2010 X-Runner Turbo Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Hacktacular, Mar 1, 2017.
  1. Sep 22, 2017 at 9:20 AM
    #101
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you do get some Injectors Dynamics, then get the size which will feed your ultimate engine HP goal, with consideration to the fuel you plan to use.
    I have my Dead times for my stock injectors. Want me to post them up?
  2. Sep 22, 2017 at 3:21 PM
    #102
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    You think they're the same?? Ill try anything at this point lol
  3. Sep 22, 2017 at 3:27 PM
    #103
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Doesn't hurt to try. As long as you have the proper size entered as well.
  4. Sep 29, 2017 at 7:54 PM
    #104
    MrCrowntown
    Alyn
    Ky
    Im unsure of the flow rate though.. cand find it anywhere. Maybe i just get the damned FiveO injectors or the ID and be done..
    :censored:
    Hacktacular[OP] likes this.
  5. Oct 15, 2017 at 2:12 PM
    #105
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    I'm running deka 80lb. They have been good.
  6. Apr 25, 2018 at 5:09 PM
    #106
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    I need a unichip harness :pout:
  7. Apr 25, 2018 at 7:09 PM
    #107
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    See if you can find a used one.
  8. Apr 25, 2018 at 7:10 PM
    #108
    GT7
    Grant
    Phoenix
    2013 DCLB
    Already tried. Its obviously the route to go. Ill find one eventually
  9. Apr 26, 2018 at 3:44 PM
    #109
    GT7
    Grant
    Phoenix
    2013 DCLB
    I wonder if I went to the junk yard and got an oem harness, if the could use that. I dont see why not but I have no idea.
  10. Apr 26, 2018 at 3:48 PM
    #110
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Get a used ecu from an '05-'08. Get the harness that matches. Make sure both match the majority of the components that yours has.
    Then you'll no longer have to worry about the SAIS system either. ;)
  11. Apr 26, 2018 at 3:50 PM
    #111
    GT7
    Grant
    Phoenix
    2013 DCLB
    I thought about that, but its all wired for 6 connectors, so wouldnt I have to get a whole new wiring harness? And what DTC’s can the haltech control?
  12. Apr 26, 2018 at 3:56 PM
    #112
    GT7
    Grant
    Phoenix
    2013 DCLB
    I realize you said get the 05-08 harness. But wouldnt I have to replace the entire harness and engine harness?
  13. Apr 26, 2018 at 4:23 PM
    #113
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The engine harness, yes.
  14. Jun 12, 2018 at 4:10 PM
    #114
    Hacktacular
    Robert
    Ok, fellas. I added some more goodies and pics. I hope you all approve. ;)~ More Power!
    yota243 likes this.
  15. Jun 12, 2018 at 4:14 PM
    #115
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Where?
    yota243 likes this.
  16. Jun 12, 2018 at 4:18 PM
    #116
    Hacktacular
    Robert
    1st post Red, sorry for the confusion.
    RedLantern likes this.
  17. Apr 12, 2019 at 3:15 PM
    #117
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Great thread on your build. Curious if you can link me to a thread on replacing the rear drums with discs?
  18. Apr 12, 2019 at 3:25 PM
    #118
    Hacktacular
    Robert
    Thanks bud!
    I didn't document the rear upgrade well but I should have some pics. It was a pain in the ass to get the spring clips on. @Torspd got that call... Haha. I remember that! I also had to cut off the backing plates, and modify the axle housing for the abs sensor too. We'll worth it in the end. Stoptech on all four corners now.:D
    Torspd likes this.
  19. Apr 12, 2019 at 4:25 PM
    #119
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup, I have some of those pictures in my build thread.
    Athlaos[QUOTED] and HomerTaco like this.
  20. Jun 23, 2019 at 11:05 AM
    #120
    Boostboostboost
    Boostboostboost New Member
    2010 Xrunner
    Hello there!
    I feel like the best way to introduce myself is as the guy who googled this truck before I bought it.
    Short story:
    I needed a truck for work that was also fun. Thinking SVT Lightning, SRT-10 Ram, and that was pretty much it.
    Found this peculiar add for this EXACT truck in Hollywood, FL and confirmed it was the same truck in this build thread.
    The story is interesting to say the least but more on that later. Anyways, I traded in my NEWER, LOWER MILEAGE vehicle (2012 Nismo 370Z) And I was also payed cash on top, so ultimately a fair trade for me.
    I love the quality parts and work put into this truck. With experience building turbo vehicles, I will continue to improve this truck. My last project was a 1995 Audi S6 Avant with an RS2 turbo and Vems standalone ecu. That 2.2L put down about 350awhp.
    Back to the truck -
    Immediately I performed an oil change and trans fluid flush just to check for any potential particulates or damage. No issues so far!
    Plans for the next two weeks are as follows:
    - Order fittings and 3/16 stainless hardlines and replace all the silicone vacuum hoses for peace of mind
    - Make a bronze clutch pedal bushing on my lathe to reduce side-to-side slop. If I'm happy with the finished product, I will make more for anyone interested in a solution for this issue.
    - Check condition on drivetrain/motor mounts and look into solutions to reduce drivetrain shock
    - Look into replumbing the catch can and updating to a Mann Pro-vent unit.
    Thats pretty much it for now!
    MY50cal, Scribbles, randd and 7 others like this.
