2011 front billy's installed today, rims/tires monday and tsb springs on order
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ccextra1976, Oct 22, 2010.
  1. Oct 22, 2010 at 4:52 PM
    ccextra1976
    ccextra1976 [OP] Well-Known Member
    Utah
    2011 timberland mica DC 4x4 off road
    I know worthless without pics, but I'm still moving and haven't unpacked my cam yet.
    5100's are installed and I love them! Set at 1.75 and the got the alignment perfect. They ride sweet!!! The truck does sway in turns as much and actually feels better over bumps than factory. I'm very pleased.
    Ordered 265/75-16 duratrac's and pro-comp 7028's (black) and will have them installed on Monday.
    Local dealer ordered my tsb leaf today, so those will be installed as soon as they come in. ( yes it's a 2011 and loaded down it sagged bad and hit hard on freeway) From what i understand from the tsb on the 2010's+ they replaced the bumps stops and shocks not the actual spring pack.
    pics when all is installed and I find my cam..lol
    For those that are nervous about lifting the front with 5100's DON'T be it rides awesome at the 1.75 setting
  2. Oct 22, 2010 at 5:16 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  3. Oct 22, 2010 at 5:20 PM
    JB3CK24
    JB3CK24 Return to the 36 Chambers
    Jeff
    SD, CA
    2001 4x4 TRD, 2003 BMW 330i ZHP
    That's not correct... they replace the Leafs and leave the rest alone. I know, I had mine ordered today too and are going on Tuesday.
  4. Oct 22, 2010 at 5:26 PM
    ccextra1976
    Utah
    I agree with you, i guess i worded it wrong. My dealer stated that in 11 they changed the leaf pack from the factory. The tsb stated that they "upgraded" the shocks/bump stop on the 10+'s. The regional rep actually told me over the phone that toyota created a hybrid leaf pack in 11, still 3 springs but a rate between the old ones and the replacement 4 leaf tsb pack.
  5. Oct 22, 2010 at 5:53 PM
    Eurosport
    Eurosport Well-Known Member
    he's blowing smoke up your ass, hybrid pack?
    then it wouldn't have the same part numbers as clearly showed by many on here as the old spring packs...
  6. Oct 22, 2010 at 6:25 PM
    ccextra1976
    Utah
    yep, when i showed him the part number on the spring pack, and a picture (thanks TW) of an 08 with the same part number he quit talking and told the parts guy to order the tsb leafs for me.
    It blows my mind how 15 minutes or research on the net can educate a consumer more than a "regional rep" I wonder how much they make a year??? lol
  7. Oct 22, 2010 at 7:22 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    TSB , Duratracs
    Im getting excited already!
  8. Oct 22, 2010 at 7:31 PM
    ccextra1976
    Utah
    me too...i think it will look sick with the pro-comps/duratracs
    so the dealer "warned" that the TSB springs ride horrible, how do you rate them compared to stock?
  9. Oct 22, 2010 at 8:33 PM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    I had the TSB done on my 2010 DC in August. Trucks rides stiffer and more solid in the rear. Glad I had mine done. You won't regret it.
  10. Oct 22, 2010 at 9:04 PM
    iSTIZO99
    iSTIZO99 Well-Known Member
    Jax, FL
    2010 TRD Sport 4x4 DC/SB
    I don't have the tsb done yet and when going over speed bumps it wobbles from side to side way to easily. Does stiffer and more solid mean it's also more bouncy?
  11. Oct 22, 2010 at 11:26 PM
    Thucker
    Portland, OR
    Stiff as in when you go over a bump, you just feel the bump then it stops. Whereas, before the TSB, it was Bump, bounce, bounce, stop.
  12. Oct 23, 2010 at 12:51 AM
    kauaibuilt
    kauaibuilt U no kea but AINOFEA!
    LA/SGV
    2011 DCSB
    Check out my sig...
    What dealership are you going to? Im gonna try and get my 2011 done and am deciding what dealership would give me the least hassel.
  13. Oct 23, 2010 at 12:59 AM
    JB3CK24
    Jeff
    SD, CA
    Went to Toyota of El Cajon.. they were pretty chill about it. Described that the ride was harsh when I had a load in the back and that it has touched the bump stops a few times. The guy said "let me look at service bulletins" and then said "I don't think it will fall under 2010 though... oh wait, I am a liar... here it is" and he ordered the parts and set an appointment for me to have it done Tues.. :)
  14. Oct 23, 2010 at 3:05 AM
    Hank4444
    Hank4444 Member...?
    Brian
    Daphne
    09 Sport DCSB
    Dog-Proofed Rear seat, 5100's, Rear TSB, Tranny TSB, Fog light mod, map light mod, DTRL mod, Volant CAI with ram air, UltraGauge, Blacked out emblems, extra D-rings, Bedlined front valance, Satoshi, Hella 500ff 55w HID, Dynomax Super Turbo Muffler, Leather arm rests, Weathertechs, Hankook Dynapro ATM, Oil catch can, URD MAF Calibrator, Wheelers HD AAL, Thule Roof Rack, OME 885x with Lean Spacer, RedLine Hood struts, Access LE Tonneau, LED Bedrail lights,
    +1
    Rear TSB is completely worth it.
    While you there get the tranny TSB done too, takes them about 10 minutes.
    I love the way my truck feels now. Smooth and solid.
  15. Oct 24, 2010 at 5:27 AM
    Steig
    Steig Well-Known Member
    Tacoma TRD off road
    I recently got the TSB done on my 2011 TRD Off Road. They replaced the leafs with 4 leaf springs and alignment. I already have the Billies, the bump stops do not have to be replaced on newer models according to the TSB.
    How do you raise the Billies in the front to 1.75, do the shocks have to come off, or can it be raised while on the truck. Can this be done by myself, or does a shop have to do it ? I know Truck will require an alignment.
  16. Oct 24, 2010 at 6:27 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    I' m debating on whether to get the leaf tsb done or not. The tsb will add about 1/2 inch lift, stiffen the ride and will keep the rear from sagging from heavy loads.
    Would it be silly to ask why not just add a AAL w/o the tsb? With the leaf added, that itself should keep the rear from sagging with loads while giving you more lift.
  17. Oct 24, 2010 at 11:24 AM
    ccextra1976
    Utah
    from everything I've seen here the tsb with actually lift the back 1.5", and not silly to ask I got the tsb because in my mind the truck shouldn't sag/hit from the factory. They cover the cost under warranty and the ride will be the same as an AAL.
    if you already have billy 5100's in the front (not stock billy's) then you can adjust the c-clip yourself.
  18. Oct 25, 2010 at 3:36 PM
    Steig
    Tacoma TRD off road
    Does the shock have to come of to adjust the C-Clip ?
  19. Oct 25, 2010 at 4:53 PM
    skistoy
    Western New York
    yes , have to remove collar that goes over c-clip
    basically remove shock from coil
  20. Oct 25, 2010 at 5:01 PM
    Kernel
    Kernel Well-Known Member
    Ohio
    09 TRD Off Road 6sp Manual
    5100's all 4 corners, front at .85 with Eibach Coils, Rear TSB w/AAL, TRD Catback Exhaust, AFE Pro Dry S, Duratracs, redline hood struts, maglight mod, weathertechs
    I have that exact setup minus the wheels. TSB, 5100's all 4 @ 1.75 up front & 265/75 duratracs. Sits pretty much level. You should be happy with the final outcome :thumbsup:
    Also, if you don't have 5100's on the rear, they make a big difference over stock.
