2011 5100 Series - Adjustable shocks.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeniorSpan, Jan 6, 2011.
  1. Jan 6, 2011 at 10:07 AM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    18 TRD DCSB OF
    In anticipation of eventually getting the Rear Spring TSD done to my 2011 4x4 DC SB I thought I would be proactive and order a set of 5100 Series - Ride Height Adjustable shocks form the front vs springs spacers. Most venders have 2010 listed but no 2011s yet.
    Anyone have a p/n for the 2011's or a suggestion as to the best place to buy?
    Cheers
    Bob
  2. Jan 6, 2011 at 10:10 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Same shock as the 2010.
  3. Jan 6, 2011 at 10:10 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
  4. Jan 6, 2011 at 10:39 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    yup... make sure you get the TSB done b4 you install them. Dealers will give you a hard time
  5. Jan 6, 2011 at 12:11 PM
    SeniorSpan
    Bob
    Colorado Springs
    18 TRD DCSB OF
    Thanks much, the advice is appreciated.
  6. Jan 6, 2011 at 4:29 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Mine didn't. The service manager actually wanted to know where he could get a set for his Taco.
  7. Jan 6, 2011 at 5:21 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    i would wait till after the tsb
    some knuckle heads would probably change them on you.
  8. Jan 8, 2011 at 8:00 AM
    SeniorSpan
    Bob
    Colorado Springs
    18 TRD DCSB OF
    Thanks for the inputs. The difficult part will be getting the TBS done. 5100's will be easy.
    Will need an alignment after shocks are installed, correct?
  9. Jan 8, 2011 at 8:14 AM
    2009 taco
    2009 taco Well-Known Member
    juan
    lompton, CA
    09 sport
    jba headers, outlaw flowmaster, 3 inch pipes, k and n cold air intake, throttle body spacer, halo headlights, HIDs, deaver springs, kings all the way round, Built right UCAs, camburg spindles, Satoshi bumper and main grill, sliders
    that is correct. get it done asap after install.
  10. Jan 8, 2011 at 8:47 AM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    I drove around for about a week before getting an alignment. Let everything settle a bit.
  11. Jan 8, 2011 at 4:47 PM
    neoflex
    neoflex Well-Known Member
    Anyone know of a vendor that has these in stock? Seems downsouth is out.
  12. Jan 8, 2011 at 6:23 PM
    2009 taco
    juan
    lompton, CA
    09 sport
    I drove mine a week and now I need two new tires. I drove a little too much
  13. Jan 9, 2011 at 4:54 AM
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    No problems with my toyota tech he did the TSB and intalled the 5100's along with the toytec coil-overs for me.
