2011 Squeaky brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BG KY Jets Fan, Apr 21, 2012.
  1. Apr 21, 2012 at 7:39 PM
    BG KY Jets Fan
    BG KY Jets Fan [OP] Dagger Taco *****
    Joe
    Bowling Green Ky
    2011 TRD Sport 2WD DC
    Roof Rack, TRD skid plate, TRD cat back exhaust, Pioneer AVIC-930BT, subwoofers, Avid bar, Westin side steps, FLYZEYE strip, and Blacked out Badges. More to come....
    I have 32,000 miles on my 2011 Taco. My brakes squeak bad right at the point of stopping. Last oil change I did, I told the dealership to check them out. They said my brake pads are at 90% and great, they are just aftermarket pads?! They went on to say that aftermarket pads will squeak and if I want some FACTORY brand pads they would put them on for a fee?! :mad:Huh?! Anyone else have this issue
  2. Apr 21, 2012 at 7:43 PM
    nut
    nut she'll ride
    Patrick
    Eustis, FL
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    happened to my 2012 with 3,000 miles, have them scuff up the drums/rotors/pads. they did mine for free. i can put up a copy of the service ticket so you can show them it was warranty work for free. i have over 12k now, still silent :)
  3. Apr 21, 2012 at 7:45 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Did you put in after market pads? sounds like you didnt know that they were there. If you didn't, the stealership is trying to jack you.
  4. Apr 21, 2012 at 7:59 PM
    BG KY Jets Fan
    Joe
    Bowling Green Ky
    Its the pads that came with the truck when I bought it last year. I'm getting screwed right?
  5. Apr 21, 2012 at 8:46 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Mine sound the same at 8000 miles
  6. Apr 21, 2012 at 9:10 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) There may be some extra information needed from you to help with making some helpful advice. Did you buy your truck new or used ? Why does it have aftermarket pads with only 32 K on the truck ? Most aftermarket pads that are not the top of the models, may require some form of assistance in sound control. That is a fancy way to say you may need some modifcation to your brake pads to keep them from squeeking. Appling anti-squeal paste to the backs of your pads usually stops most pad squeeks.
    Do you drive hard and brake hard every time you go out with your Taco ? Where have you been with your Truck, hauling a heavy load or driving down a mountain and riding your brakes ? These are a lot of questions that will help provide a correct answer to your complaint. Good Luck.
  7. Apr 21, 2012 at 10:31 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    All that needs done is pull the pads and use some brake grease. The dealer should be more than willing to this. If they dont, dont worry should only take you 20 mins.
  8. May 13, 2012 at 4:27 PM
    Heykoolaid3
    Heykoolaid3 New Member
    Phoenix
    2011 TRD Sport
    U have a 2011 with 16k miles and my rear brakes squeak. I'm going to take it in and see what they say..
  9. Jun 1, 2013 at 5:40 PM
    helomech
    helomech Active Member
    Bryan
    San Diego, CA
    '10 4wd TRD Sport DC LB
    20% Tint on all windows
    I'm in the same boat. I have just under 40k miles on my taco and just put new fronts on today....turns out it wasn't the issue, it was the rears. Just got new rear shoes and intend on ripping it apart tomorrow. Very aggriavating. Never had rear brake shoes squeal at just 40k miles.
  10. Jun 2, 2013 at 4:36 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Curious to know if your brakes are worn out at 40k since my 2010 DCLB 2wd just started whining also at 32k miles.
    If I wore out a set of drum brakes on the back in that short of distance, I have set a new personal best by a large margin.
    PK
