remember getting an email a while back from them. Still requires the use of the clutch as it still uses whatever synchros are already in the case
    Hacktacular[OP] and superwhite like this.
  16. Mar 2, 2017 at 8:53 AM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    1-4 gear set, and that shifter. Done.
  17. Mar 2, 2017 at 8:54 AM
    #57
    MrCrowntown
    Alyn
    Ky
    You are pickin up, what I'm settin down :cool:
  18. Mar 2, 2017 at 9:22 AM
    #58
    ChadsPride
    Sponsored by TacomaWorld.com
    Damn, nicely done OP! ​
    Hacktacular[OP] and MrCrowntown like this.
  19. Mar 2, 2017 at 10:32 AM
    #59
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
  20. Mar 2, 2017 at 11:38 AM
    #60
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
