2011 Flatbed Build
Discussion in '2nd Gen. Builds (2005-2015)' started by SMKYTXN, Sep 2, 2014.
  1. Nov 21, 2014 at 12:42 PM
    #281
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    Agreed. Thin steel metal and composite bed vs. extensive box tubing in 2.0"x.120.
  2. Nov 23, 2014 at 10:16 AM
    #282
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Plans are changing. This thing is starting to weigh too much, so I'm going to ditch the additional tube work I had planned. I'm adding a headache rack and gonna call it good. This will be a true flatbed.
    Still haven't decided on the deck or skirt material though.
    The feet are on and I've cut the gussets for them this morning. The bed is actually bolted to the truck in these pics.
    Pirhett likes this.
  3. Nov 23, 2014 at 10:56 AM
    #283
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    The tubing weighs about 3 pounds per foot. How many feet are in the build so far? 70' or so? That's 210 pounds. I would guess the bed weighs more than 300. (EDIT: The shortbed weighs 250lbs, couldn't find the info on the longbed) The sheetmetal on it doesn't weigh much, but if you look underneath the composite part there is webbing all over.
  4. Nov 23, 2014 at 11:00 AM
    #284
    BradyT88
    BradyT88 Well-Known Member
    That webbing is a bitch to cut through when you are using a 4.5" angle grinder... I ended up having to make 2 cuts on everything. One from the top and one from the bottom.
  5. Nov 23, 2014 at 11:31 AM
    #285
    SMKYTXN
    Nathan
    Houston
    DCFB
    You're pretty close at 70'. So the new bed and the stock bed are close to a wash at this point. Remember the jobox though. That damn thing weighs 200lbs by itself. So I'm up 200lbs from stock at this point.
  6. Nov 23, 2014 at 1:17 PM
    #286
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    that's really not that bad. Almost similar to someone having a bed cap on a stock Tacoma. When your jobox is full its just like the bed being full of shit with a cap on.
    Im actually pretty surprised its that lite considering how heavy duty everything is.
  7. Nov 23, 2014 at 1:26 PM
    #287
    SMKYTXN
    Nathan
    Houston
    DCFB
    I guess having the bed so concentrated makes it seem heavier. I'm planning on picking up a hoist scale to weigh the bed when I'm done with it.
    Thanks for the dose of reality, needed that.
  8. Nov 23, 2014 at 2:01 PM
    #288
    SMKYTXN
    Nathan
    Houston
    DCFB
    Well, I don't have the tube bender that I was supposed to have at this point so it may be a mute point.
    Probably going to add the headache rack and a short tube rail around the perimeter and call it good. Time to finish this thing and move on. :)
  9. Nov 23, 2014 at 5:37 PM
    #289
    Imageoguy
    Imageoguy Well-Known Member
    Gatineau, Qc, Canada
    2012 DCLB SR5
    Full OME suspension (885 front springs, Dakar leaf pack + OME shocks) + D29XL extra leaf + 3 deg. shim + RideRite airbags
  10. Nov 23, 2014 at 5:47 PM
    #290
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Moot point. :p
    There is a lot of stuff you can do without a bender. Like take a hole saw through the square tubing and slide the round tubing in for the vertical parts of your headache rack, notch the round tubing for 45' gussets, etc.
  11. Nov 23, 2014 at 5:52 PM
    #291
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    No worries keep up the great work:cheers:
  12. Nov 23, 2014 at 7:20 PM
    #292
    SMKYTXN
    Nathan
    Houston
    DCFB
    If I were to do it again I would use smaller/lighter steel for some of the cross members.
    I'm leaning towards 3/8" UHMW. It'll be strong, won't rust, and is lighter than 14gauge diamond plate. The only issue is the cost. :eek:
  13. Nov 23, 2014 at 7:27 PM
    #293
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Cutting boards. Make it modular, each section it's own cutting board. You can find them super cheap at kitchen supply stores, or Amazon.
  14. Nov 24, 2014 at 4:40 AM
    #294
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yes, the 3/8" will be thick enough for countersinking. I've used Rivnuts for attaching sheet to blind nuts before, but I'm worried about the possibility of getting moisture inside the tubing if I put a rivnut in the top of the tube. I don't know if that's really an issue, but it's something that's making me want to investigate another method of attachment.
  15. Nov 24, 2014 at 4:53 AM
    #295
    chairly55
    chairly55 Active Member
    Frank
    South Shore, Boston
    White 2013 TRD Off-Road
    35% tint, brush guard, taillight guards, 4" rugged ridge LED, tonne cover, 31" KO's, interior floor lighting, plastidip
    I love it very jealous
  16. Nov 24, 2014 at 1:58 PM
    #296
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I have 1/2" hdpe skids im testing on the truck. Super slick stuff
  17. Nov 24, 2014 at 5:23 PM
    #297
    SMKYTXN
    Nathan
    Houston
    DCFB
    HDPE is definitely slick. UHMW is less slick, but stuff will still move easily on it. My mid skid is pipe and 1" uhmw.
    Working on the feet and headache rack tonight.
  18. Nov 24, 2014 at 5:27 PM
    #298
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    I'd like to see a pic of that! I've been wanting to build one.
  19. Nov 24, 2014 at 5:40 PM
    #299
    SMKYTXN
    Nathan
    Houston
    DCFB
    Link to the build here
    Now I will say that I need to rebuild it with some quality DOM tubing. The regular black pipe that I used did it's job, but it deflected more than I would like. :D
    And now for the show stopper! At least my welds didn't break.
    Pirhett likes this.
  20. Nov 24, 2014 at 5:44 PM
    #300
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    Poop pipe is pretty soft. Even DOM will deflect quite a bit in that application. How thick is the UHMW?
