2010 X-Runner Turbo Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Hacktacular, Mar 1, 2017.
  1. Aug 25, 2017 at 6:09 PM
    #81
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Ohhh I know what it is but easier to start the engine and then check timing...lol
  2. Aug 26, 2017 at 5:13 AM
    #82
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pretty nifty!
  3. Aug 26, 2017 at 5:39 AM
    #83
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Speaking of timing. What did you end up with your as your final degrees of timing Hack?
    Curious how close it was to the number which I gave you.
  4. Aug 26, 2017 at 9:19 AM
    #84
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Thats not going to work with setting the TDC offset angle for the Haltech. I'll only really need it once, so thank god it was only 15 bucks lol
  5. Aug 26, 2017 at 9:30 AM
    #85
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    I noticed you did a TOB fix, was that the URD kit? Also, was your TOB squeaking before you replaced everything? Sick truck man!
  6. Sep 5, 2017 at 4:03 AM
    #86
    Hacktacular
    Robert
    Yes, URD. I had the TOB replaced under TSB because of the squeak. Once stock clutch slipped on dyno I changed it out and figured I might as well do this mod while I'm in there.
    Torspd likes this.
  7. Sep 6, 2017 at 7:21 PM
    #87
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Might not be the time, but a few questions. I know we discussed it a little, but did you ever hook up the analog wire of the AEM wideband to a spare AVI on the Haltech? @MrCrowntown and I were discussing him doing that, and that it should work. Thus circumventing the necessity for the Wideband CAN box.
    Hacktacular[OP] likes this.
  8. Sep 6, 2017 at 7:25 PM
    #88
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Curious how yours is running as well? Still crushing dreams?
    After all of the water in my engine, I was having a stumbling issue sporatically, and then a rather lengthy episode today. Cleared itself up enough to make it home fine. Pulled out the sensors and re-calibrated them. Been a beauty since.
    HomerTaco likes this.
  9. Sep 6, 2017 at 7:30 PM
    #89
    Hacktacular
    Robert
    It works fine Torspd. The biggest potential issus is that if the O2 somehow fails rich then engine will go lean and the ECU has no way to determine the failure. That is the benefit to the Haltech. BTW if any needs help once this storm passes, I have no problem logging in to see your screen and helping out...
    MrCrowntown and HomerTaco like this.
  10. Sep 6, 2017 at 7:33 PM
    #90
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Makes sense. Stay safe my man. :rain::pray:
    @MrCrowntown certainly would like that. :cheers:
    MrCrowntown likes this.
  11. Sep 6, 2017 at 7:38 PM
    #91
    Hacktacular
    Robert
    Still running good. Need to get to a load bearing dyno. Haven't run it much but the last couple BMW'S I ran, one was in awe and "couldn't get his race map loaded" and the second on had 16psi and kicked my ads by 2-3 cars. But I have a full truck 4 people. Needless to say he was impressed and wanted to pull over but I declined with the family in the truck....lol. Fun times with sleepers. Dyno and a bcv and it will get real interesting....glad you got that striker sorted out!
  12. Sep 6, 2017 at 7:41 PM
    #92
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Man, I would love to see yours at an autocross or road course. Maybe even FL2K. ;)
    Out for the night brother!
  13. Sep 7, 2017 at 11:23 PM
    #93
    MrCrowntown
    Alyn
    Ky
    I'm having some initial setup issues. Not sure where the problem lies exactly.
    :bananadead:
  14. Sep 19, 2017 at 5:33 PM
    #94
    Hacktacular
    Robert
    Not sure why I wasn't notified of this new reply but, whats up?
  15. Sep 21, 2017 at 12:00 AM
    #95
    MrCrowntown
    Alyn
    Ky
    Im having a terrible time getting my truck to start.
    Im getting good trigger signal, but isn't controlling my fuel correctly I think? I may be running into shitty injector problems.. I'm a total newb but am a quick study.
  16. Sep 21, 2017 at 6:45 AM
    #96
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What was the voltage that you had to adjust?
  17. Sep 21, 2017 at 7:42 AM
    #97
    Hacktacular
    Robert
    Does it actually start? I can teamveiwer in if you would like and have a look. As Torspd mentioned you will need the injector specifications if at all possible. Shoot me a PM with a number and a time after 6pm and I can try to log in and have a look. Torspd helped me with initial setup so it is just a matter of checking everything and finding important info like injector specs. I can offer a map that we know starts our trucks.
    Do you have any errors in the diagnostics tab at all?
  18. Sep 21, 2017 at 6:07 PM
    #98
    MrCrowntown
    Alyn
    Ky
    It started then either flooded itself out, or leaned out. The AFR gauge was all over.
    Ive had to find comparable dead times from other modified denso 650cc injectors. I sourced mine from a speed shop in Thailand before I found options from the states.. and the language barrier is severe at best so they dont know what I'm asking of them.
    Im currently on vacation in california, but when I get back to AZ I would definitely appreciate your assistance
  19. Sep 21, 2017 at 7:36 PM
    #99
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What size did they start as, the Denso injectors?
    I'll be an optimist and a realist. I hope that you can get those injectors to work. Otherwise you might very well need to purchase something more local. Deatschwerks, Injector Dynamics, etc, etc....
  20. Sep 22, 2017 at 8:03 AM
    #100
    MrCrowntown
    Alyn
    Ky
    Im leaning towards that idea honestly...injector dynamics is a 20min drive from my house lol
    And I think they start as stock tacoma injectors, but I couldn't find any dead times or flow rates for them..
