2011 Flatbed Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2014.
  1. Nov 4, 2014 at 11:47 AM
    #261
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    For reference this is what I was thinking.
  2. Nov 4, 2014 at 11:49 AM
    #262
    drc42
    drc42 Member
    Doug
    New Hampshire
    2015 TRD Off-Road
    Keep in mind you may want something the hook end of a tie down strap will fit around or possibly a bungee cord for small stuff. So I suspect you will want some sort of a tiedown loop there. Something as simple as some small footman loop on the inside of the rails wouldn't get in the way and would allow for lots of tiedown options.
  3. Nov 4, 2014 at 12:33 PM
    #263
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  4. Nov 4, 2014 at 8:54 PM
    #264
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    :oldglory: coming along good
  5. Nov 5, 2014 at 4:13 AM
    #265
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Oh I'm sure its been done!
    Of course I was thinking one would replace the bolts...
  6. Nov 5, 2014 at 5:25 AM
    #266
    Luke01
    Luke01 Well-Known Member
    Luke
    Dallas, TX
    2012 Tacoma DCSB MGM lifted dented and armored
    Grillcraft Grill, Leer 100q top, 5100's on four corners, OME 885x up front, OME Dakars with add a leaf in rear, Lighting, a mix of Rigid and Chinese LED's, US Off Road hidden winch front bumper, SOS offroad conceprs skids, and rear bumper with swing out
    this is what I was going to recommend or even just some trailer tie downs welded on the side of a rail, You could even use a large gusset with a hole in it
  7. Nov 5, 2014 at 5:34 AM
    #267
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I can cut those tie downs myself at the shop, so that's not a bad idea. The gusset with a hole is also a great idea. :thumbsup:
  8. Nov 5, 2014 at 5:54 AM
    #268
    Luke01
    Luke
    Dallas, TX
    Kind of what I was thinking
    I wish we had a shop like what you guys have down there up here in Dallas
  9. Nov 5, 2014 at 6:01 AM
    #269
    SMKYTXN
    Nathan
    Houston
    DCFB
    Search for "makerspace" or "hackerspace" in your area. You'll be surprised at what you find.
    http://dallasmakerspace.org/
  10. Nov 5, 2014 at 6:23 AM
    #270
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I'm all for the gussets with holes route.
    the ones I used for my trailer hitch have the perfect sized holes for tie-downs. since you're gusseting anyway, might as well built in your attachments points, and not have any new obstructions in or around the bed
    Good thing you can make them though, because they're on backorder
    http://www.ballisticfabrication.com/Cage-Gusset-With-Holes_p_1185.html
  11. Nov 5, 2014 at 12:52 PM
    #271
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    How do you like that releasable magnet?
  12. Nov 5, 2014 at 1:46 PM
    #272
    SMKYTXN
    Nathan
    Houston
    DCFB
    The magnets are amazing! The little one has enough pull that it will fubar a weld though. I was tacking too close to it and the wire basically spit out of the gun and didn't bond to the tube. Switched over to the right angle, which is only 90lbs of pull and did just fine.
  13. Nov 5, 2014 at 2:04 PM
    #273
    MidnightRebel07
    MidnightRebel07 If you're gonna be a bear, Be a Grizzly !
    Jerry
    Northside of Pittsburgh, Pa.
    2013 Tacoma BAJA T/X dcsb
    Ironman Foam Cell Pro suspension, Anso black headlight housings, l.e.d. headlights, black taillights, Demello steel front bumper with highlight 7" l.e.d. round lights, Diode Dynamics Amber SS3 Pro lights, Hooke Road steel rear bumper with Nighlight reverse lights, Hooke Road roof rack, Ultima Aluminum toolbox, Weathertech floor mats, EGR in channel ventshades, Snorkel, K&N air filter and cabin air filter, 265/75/16 Cooper ST Maxx, Firestone ride rite airbags, Bentrodders bed reinforcements, too many other things to remember.
    If you still have the factory in bed tie down loops you could just bolt those on the outside rails. They'll lay down fairly flat, rotate and lift up when needed. Just an idea.
  14. Nov 5, 2014 at 2:08 PM
    #274
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Awesome. I have the adjustable angle one on my x-mas list :cool:
  15. Nov 16, 2014 at 5:51 AM
    #275
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Just curious, were you able to weigh the truck before you pulled the bed then after you're done with the new flatbed? I'd imagine the flat bed is significantly heavier and was wondering if it caused the rear end to sag.
  16. Nov 16, 2014 at 7:09 AM
    #276
    SMKYTXN
    Nathan
    Houston
    DCFB
    I didn't get a before weight. I'm sure the bed will be heavier so I'll be adding an extra leaf to the Dakar's out back. If that doesn't cut it I'll get a custom leaf pack made up.
    I hope to make some progress this coming weekend. I've been out of the country for work and haven't been able to touch the bed since the last update.
  17. Nov 16, 2014 at 8:43 AM
    #277
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    I don't know about that. Having removed a bed by hand, they are significantly more heavy than they look. My truck weighs less than a stock one, and it's got crap welded all over it.
  18. Nov 17, 2014 at 6:12 PM
    #278
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    I would've never guessed it would be lighter. The stock bed is a lot of thin, former sheet metal whereas a flat bed is heavy wall tubing. But surface area probably is much higher with the oem bed, enough to make up for the heavy wall tube.
  19. Nov 17, 2014 at 6:13 PM
    #279
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Do you already have an extra lift now from the lift? Might make more sense to get a new leaf pack of needed. Either way, looks badass and I wish I had the courage to chop apart a new truck lol.
  20. Nov 17, 2014 at 11:52 PM
    #280
    SMKYTXN
    Nathan
    Houston
    DCFB
    Too bad I sold off the stock bed before getting a weight on it. Maybe I can find a set of scales after I'm all done and see where she weighs in at.
