2011 not starting. no crank no click
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lilredin808, Jan 24, 2023.
  1. Jan 24, 2023 at 5:42 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    So if you leave pin 3 and 5 connected you should have voltage at the small wire of the starter when you try to start
  2. Jan 24, 2023 at 5:49 PM
    lilredin808
    lilredin808 [OP] Well-Known Member
    Update
    Even though I jump 3-5 don’t I have to jump it to 1-2. But I’ll try it. Doing it now lyk in few minutes
    HondaGM[QUOTED] likes this.
  3. Jan 24, 2023 at 5:51 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Don't jump pins 1 and 2 together, you will either blow a fuse or fry a wire.
  4. Jan 24, 2023 at 5:51 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Only 3 and 5
  5. Jan 24, 2023 at 5:55 PM
    lilredin808
    Ok just finished jumping 3-5 and checking starter like other picture with starter. ‍♂️ this truck. And no light.
  6. Jan 24, 2023 at 5:59 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    But you have power on pin 5 when you turn the switch right?
  7. Jan 24, 2023 at 5:59 PM
    Accipiter13
    Accipiter13 Well-Known Member
    California
    '11 DCLB 4x4 Sport
    No lights - no click, no crank?
    I had the same problem last year.
    Alternator killed the battery - new alternator fixed it up and zero issues since.
    Dm93 likes this.
  8. Jan 24, 2023 at 6:02 PM
    lilredin808
    Yes I even got a starter relay from my car that’s running and swapped it and still no start.
  9. Jan 24, 2023 at 6:04 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    This would be good to know, we are here assuming the battery is good but not sure it the OP has checked battery voltage.
    airmax233, TXpro4X4 and HondaGM like this.
  10. Jan 24, 2023 at 6:05 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    so if there’s power on pin 5 when you turn the switch…and you connect 3 and 5 together and you don’t have voltage at the starter the wire is broke somewhere from pin 3 to the starter
  11. Jan 24, 2023 at 6:06 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    I’m assuming also…he said he jumped it and replaced the battery in his first post..
    lilredin808[OP] likes this.
  12. Jan 24, 2023 at 6:07 PM
    lilredin808
    Update checked battery and it’s good. checked am1-2
    Starter relay good
    Checked power to starter good
    Possible problem could it be the ignition switch
    HondaGM likes this.
  13. Jan 24, 2023 at 6:08 PM
    lilredin808
    Yeah went to autozone to check it and they said it was fully charged
  14. Jan 24, 2023 at 6:09 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    If your getting power to pin 5 the switch is good
  15. Jan 24, 2023 at 6:12 PM
    #35
    lilredin808
    thanks man. Appreciate everything it’s getting kind of late now. But if anyone has any ideas lmk. Please worst comes to worst just might have to take it to the dealer.
  16. Jan 24, 2023 at 6:15 PM
    #36
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok so let's recap.
    Have you verified your test light works before each test?
    Test light ground connected to battery Negative and the tip on Pin 1 of the starter relay connector, does it light with the key in the crank position?
    Test light ground connected to battery Positive does it light when you touch the tip to Pin 2 of the starter relay connector?
    Test light ground connected to battery Negative and the tip on Pin 5 of the starter relay connector, does it light with the key in the crank position?
    Test light connected to battery Positive and starter plugged in, does it light when you touch the tip to Pin 3 of the starter relay connector?
  17. Jan 24, 2023 at 6:28 PM
    #37
    lilredin808
    Negative pin 1 no light
    Positive pin 2 lights
    negative pin 5 lights
    Positive pin 3 lights
  18. Jan 24, 2023 at 6:29 PM
    #38
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Yes read the first post he even replaced the battery. I had to edit my post because of that lol
  19. Jan 24, 2023 at 6:38 PM
    #39
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting, it should crank then if you put a jumper wire between 3 and 5 and turn the key to crank.
    I'm assuming you verified the STA Fuse is good and has power on both sides with the key in the crank position?
    Pin 1 comes from the Park/Neutral Position switch, you can backprobe pin 5 (Black/Yellow) at the Park/Neutral Switch and check for power there with the key in the crank position. If you have nothing do the same test at Pin 4 (Violet).
    What were the events that led up to this no-crank?
  20. Jan 24, 2023 at 6:40 PM
    #40
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Starter is bad?
