2011 Access Cab closing door issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GaryS1964, Jul 2, 2011.
  1. Jul 2, 2011 at 1:18 PM
    GaryS1964
    GaryS1964 [OP] Member
    When I close the door (either door) on my Tacoma unless I slam it pretty good it doesn't close. The second attempt requires very little force to get it to close. Is this common?
    Something else to add is that when the opposite door is open or the window is down it closes with little force making me want to think that it is due to a fairly pressure tight cabin. But if that were the case why does it close easily on the second attempt when the air pressure would be the same?
  2. Jul 2, 2011 at 1:24 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    it's normal, mine does the same thing, and i've seen other people with the problem aswell
  3. Jul 2, 2011 at 1:27 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    There was a thread a couple of months back where someone's access cab doors on their 2011 didn't line up properly.
  4. Jul 4, 2011 at 1:23 AM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Escondido
    2014 SSM Trd Off Road 4x4 Auto
    It's not a line up issue seen issue a bunch and I have the same prob it is very air tight. The reason it closes easy the second time is when u try closing it again ur not opening it all the way or I know I don't therefore not as much air pushed into cab
  5. Jul 4, 2011 at 2:52 AM
    Eurosport
    Eurosport Well-Known Member
    if you ever upgrade your stereo speakers, put some dynamat/second skin on the doors, you won't believe the difference in how easy they close as well as no more flimsy feel to them...
  6. Jul 4, 2011 at 3:33 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    The dynamat is adding weight, which gives it more momentum, and hence easier to close. I'd recommend going to the cab vent and seeing if it is stuck or something covering it etc.
  7. Jul 4, 2011 at 11:39 AM
    GaryS1964
    I tend to agree with your reason. Seems to be the most reasonable explanation based on the many variables involved like other open doors or windows, second attempt, etc..
    I suspect it just a matter of getting use to it. On my 2000 Ranger all it took was a gentle shove to close the doors. Since I'm not one who likes to slam doors it just a matter of finding the right amount of "shove" necessary to get the door to close the first time.
  8. Aug 21, 2013 at 6:09 PM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    Never had this problem on my 09 but I have to close the doors twice on my 12. It sucks, I'm constantly having to re-shut the door. Gonna do some sound deadening in the doors to help.
  9. Aug 21, 2013 at 6:14 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I noticed that to, my 08 closed easy, my 10 takes 2 tries usually or a really good slam
  10. Aug 21, 2013 at 6:37 PM
    csjumper2003
    Escondido
    Its air pressure. If you leave your window cracked you will never have that problem again.
    The dealership showed me with windows up the air pressure stops the door from closing easy, But with the window cracked the door closes fine.
