2011 SR5 4x4 front axle (non TRD)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Apr 8, 2011.
  1. Apr 8, 2011 at 3:58 AM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    This has probably been discussed already. In 4wd low is the front axle auto LSD or is only one front wheel powered. Thanks
  2. Apr 8, 2011 at 4:00 AM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    No LSD, it is an open diff, so if one wheel is off the ground it will spin free in 4 low.
    Unless you do the yellow wire mod, in that case it will act as if it were in 4 hi and TRAC will kick in.
  3. Apr 8, 2011 at 12:34 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Thanks brother. Have to look into detroit and see if they make a trutrac for the front.
  4. Apr 8, 2011 at 2:09 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    will that work if I just have the sr5 4x4 and not the trd (I do not have atrac)
  5. Apr 8, 2011 at 2:21 PM
    bizjettech
    bizjettech Well-Known Member
    San Antonio, TX
    2013 MGM DCSB 4x4 TRD OR
    undercover flex bed cover
    sounds interesting, what exactly is being done when the "yellow wire" mod is done?
  6. Apr 8, 2011 at 2:27 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    X2
  7. Apr 8, 2011 at 7:08 PM
    StandingCow
    NJ
    Yep, and a good number of people have been running it now with no negative consequences.
  8. Apr 9, 2011 at 1:58 AM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    big help brother - thanks
  9. Apr 9, 2011 at 4:12 AM
    StandingCow
    NJ
    I keep meaning to do the mod, it is a simple cutting of a wire... but I am just waiting for my first warranty to expire (no idea why)...
