2011: SEAT BELT BEEP DISABLE
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JonJonXD, Aug 24, 2011.
  1. Aug 24, 2011 at 10:01 PM
    JonJonXD
    JonJonXD [OP] Active Member
    PA
    2011 PreRunner SR5 V6
    I'm about to drive this truck into a wall.
    Anyone know how to disable it?
  2. Aug 25, 2011 at 3:28 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    There are 2 or 3 threads about this already.
    Just ask the dealer to turn it off.
  3. Aug 25, 2011 at 3:30 PM
    upnadam
    upnadam Well-Known Member
    Adam
    Wilmington, NC
    11 PreRunner TRD Sport LB
    5100's up front, TSB, tinted windows, tail gate theft deterrent mod, fog lights anytime, de-badged, 7 pin relocate, AFE dry, Magnaflow
  4. Aug 25, 2011 at 3:37 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    ^ This.
    From the Pennsylvania DMV:
    SEAT BELT LAW
    In accordance with Section 4581 of the Pennsylvania Vehicle Code, it is a law in Pennsylvania that:
    • All drivers and front seat passengers in vehicles, light trucks and motor homes must wear seat belts.
    • If you are transporting passengers age eight (8) or older but less than age 18, they must wear seat belts,
    no matter where they are riding in the vehicle.
    • If you are a driver under the age of 18, the number of passengers may not exceed the number of seat belts
    in the vehicle.
    YOU ARE REQUIRED BY LAW TO BUCKLE UP. It makes good sense to wear your seat belt.
    Many people believe they would be able to use their arms and legs to stop themselves from hitting the vehicle's
    surfaces in a crash, but they are wrong. In a collision, your vehicle stops, but your body keeps moving at the same
    speed you were traveling until it hits the instrument panel or windshield. In most crashes, the bodies of the
    passengers and drivers hit the vehicle's interior surfaces with several tons of force. This will shatter even the
    strongest arms and legs. At 30 mph, this is like hitting the ground from the top of a three-story building. This is why
    you cannot catch yourself with your arms. A driver or passenger who is not buckled up, can be killed on impact
    even when the vehicle is traveling as slowly as 12 mph.
    Only seat belts can safely slow your body. You have only 1/50th of a second to stop your body after the vehicle
    crashes. Arms and legs do not work that quickly, but seat belts do. Seat belts slow your body down far more gently
    than a hard instrument panel, steering wheel or windshield does. During a crash, fastened seat belts distribute the
    forces of rapid deceleration over larger and stronger parts of your body such as the chest, hips and shoulders. Air
    bags provide an even greater "ride down" benefit. However, even with an air bag present, a seat belt must be worn.
    Seat belts also keep you inside of your vehicle. Your chances of being killed are almost 25 times greater if you are
    thrown from your vehicle. Being thrown clear usually means going through the windshield and then landing
    somewhere - hard. The forces in a collision can be great enough to fling you as much as 150 feet (about 15 vehicle
    lengths). If you land in the street, there is always the chance of being run over while you lie there. Four (4) out of
    every five (5) people who were killed by being thrown clear would have lived, if they had been able to stay inside
    the vehicle.
    Seat belts and air bags save lives. They work best when everyone is buckled and children are properly restrained
    in the back seat.
  5. Aug 25, 2011 at 3:41 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    there is a plug under the seat at the latch side that will disable it
    i for one dont need a stupid chime to tell me when to put on the seatbelt, i always wear it on the street but there are times when its not necessary...
  6. Aug 25, 2011 at 3:43 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    ummmm wear your seat belt and no chime
  7. Aug 25, 2011 at 4:24 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
  8. Aug 25, 2011 at 10:17 PM
    JonJonXD
    PA
    Save me the "click it or ticket" BS. In PA, seatbelt citations are secondary infractions. You can NOT be pulled over or fined for failure to wear a seatbelt in PA.
    I've already been in two accidents (not driver) where if I had my seatbelt on, I would have been killed. (drown and burned)
    Thanks for the other replies, I'm a big boy, I don't need the government to tell me how to live my life.
    yote, B1GRED and Drainbung like this.
  9. Aug 25, 2011 at 10:23 PM
    Bgwood88
    Bgwood88 Thats what she said..
    Tennessee
    2011 Reg Cab 4x4
    Agreed!!! Well said.
  10. Oct 10, 2011 at 4:32 PM
    Gagger11
    Gagger11 New Member
    R
    Pittsburgh Pa
    2011 Taco 4 cyl
    It's interesting to see that so many idiots wanna tell you about wearing your seat belt. I also would like to disable this annoying fu**ing thing. I would have never bought this truck if I had known about the seat belt beeper. If I set anything on the passanger seat that weighs more than a piece of paper, it sets off this thing. I also get in and out of my truck alot after traveling only a few feet, it's not practical to put it on all of the time. There's a time and place for seat belt's, as an adult - I know when it is.
  11. Nov 25, 2011 at 11:50 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    I did the following for my 2011.Worked like a charm.Was posted by Chobee....Thanks.
    1)Turn the vehicle `ON`, But do not start the engine.(Leave your foot off brake).Cycle your trip reset knob until it reads ODO.Turn the ignition back off.Wait a couple of seconds. 2)Make sure seat belt is not fastened. 3)Turn the ignition back on,Do not start the car(Leave foot off brafe) AS SOON as you see everything light up, press and hold the trip reset knob and do a long 12 second count. 4)KEEP your finger on the trip reset knob. Fasten your seat belt,, AS soon as you fasten your seat belt you should see the ODO display go from xxxxmiles to 'b-on'.At that time take your finger off of the trip reset knob and press it again.It should NOW cycle to 'b-off'. You should be all set and turn the ignition off and unfasten your seat belt.
  12. Nov 26, 2011 at 8:55 AM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    Thanks for this, it DID work like a charm!
  13. Nov 26, 2011 at 10:06 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Is this with the "White" gauges?
  14. Nov 27, 2011 at 6:03 AM
    JonJonXD
    PA
    Yes. White gauges
    Instructions don't work
  15. Nov 27, 2011 at 7:46 AM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    I have white gauges and I couldn't get it to work. Though it was a complicated process and I only tried once. I am going to try again today.
  16. Nov 27, 2011 at 2:40 PM
    Flyfisher22
    Flyfisher22 Well-Known Member
    Cameron
    Indian Trail, NC
    2011 Off Road Package DC
    None
    If you have the white gauges it won't work. I had my dealer turn it off last time I was there.
    Cam
  17. Nov 27, 2011 at 2:59 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    That logic will catch up with you one day. I agree that you're a "big boy" and can make your own decisions, but don't try to dispute safety facts by referencing the low percentage times a safety belt could do more harm. Especially when you're assuming that you 100% wouldn't have been able to remove the belt.
  18. Nov 27, 2011 at 3:11 PM
    matts11
    matts11 Well-Known Member
    TN
    I dare you to try just that without your belt on. Although you claim to have been in two wrecks where you would have burned or drowned without your belt (how do you know you could not have just taken the belt off?) do some research on safety. Here is what the wreck I was in where a seatbelt SAVED MY LIFE looked like. T-boned by a drunk driver on a Sunday afternoon. I am not trying to be a douche but without my belt I would have been dead or a quadriplegic.
  19. Nov 27, 2011 at 3:15 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Glad to hear you're alive!!! ^^^
    All else is derp.
  20. Nov 27, 2011 at 3:30 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    damn man! i see KPD tho. lol.
    i always wear mine on the road. but some times i stop and get the mail and my drive way is kinda long. like 150 maybe 200 yards long and up hill. or i have to go to the barn thats a good 100 to 150 yards from the house.
    my truck does not peep at all when i have it off.
    DarkPath likes this.
