2011 6in lift
Discussion in 'Suspension' started by Ledzepco, May 3, 2011.
  1. May 3, 2011 at 9:52 PM
    Ledzepco
    Ledzepco [OP] New Member
    Oregon
    11 Tacoma
    Looking to see if a 6in lift with 18in wheels and 35in tires will fit a 2011 tacoma extra cab without cutting the fender wells? also does anyone know if there is no cutting will there be any tire rubbing any were? Thanks
  2. May 3, 2011 at 9:53 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  3. May 4, 2011 at 12:20 AM
    ShaydenandDiezel
    ShaydenandDiezel Well-Known Member
    Hawaii
    TRD
    6 inch Pro Comp Suspension Lift. K&N intake. Air Raid throttle body spacer. 20 inch XD Diesel rims. 33x13.50 Irok tires. Single in dual out exhaust with SS tips.
    How wide are your tires? I have 33x13.50 and they needed to trim mine to fit my tires. You can't tell it was trimmed. Another is the body mount might have to be moded. They make a kit for that too. You could ask them to crank you torsion's tighter and squeeze out an inch or so. But your ride will be stiffer. Or get a body lift with the 6 inch suspension.
  4. May 4, 2011 at 12:43 AM
    Manwithoutaplan
    ID
    Dont do it man get a all pro long travel kit, it is more worth the money.
  5. May 4, 2011 at 1:08 AM
    lvlytaco
    lvlytaco Well-Known Member
    Allan
    Hawaii
    Got Lip?
    6" procomp basic lift, alpine dbl din, 9" headrest screens, mb quart components, jl amp, yellow top battery, wet okole seat covers all around
    i rub in reverse at full lock with 33x13.5 tires....
