2011 4x4 Reg Cab - Hunting - Fishing
Discussion in '2nd Gen. Builds (2005-2015)' started by PintSize, May 17, 2017.
  1. Dec 31, 2017 at 1:15 PM
    #141
    ChadsPride
    Sponsored by TacomaWorld.com
    Happy New Year brother!!!
    :cheers:
  2. Jan 1, 2018 at 7:21 AM
    #142
    PintSize
    PintSize [OP] Crossthreaded & torqued down
    Texas
    2011 2.7L 5 spd RC 4x4
    Thank you!
    ChadsPride[QUOTED] likes this.
  3. Jan 1, 2018 at 9:21 AM
    #143
    ChadsPride
  4. Jan 5, 2018 at 7:00 AM
    #144
    PintSize
    Texas
    To be bolted on soon...
    Kemosabe and ChadsPride like this.
  5. Jan 5, 2018 at 7:01 AM
    #145
    ChadsPride
    :yay: :headbang: :militarypress: :muscleflexing:
    PintSize[OP] likes this.
  6. Jan 5, 2018 at 7:07 AM
    #146
    PintSize
    Texas
    Yeah I’m pretty psyched. Got these to install and put the 884s/5100s on. Next weekends project with my brother.
    Kemosabe and ChadsPride[QUOTED] like this.
  7. Jan 5, 2018 at 7:09 AM
    #147
    ChadsPride
    Sick!!!!
    Interested to see how much lift you get out of the 884s
    I will be going that route before too long
  8. Jan 5, 2018 at 7:26 AM
    #148
    PintSize
    Texas
    We will see I hear 885s are a bit much for regular cabs so I’m going with these and I really am looking forward to get the poly spacers out!
  9. Jan 5, 2018 at 7:29 AM
    #149
    ChadsPride
    Should be a really nice upgrade!
  10. Jan 8, 2018 at 7:27 PM
    #150
    PintSize
    Texas
    Got another TRS OR rim off Craigslist today. Gonna make a matching spare. B5A77A00-E386-4EF3-95B7-62424BD72F9F.jpg
    ChadsPride, Kemosabe and BassAckwards like this.
  11. Jan 8, 2018 at 8:13 PM
    #151
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Subbed af!:D
    ChadsPride and PintSize[OP] like this.
  12. Jan 8, 2018 at 8:24 PM
    #152
    PintSize
    Texas
    Thanks :thumbsup:
  13. Jan 15, 2018 at 2:12 PM
    #153
    PintSize
    Texas
    Removed the poly spacer lift and installed OME 884s on Bilstein 5100.
    Here’s the old lift
    Used the compressorless method alone, was not too sketchy. Marked the alignment cam tabs, loosened same. Took off the two ball joint bolts, and the shock top nut. Top hats needed to be removed to get the spacer kit extenders off.
    CC9A36ED-3E0E-4BE4-A00F-61E1B8CB03A8.jpg 772A6D28-9673-4590-A8B8-B9308D953319.jpg
    I reused the old top hats, they didn’t have much wear. Took more time to install taking the spacer kit off.
    Drivers side all buttoned up with thread locker and I torqued everything to spec. I did good today and didn’t cross thread anything!!! 47A624D4-7D82-4620-9C07-C6AF5C6E5BA3.jpg
    I didn’t measure lift, before or after. But I think maybe it added 3/16” to 1/2” an inch. At the alignment shop now. Rides much, much better. Can’t believe I waited this long to do this.
    Greenbean, Kemosabe, Phoosa and 2 others like this.
  14. Jan 15, 2018 at 2:14 PM
    #154
    ChadsPride
    Good work!! :bananadance: :taco:
  15. Jan 15, 2018 at 2:16 PM
    #155
    PintSize
    Texas
    :transformer:
    I did it solo too, took about 4 hours. Took a few breaks too as I cleaned, primed and painted the sliders :D
  16. Jan 15, 2018 at 2:17 PM
    #156
    ChadsPride
    Not too bad at all!! I'm very proud to say the least!
    :headbang: :woot: :popcorn:
  17. Jan 15, 2018 at 2:20 PM
    #157
    PintSize
    Texas
    Thanks
  18. Jan 15, 2018 at 2:23 PM
    #158
    BassAckwards
    Truck looks good!
  19. Jan 15, 2018 at 2:25 PM
    #159
    ChadsPride
    When's the slider install going down?
    MarX and PintSize[QUOTED][OP] like this.
  20. Jan 15, 2018 at 2:27 PM
    #160
    PintSize
    Texas
    Cleaned the sliders today with acetone while installing the front lift and spray painted Rustoleum self etching primer and semi gloss black enamel. I used two cans of primer and two cans of black enamel. To be bolted on tomorrow.
    E2E49848-A735-4822-8601-5E94BD44F711.jpg A0AD5230-3F2B-436B-A0E2-F80BFB3280EB.jpg CA868B89-1D0F-444B-903B-8F35A1A9A2E1.jpg
    MarX, SOS CONCEPTS, Kemosabe and 2 others like this.
