2011 2.7L 4x4 Clutch Slipping.. Help?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Stick Sh1ft, Jan 18, 2012.
  1. Jan 18, 2012 at 2:48 PM
    Stick Sh1ft
    Stick Sh1ft [OP] Active Member
    Tim
    Southern IL
    11 White Reg Cab 4x4 5spd
    Tonneau Cover
    I have a 2011 Tacoma Reg Cab, 2.7L I4, 5spd Manual, about 11,000mi. I've noticed in the last month the clutch has started slipping. First instance I noticed it was in 4th gear around 50 mph accelerating and noticed something wrong. I let off the throttle, stabbed it and noticed an rpm flare. It was in the low to mid 30s outside when that happened, so I was wondering if that made a difference somehow.
    I know how to drive a manual and I don't ride the clutch but I will admit, I could probably be shifting a bit slower than I am, and I do give a little throttle overlap to aid smoothness of shifting. I do not, however, jam the thing between gears, I don't ride the clutch on the rpm drop after the shift.
    I was going to take it into the dealer but couldn't get it to do it again. A few weeks later, I noticed that during shifts, the clutch was reluctant to engage. I'd shift at around 2500rpm, do my throttle overlap and if I stabbed the throttle instead of my usual input, the rpm's would float around 2000-3000 for a few seconds, I let off and they'll drop back down and the clutch engages. Then today coming home from school, I finally noticed the slip in 4th gear again, same situation. 4th gear, 50mph, sudden brisk acceleration. It, of course, wouldn't do it when I tried it later, but when going up a hill I did notice a smell that I swear was burning clutch, but this was when I didn't notice it slipping.
    Long story short: It *sometimes* slips in 4th gear, the clutch is reluctant to engage on shifts, I'm not sure how to convince the dealer that it is a defect.
    I almost don't want to drive it anymore until I get the problem sorted out, the more it slips the more it's going to look like driver error and the dealer will just tell me I'm riding the clutch and it's not covered under warranty.
  2. Jan 18, 2012 at 3:13 PM
    Thundjet
    Thundjet Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    Am guessing it is a hyd clutch? If the fluid looks dark or dirty get one of those turkey basters at Wal Mart and suck out some fluid, put in new and work the petal about 50 times. Do this a few times and see if it helps.
    Doesnt make sense it will do it sometimes and not all the times unless you are running the shit out of it when you notice it is slipping.
    If the clutch was shot it would slip more in the lower gears since more torque is being applied to it.
  3. Jan 18, 2012 at 4:05 PM
    Stick Sh1ft
    Tim
    Southern IL
    Tonneau Cover
    I honestly haven't held down the accelerator for too long for fear of burning up the clutch, but yes, I shift, stab the throttle, the revs don't drop, they float there. They did decrease slightly so I'm guessing they would, I'm just going to check this real quick.
  4. Jan 18, 2012 at 4:06 PM
    Stick Sh1ft
    Tim
    Southern IL
    Tonneau Cover
    Yep it's a hydraulic clutch. And yeah it is weird how it only does it in 4th.
  5. Jan 18, 2012 at 4:08 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    my buddy's 4 cylinder was doin the same thing. he just had toyota replace the cluth and flywheel all under warranty
  6. Jan 18, 2012 at 4:32 PM
    Stick Sh1ft
    Tim
    Southern IL
    Tonneau Cover
    Gelo760, What happens is I'll shift and the clutch will hover at an rpm and until the truck's going fast enough so the trans matches speed with the engine it'll stay there. Once the clutch grabs it'll drop a few hundred rpm. And I did manage to get it to slip in 4th again, I think I'm calling the dealer tomorrow.
  7. Jan 18, 2012 at 4:34 PM
    Stick Sh1ft
    Tim
    Southern IL
    Tonneau Cover
    Thanks for all the replies guys, good to know I'm not going insane.
    Edit: Clutch glazing, sounds about right.
    Is it the Luk clutch? that's what I've been reading.
  8. Jan 18, 2012 at 4:47 PM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    I don't think anyone has found the actual document, just references to it and a brief summary.
    This may be the number....CLUTCH TSB-0066-11
  9. Jan 18, 2012 at 4:48 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Slipping already? Maybe it's your driving?
  10. Jan 18, 2012 at 4:48 PM
    Stick Sh1ft
    Tim
    Southern IL
    Tonneau Cover
  11. Jan 18, 2012 at 4:51 PM
    Stick Sh1ft
    Tim
    Southern IL
    Tonneau Cover
    I highly doubt that, I drove my dad's Yaris for a year and a few months (Same amount of time I've been driving the Tacoma) as my daily driver and that car's now got 30K on the ODO and no clutch problems.
  12. Jan 18, 2012 at 4:56 PM
    jflan
    Vancouver, WA
    I had found that, but it's someone's translation, not an official Toyota document as all TSB's are.
    I think that you could be in the early stages of the defective clutch disk failing.
  13. Jan 18, 2012 at 5:03 PM
    Tbones taco
    Tbones taco Well-Known Member
    Tony
    Carrollton
    07 PreRunner ext cab
    Flowmaster 40 smittybuilt bull bar smittybuilt nerf bars hella lights crome custome grill
    Good luck all. I have a V6 auto and have the torque converter shutter. It's an 2007 and out of warranty. My dealer says they will have a fix in April and i will get a new one at no charge. I'm crossing my fingers. I know Toyota will take care of y'all.
  14. Jan 18, 2012 at 5:05 PM
    Stick Sh1ft
    Tim
    Southern IL
    Tonneau Cover
    I'm actually attending a technical college and am currently in the process of becoming a certified Toyota Technician, so there's a database of information we get to use, all official Toyota stuff. I found a TSB about the Tacoma's 5 speed's clutch having "difficulty engaging" And it is void if the vehicle even moves...
  15. Jan 18, 2012 at 5:33 PM
    jflan
    Vancouver, WA
    Have you checked your database for the TSB number mentioned in this thread ?
    It's weird how this TSB document is non-existent in the usual places.
  16. Jan 21, 2012 at 10:52 PM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    I hope someone can find the tsb my stearlership wants 1200 for my clutch job and I would love to throw that tsb in there face I've got 35000 and it's only doing it in fourth also.
  17. Jan 22, 2012 at 2:29 PM
    AKTACO420
    RETODD
    Anchorage AK
    2009 tacoma
    I don't think that tsb applys to me because my clutch engages And it seems like it only slips in 4th gear around 50. But I sure as hell will show it to them and see what they say
  18. Jan 22, 2012 at 3:25 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    Wrong, the slipping clutch will be more evident in higher gears, because more torque, on the clutch, happens in higher gears. Read older posts, everyone with this problem experiences it first in the higher gears.
    The engine applies more torque to the clutch in higher gears, but applies more torque to the drive wheels in lower gears.
  19. Jan 22, 2012 at 4:08 PM
    jassco
    jassco Well-Known Member
    Boston
    2008 4runner, UrbanRunner Silver
    I'm at 23,000 and I have issues getting into 2nd gear. I have had this happen in 3rd and 4th to me in the morning while engine as cold. Dealer time it seems.
  20. Jan 23, 2012 at 5:52 AM
    Stick Sh1ft
    Tim
    Southern IL
    Tonneau Cover
    Update: Clutch is still slipping but is *much* less noticable, I procrastinated taking it to the dealer and now it's in the 40s and it only slips slightly during shifting. Hoping it gets colder so I can just take it in.
