2011 2.7 hesitant starts?
Discussion in '4 Cylinder' started by ISUGrad05, Dec 28, 2011.
  1. Dec 28, 2011 at 9:17 PM
    ISUGrad05
    ISUGrad05 [OP] Public Servant Enemy #1
    Wichita, KS
    2012 4x4 5.7 Tundra DoubleCab
    Since the very first day I bought this truck new, the engine has hesitated to start every now and then. The truck has 14000 miles and is driven pretty much every day. About once or twice a week when I crank the ignition its like the starter is cutting out and I have to hold the key to start for 3 to 4 seconds. It has never failed to turn over and start but has done this under varying conditions, ie cold/hot temperatures, short/long trips, after sitting for a week in the driveway, ect. Its almost like the starter doesn't have enough torque to turn over the engine. Just wondering if anyone else noticed this or not.
  2. Dec 29, 2011 at 7:28 AM
    SpE3dF0x
    SpE3dF0x MD bound!
    Fox
    San Antonio
    2013 TRD Tacoma Sport
    Nothing its tooo new!
    I've just purchsed a 2010--(5speed) and notice it's happened to me sometimes...wonder why-- anyone got any info on why?
  3. Dec 29, 2011 at 7:30 AM
    Aw9d
    Aw9d That one guy
    Az
    Let your injectors prime up first before cranking the motor over.
  4. Dec 29, 2011 at 7:33 AM
    T-Rex266
    T-Rex266 T-Rex Moderator
    Should be warrantied still? Take it to the dealer
  5. Jan 5, 2012 at 8:26 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Bingo! Just try waiting a second or two with the key in the on position prior to cranking the motor to see if it fires right up. :)
  6. Jan 5, 2012 at 11:11 AM
    johnanm
    johnanm Well-Known Member
    Up
    2011 Double Cab 2.7L Prerunner
    Bilstein 5100 @ 1.75" front shocks on stock springs, AFE ProDry drop-in, white DTRLs, Sylvania ZXE headlamps, DeeZee bed mat, Tailgate hose clamp mod, cheap snap craigslist tonneau, Weathertech vent visors, secondary air filter removed, Class III hitch
    I've noticed this from time to time, it's very subtle but I'll try the injector priming and see if that speeds it up.
  7. Jan 21, 2012 at 1:02 AM
    Skidmarc
    Skidmarc Active Member
    Marc
    Atlantic Canada
    4WD I4
    Clutch pedal all the way in??
  8. Jan 21, 2012 at 1:27 AM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
    I havent had any problems with mine. Has almost 7k miles on it.
