2011 Signal Flashers are 12 pin?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sledneck, Jun 5, 2011.
  1. Jun 5, 2011 at 10:35 AM
    sledneck
    sledneck [OP] Active Member
    Northern Maine
    2011 TRD Sport DC
    MBRP Stainless Duels, AFE CAI Stafe 2, lBilstein 5100's, 886's, smittybuilt Nerf Bars, UWS box, 6000K HID's, Grillcraft grille, Switchback LED signals and DTRL's, 20% tint,
    I recently put switchback LED's up front and LED's in the reay turn signals. Other posts have the LED signal flasher as a 8 pin CF 18ALT but when I took mine apart on my 2011 TRD Sport it is a 12 PIN flasher. Does anyone know if it is different because it is a TRD or because it is a 2011? Also, if anyone can give me direction on where to get a 12 pin that fits my application to fix hyperflash it will be greatly appreciated.
    Thanks
  2. Jun 5, 2011 at 1:39 PM
    sledneck
    Northern Maine
    2011 TRD Sport DC
    After some more research I found out that the 8 pin flasher is for non-drl and the 12 pin flasher is for trucks equipt with DRL. If anyone knows where I can get a 12 pin DRL LED flasher that would be great!
    P.Escobar likes this.
  3. Feb 8, 2017 at 6:27 PM
    P.Escobar
    P.Escobar Member
    Ventura,CA
    2008 Silver Tacoma TRD Off Road 4x2
    Where you able to find the 12 pin l.e.d flasher? I have the same problem.
  4. Feb 8, 2017 at 6:58 PM
    jbrnigan
    jbrnigan Well-Known Member
    USA
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    I never found a 12 pin LED compatible flasher and ended up using resistors - good luck
  5. Feb 8, 2017 at 6:59 PM
    P.Escobar
    P.Escobar Member
    Ventura,CA
    Thank you.
