2011 pressure ratings door to tire ??
Discussion in 'Wheels & Tires' started by scgunslinger, Dec 27, 2010.
  1. Dec 27, 2010 at 1:08 PM
    scgunslinger
    scgunslinger [OP] Well-Known Member
    SC
    11 taco 4x4 2.7 man trans
    bone stock
    Have a new 2011 Taco 4cyl reg cab man trans. The door tag says 30psi cold thats the only psi given. The tires say 51 psi cold at a given weight. What the heck ? Have the tires been changed ? Yes its brand new.
  2. Dec 27, 2010 at 1:15 PM
    cc350
    cc350 Retired Member
    Door tag is Toyotas psi(what you air tires to). tires psi is a max rating for tire.
  3. Dec 29, 2010 at 5:14 AM
    scgunslinger
    SC
    bone stock
    Does that mean you can run 30psi in these tires that say 51psi max. That seems like the tire would be running to low. 21lbs difference ?:confused: I always thought you should set the tires close to the pressure rating on the sidewall ? You would think it would give a min pressure rating as well for no load conditions. Heck if I know Im going to run 40 at no load for now and watch tread ware.
  4. Dec 29, 2010 at 5:20 AM
    tacoriffic
    tacoriffic Well-Known Member
    Greg
    Rhode Island
    Clarion CX609 HU, Satoshi Grill, More to come
    I run mine at about 28 to 29, even though the door says 30. If I have them at 30 the truck is all over the road at 65mph. I noticed the taking out that one pound makes a big difference.
  5. Dec 29, 2010 at 5:26 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    The tire pressure on the tire is the max pressure the tire can handle at the max load the tire is rated for. Your truck isn't anywhere near that weight. Go by the pressure on the door as a starting point and do the chaulk test to find the optimum pressure (it'll be close to what's listed on the door for daily driving unless you're fully loaded all day every day). The chaulk test entails drawing a line of chaulk across the tire, driving about a mile or two, then inspecting the line you drew. If it's worn on the center and not the edges, you have too much pressure and visa versa. I run 30-32 psi in mine (265/65R17).
  6. Dec 29, 2010 at 1:16 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I run the tire pressure that toyota recommends. Like Pugga said the tire will show the max pressure on the sidewall. Your truck is fairly lightweight so your won't need to max out the pressure. Only time i run more than 30/32 is when im hauling my trailer or have my quad in the bed.
