2011 not starting. no crank no click
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lilredin808, Jan 24, 2023.
  1. Jan 25, 2023 at 11:12 AM
    #81
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Agreed.
    That fuse is bolted in. (Harder to check)
    I’d start with checking power to the STA fuse. (It’s fed from the 140A alt fuse).
    But the no power to pin 5 is odd, it is BEFORE the the 140a fuse.
  2. Jan 25, 2023 at 11:13 AM
    #82
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Agreed ....I dont know which way to peel my Banana right now
  3. Jan 25, 2023 at 11:13 AM
    #83
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This right here.
    I had a no start issue after doing some radio work once which was tied to one of the accessory/ radio fuses. It sounds stupid, but it is something that we should know whether functional or non operational at the moment as well.
    HondaGM and TnShooter like this.
  4. Jan 25, 2023 at 11:14 AM
    #84
    TnShooter
    Deogee
    STOCK
    Me too neither..:rofl:
    12TRDTacoma and HondaGM[QUOTED] like this.
  5. Jan 25, 2023 at 11:16 AM
    #85
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The best way to peel the banana is one flap at a time. :D :laugh:
    Time for all of you including the OP to reset your bearings and start over.
    HondaGM[QUOTED] likes this.
  6. Jan 25, 2023 at 11:44 AM
    #86
    TnShooter
    Deogee
    STOCK
    When all else fails. I usually open the hood. Then take a 10mm, 12mm and 14mm wrench and throw them in the engine bay. Close the hood and hope the problem fixes itself.
    It’s never worked. But man can hope. A little bit hope and lots of luck can go a long ways. :rofl:
    HondaGM and 12TRDTacoma[QUOTED] like this.
  7. Jan 25, 2023 at 11:53 AM
    #87
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    So, just tell me to shut up if this is stupid thinking, but a lot of stuff is grounded through the chassis, and that ground might be good (some of these tests may be going through a chassis ground?). The starter is grounded through the block, and that ground may have come loose? Anyway, it seems like a lot of stuff has been checked and looks OK, but still no joy.
    HondaGM and 12TRDTacoma like this.
  8. Jan 25, 2023 at 11:57 AM
    #88
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just walk away sometimes for a while on the serious. Lol. This issue shouldn't be hard to trace down, but he needs to attack things in a tiered order because from what I've seen, things are too all over the place the way they have been checked right now.
    - Battery
    - Fuses
    - Relays
    - then you move onto checking for appropriate powers and grounds at their respective connection points on the parts
    - doesn't check out good? You may have an issue at a junction connector or a break/ short in wiring somewhere in between all the connection points and closer inspection of wiring will be needed.
    - all of the above check out good? You probably have failing hard parts then.
    Anybody who does their own inspecting and diagnosing needs a power probe. OP could have easily applied power direct from the battery to the starter signal pin and see if the starter would begin turning the engine over. That would eliminate the starter itself from being a dud. It would also allow him to see if when the key is being cranked, the signal at the wire connected to the starter changes from ground to hot right then and there.
    I'm a power probe whore. It just eliminates all the guess work and is such a no frills, easy to use tool. :)
  9. Jan 25, 2023 at 11:57 AM
    #89
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Just throwing 10mm sockets around? He got moneeeyyyyyy
  10. Jan 25, 2023 at 4:27 PM
    #90
    lilredin808
    lilredin808 [OP] Well-Known Member
    Ok got home now going to start by checking ALL the fuses under the steering column and under the hood.
    Then do the 1-2-3-5 pins and check the power to the starter
    idk if this is a problem but the remote for the truck doesn’t work for the last two months. I was told by my brother he was driving the truck fine without it. whenthe truck door closes the antitheft is flashing but disappear when I put in the key. I just figured to tell u guys. So we are not wasting time. And frustration
    TnShooter likes this.
  11. Jan 25, 2023 at 4:32 PM
    #91
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Unless there is an aftermarket security/remote start system installed the remote has zero to do with the starting system, same with the factory security it only disables fuel not the starter.
  12. Jan 25, 2023 at 4:44 PM
    #92
    lilredin808
    No aftermarket just bone stock
  13. Jan 25, 2023 at 4:51 PM
    #93
    lilredin808
    Neg to pin1 crank with no light
    Pos pin 2 lights no crank
    Neg pin 5 crank lights up
    Pos pin 3 lights no crank
    Jumped 3-5 started to crank and when I put sta relay in doesn’t want to crank
  14. Jan 25, 2023 at 4:52 PM
    #94
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So the engine turns over with Pins 3 and 5 jumped together but not with the relay installed?
  15. Jan 25, 2023 at 4:54 PM
    #95
    lilredin808
    Yes
    I checked both relay with my car and started right up with both relays
  16. Jan 25, 2023 at 4:54 PM
    #96
    TnShooter
    Deogee
    STOCK
    We need to focus on this.
    airmax233 and b_r_o like this.
  17. Jan 25, 2023 at 4:55 PM
    #97
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok now we're getting somewhere, did you verify the STA Fuse was good and had power on both sides with the key in the crank position?
  18. Jan 25, 2023 at 5:03 PM
    #98
    lilredin808
    Sta relay should be good because checked it with my car sta relay both of them.
    But when I installed both of the and tested the starter there was no light.
  19. Jan 25, 2023 at 5:04 PM
    #99
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    We know that but we are missing the control voltage, that's why I'm trying to get you to check the STA Fuse so we know which direction to go.
    12TRDTacoma and TnShooter like this.
  20. Jan 25, 2023 at 5:04 PM
    #100
    lilredin808
    Should I just buy a new sta relay
