2011 Crew Cab TRD Sport Diesel Build
Discussion in '2nd Gen. Builds (2005-2015)' started by steed, Feb 8, 2016.
  1. Nov 10, 2016 at 5:02 PM
    #81
    steed
    steed [OP] Well-Known Member
    Steed
    Tacoma
    Starting to work on the controller for the ISB3.9.
    This will allow the use of a Edge juice with attitude programmer. Convert some J1939 to OBD2, as well as, controlling the 68RFE and two variable geometry turbochargers Independently. One Garrett GT-XXXX-KLVN series and one Holset VGT.
  2. Dec 15, 2016 at 4:49 PM
    #82
    steed
    Steed
    Tacoma
    Joey @ the custom fab shop finished up my adapters for my Turbochargers.
    If you need something like this, check out his site.
    http://www.customfabshop.com/
    Torspd, Nickel and G.T. like this.
  3. Dec 19, 2016 at 5:32 PM
    #83
    steed
    Steed
    Tacoma
    Here's an update, looks pretty awesome. This thing is going to scream!
    V-band to Holset VGT adapter
    GT3571KLVN to V-Band adapter
    Nickel, NAAC3TACO, Caltech90 and 2 others like this.
  4. Dec 20, 2016 at 4:58 AM
    #84
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    That is art! How's your motor? Finished?
  5. Dec 20, 2016 at 7:05 AM
    #85
    steed
    Steed
    Tacoma
    Thanks, it's still in pieces. Hopefully soon.
    ZZ Fab made my intake flange. Once I get that I'll start working on the intake. Plan is to build a runner setup similar to a 2JZ intake plenum.
    G.T. likes this.
  6. Dec 20, 2016 at 3:08 PM
    #86
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    I have almost no idea what that is. Supra? Doesn't matter, I'm sure this thing will be badass when it's finally done.
  7. Dec 20, 2016 at 5:24 PM
    #87
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    Subbed, this build is awesome!
  8. Dec 21, 2016 at 7:33 AM
    #88
    5amtaco93
    5amtaco93 Well-Known Member
    Sam
    South Bend, WA
    '11 base 4x4 5 speed
    I can't remember
    Subbed. Can't wait to see this thing come together!
  9. Dec 23, 2016 at 5:31 PM
    #89
    steed
    Steed
    Tacoma
    ZZ Fab send me a flange so I can make my own intake. Mine is going to be different then the normal designs you see on Cummins.
    Taking a 90 degree bend, cutting it in half from the side. One side will be in the back the other will be in front. I'll then cut a tube down the middle to connect both ends. This way my inlet will be at the front of the motor. Plan is to attach a Dodge 6.7 the throttle valve delete with a grid heater so I can still have the heater.
    mrlee and Nickel like this.
  10. Jan 21, 2017 at 4:46 PM
    #90
    steed
    Steed
    Tacoma
    Starting to work on the intake. The intake is getting milled off and this is going to bolt right to it, I'm planning on putting a grid heater to the front of the intake.
  11. Feb 25, 2017 at 3:16 PM
    #91
    steed
    Steed
    Tacoma
    Alright guys i got the short block back last night from Advanced Cylinder Heads in winterpark Florida. Pretty cool company if anyone needs work.
    I started putting everything together as soon as i got home. Still have a ton of work before i can test fire it.
    Torspd, 4Running Daily, randd and 3 others like this.
  12. Feb 25, 2017 at 3:38 PM
    #92
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Oh yeah.
  13. Feb 25, 2017 at 3:46 PM
    #93
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    As a former oil burner, all I can say is :thumbsup:
  14. Feb 27, 2017 at 3:48 PM
    #94
    steed
    Steed
    Tacoma
    Heres the build specs so far
    ISB 3.9 block and head
    4BT crank
    Colt stage 5 cam...
    2006 Dodge C/R pistons w fly cuts
    12 valve rods
    6.7 oil pump, gear case, rear main seal and CP3
    modified 6.7 cam gear, oil pan and pick up tube.
    B.A.E exhaust header
    Dual rate valve springs
    GT3571KLVN (Variable Nozzle Turbo) High pressure
    HE300VG (Variable Geometry Turbo) Low pressure
    Banshee VGT controller
    8 piston oil coolers, 4 j-hook, 4 on the crank
    APR head studs
  15. Feb 27, 2017 at 4:29 PM
    #95
    Buccaneerbandit
    Buccaneerbandit Member
    Ray
    2015 Black prerunner
    Just Found your thread. WOW cant wait to see this monster come to life.
  16. Apr 7, 2017 at 5:18 PM
    #96
    steed
    Steed
    Tacoma
    Alittle more progress. I got the ECU mounted and I decided on using the Dodge 6.7 oil filter mount. It just barley clears.
    randd and G.T. like this.
  17. Apr 7, 2017 at 5:59 PM
    #97
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    HOLD ON!!! That thing comes set up with twins?!!! :yes::thumbsup:
    randd and steed[OP] like this.
  18. Jun 20, 2017 at 12:48 PM
    #98
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Stop teasing already it's been like 2 months! I need an update already!
    randd likes this.
  19. Jul 15, 2017 at 7:32 AM
    #99
    steed
    Steed
    Tacoma
    I moved back home to Colorado and got sent to the national training center as soon as I went back to work. I ordered a ton of part's so if it works out I'll start test firing the engine by the end of August.
    I also ordered the 68RFE 6 speed automatic from a Dodge 6.7 and a Dana 60 from a Ford. So by the end of next week I'll have all the major parts. Just need to get the engine running then swap he axles and get the transmission rebuilt and I can start on the truck.
    Nickel, G.T. and Murphinator like this.
  20. Oct 5, 2017 at 6:59 PM
    #100
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
