2011 Passenger seat belt tension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeniorSpan, Jan 5, 2011.
  1. Jan 5, 2011 at 7:29 AM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    11 Silver 4wd TRD DC TXpro
    G'day all,
    The passenger seat belt on my 2011 4x4 DC SB (560 miles to date), when not in use, bangs against the door up right when going over slight bumps. The belts on my 2004 had much more tension on them when on in use than the 2011 and did not exhibit the same characteristics until I got off road.
    So, to the question: is increasing the tension on the seat belts a dealer issue or can I jump in with wrenches in hand a tackle this one by my self?
    Cheers
    Bob
  2. Jan 5, 2011 at 7:34 AM
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Although I don't have a DC, I had the same problem with mine. Here's what I did...
  3. Jan 5, 2011 at 7:38 AM
    Falcon86
    Falcon86 Well-Known Member
    Virginia Beachshire
    Bone-stock
    LOL I've got the same dang problem! I constantly reach over and try to wrap it around the passenger seat. Gotta find something to "deaden" the sound or maybe glue some felt to the back of it. Drives me bonkers for sure...
  4. Jan 5, 2011 at 7:41 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Try this....
    Got tired of the buckle banging on the hard plastic on rough roads.
    Sticky-backed felt pad cut to size from Home Depot.
    [​IMG] Seat Belt Buckle Pad
    These are used to put under furniture.
  5. Jan 5, 2011 at 7:54 AM
    Falcon86
    Virginia Beachshire
    Bone-stock
    ^Awesome. Definitely doing in this weekend, thanks mang!
  6. Jan 5, 2011 at 7:58 AM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    '10 TRD SPORT Acc.Cab Mag Grey 4x4 Auto
    Weathertech floor liners, stone and bug deflector, Putco Element In Channel Window Visors, Viper remote starter, Harley lighted hitch cover, Herculeze front mudflap, Metal Miller Harley Grill Emblem, SockMonkey design Bedside Decals and 3rd Brake light TRD decal, K&N Air Filter, Goodyear Duratrac 265/70/17 C load, Valor Exhaust tip, De-badged tailgate, Advantage Tonneau Cover, Tacoma bedmat, Bicycle Mount Rail mounts, Custom Ipod holder. Stock Suspension :( (winter wheels: 2014 16" stock steel wheels plastidipped black with general arctics 265/75/16)
    thats hilarious. I did the same thing. It was worse in my other Tacoma.
    Those pads dont dampen the sound too well. You can pull those pads out and add material to it, and put it back in. I used non slip shelf liner.
  7. Jan 5, 2011 at 8:47 AM
    SeniorSpan
    Bob
    Colorado Springs
    Thanks,
    I had thought of the velcro fix but was wondering if the tension adjustment was a quick process allowing me to avoid gluing velcro strips to the cab and seat belt.
    Will ask the dealer when I check on the rear spring TSB.
    Cheers
    Bob
  8. Jan 5, 2011 at 8:58 AM
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
  9. Jan 5, 2011 at 9:03 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    Keep in mind the seatbelt height adjustment when fastening the cushion.
  10. Jan 5, 2011 at 11:33 AM
    SeniorSpan
    Bob
    Colorado Springs
    Talked the service rep at Liberty Toyota, Colorado Springs. There's absolutely no tension adjustment on the seat belt retractor. Seems there are electrical servos now connected for additional safety. So it looks like velcro. Thanks for the inputs.
    Cheers
    Bob
