2010Toyota Tacoma 2.7 won’t start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Byrdman950, May 17, 2021.
  1. May 17, 2021 at 2:41 PM
    Byrdman950
    Byrdman950 [OP] Member
    Justin
    2010 Toyota Tacoma 2.7
    Okay guys and gals I bought a 2010 Toyota Tacoma base model from my dad after he hit a deer and done significant damage to it passenger side was damaged it’s sat at a body shop since October I got it middle of April I looped the transmission lines together and drove it on a trailer and drove it in and out of the shop as I was working on it I got it fixed and drove it to work 3 times drove all over the place one weekend went out this past Sunday and it would start and die now I can’t get it to do anything but spin over anyone ever had this problem and what did you do to fix it? Note: I have checked all fuses obd2 reader comes up as link error when connected is this a sign of a fried ecm?
  2. May 17, 2021 at 4:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    How did you check the fuses?
    If just visual you need to check them again using a Multimeter or a Test Lamp.
    OBD Fuse.
    IGN Fuse.
    EFI Fuse.
    BassAckwards likes this.
  3. May 17, 2021 at 4:20 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    One good test if done briefly is to spray a whiff of starting fluid into the intake while starting. IF it starts it narrows down the cause to no fuel situation and shows that spark and air are good.
    BassAckwards and TnShooter like this.
  4. May 17, 2021 at 4:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree. Do this, then let us know what happens.
  5. May 19, 2021 at 6:50 AM
    Byrdman950
    Justin
    I found out what it was I checked all fuses with meter before I made the post but I found out my computer quit on me not sure what made it quit but I’ve got one ordered thanks for the help!
    Jimmyh likes this.
  6. May 19, 2021 at 8:32 AM
    TnShooter
    Deogee
    STOCK
    Thanks for the update.
    You don’t to see an ECU fail o these trucks too often.
    Hopefully it was just bad luck, and not something else that caused it. :fingerscrossed:
  7. May 19, 2021 at 10:30 AM
    Byrdman950
    Justin
    I looked up past codes from the day before and I got a p0607 code control module performance and yeah I can I had a 06 sport with 600k miles on it and wrecked it but their hard enough to find flagship one sells them programmed so I payed the little extra and got it comes with lifetime warranty
  8. May 19, 2021 at 10:35 AM
    Taco'09
    Taco'09 Well-Known Member
    Suppose you could elaborate a little. You lost me at "flagship one". Link maybe?
  9. May 19, 2021 at 1:30 PM
    Byrdman950
    Justin
  10. May 19, 2021 at 5:11 PM
    Taco'09
  11. May 19, 2021 at 7:27 PM
    Byrdman950
    Justin
    Will do! I am proud to be a part of the Tacoma crew again this group of people is one of the best groups I’ve ever had anything to do with!
    BassAckwards, Markcal and Jimmyh like this.
  12. May 27, 2021 at 9:44 AM
    Byrdman950
    Justin
    My ecm from flagship one has been delivered great customer service the whole way updated me every day would 100% recomend them for all of your ecm needs!
  13. May 27, 2021 at 9:51 AM
    Taco'09
    We are sitting on the edge of our seats.......but be methodical and check every connection several times....
  14. May 27, 2021 at 10:44 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yeah definitely interested to hear if the ECU fixed your issues
  15. May 28, 2021 at 1:27 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Before you install it, I would be very concerned with what fried the ECU in the first place, it's really rare to see one let the smoke out on its own these days. If I were you, I'd spend a while testing every wire that goes into the ECU harness for proper voltage/resistance/etc. Especially considering that there was previous collision damage, it very well could have been caused by damaged wiring that got overlooked in the repairs. I'd hate to see a short or wiring damage zap your new computer.
