2011 not starting. no crank no click
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lilredin808, Jan 24, 2023.
  1. Jan 25, 2023 at 10:26 AM
    #61
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    with the starter wire off..Put power on pin 3....then check if the test lights up at the starter
    12TRDTacoma and TnShooter like this.
  2. Jan 25, 2023 at 10:31 AM
    #62
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m throughly confused.
    As the test results you posted previously, have you showing power to pin 5.
    And now, Nothing?
    12TRDTacoma and HondaGM like this.
  3. Jan 25, 2023 at 10:34 AM
    #63
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Im confused now....hes driving me monke nutz
  4. Jan 25, 2023 at 10:48 AM
    #64
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Has this truck been in any sort of wreck OP? That can always turn diagnosing into a nightmare.
    TnShooter likes this.
  5. Jan 25, 2023 at 10:51 AM
    #65
    lilredin808
    lilredin808 [OP] Well-Known Member
    Sorry but I’m at work. And trying to remember from what I did yesterday. And trying to answer all ur questions the best I can. I lyk when I get home I don’t mind doing everything over again. Because I know u guys are trying to help.
  6. Jan 25, 2023 at 10:52 AM
    #66
    lilredin808
    What does op mean.
    HondaGM likes this.
  7. Jan 25, 2023 at 10:53 AM
    #67
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Original Poster
  8. Jan 25, 2023 at 10:53 AM
    #68
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Your the OP....when you turn the key on..do the lights come on the dash?
    12TRDTacoma likes this.
  9. Jan 25, 2023 at 11:01 AM
    #69
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Check all the grounds maybe? I haven't seen that mentioned, but tests show that at least some grounds appear to be good, at least good enough to get a test light to turn on.
  10. Jan 25, 2023 at 11:02 AM
    #70
    lilredin808
    No. The truck never been in a wreck. My brother is the original owner. He neglects his truck until it’s needs fixing. Idk how often he up keeps his car. But I checked out and coolant looks fine.
    12TRDTacoma[QUOTED] likes this.
  11. Jan 25, 2023 at 11:02 AM
    #71
    TnShooter
    Deogee
    STOCK
    We need to confirm power to Pin # 5 when cranking to go any further.
    I suppose doing as @HondaGM said, and jumping power directly to pin 3 is an option.
    But, if it works, we’re back to pin 5.
    If jumping power to pin 3 as @HondaGM said, results in NO power to the smaller wire on the starter.
    We’re going to need to look at the EB1 connector. But we are getting way ahead of ourselves at this point.
    SR-71A, 12TRDTacoma and HondaGM like this.
  12. Jan 25, 2023 at 11:03 AM
    #72
    lilredin808
    We do when I get home
  13. Jan 25, 2023 at 11:04 AM
    #73
    lilredin808
    Ok will do when I get home
  14. Jan 25, 2023 at 11:05 AM
    #74
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Steves104x4 likes this.
  15. Jan 25, 2023 at 11:06 AM
    #75
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't disagree with what he has to check but what he should do before that is check alt 120/ 140 fuse before anything because he did mention he hasn't checked it and if that's smoked of course relays won't get the powers they need when they need them.
    Based on the way his brother described his truck lost power and then wouldn't crank after he shut it off indicates to me that he is having an alternator circuit causing issue at the root of this headache.
  16. Jan 25, 2023 at 11:06 AM
    #76
    TnShooter
    Deogee
    STOCK
    I know it sounds redundant.
    But check power to pin 5 - Again.
    This shouldn’t be too hard to diagnose.
    I believe we are are all lost in confusion at the moment.
    I say, we start fresh.
    1 step at a time. I’ll keep an eye on this thread.
    Let’s go step by step.
  17. Jan 25, 2023 at 11:09 AM
    #77
    lilredin808
    The alternator was replaced within the past 6 months. And I will check the fuse when I get home.
    HondaGM likes this.
  18. Jan 25, 2023 at 11:09 AM
    #78
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Does the large starter wire have power? There are two wires one big one and a smaller one. A jumper between the two should crank the engine key on or off. If it does back to the small wires. Leave the key off for this test so if it does start it won't run over you.
  19. Jan 25, 2023 at 11:10 AM
    #79
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  20. Jan 25, 2023 at 11:11 AM
    #80
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I agree. Sometimes it is good to reset and start all over again because it's too easy to get wrapped up in the complex nature of diagnosing when the issue is staring at you right in the face.
    I'm not necessarily concerned about the physical alternator yet. Just the fuse for it and every other fuse tied to the starting/ charging circuits given how it went from losing power to suddenly not even wanting to crank at all.
    TnShooter[QUOTED] and HondaGM like this.
