2011 suffers from rear Suspension TSB problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dan0, Mar 30, 2011.
  1. Mar 30, 2011 at 12:05 PM
    dan0
    dan0 [OP] Well-Known Member
    swamplands of sc
    Sold 2011 Prerunner Doublecab 4cyl auto
    ok, I've been spending way to much time reading instead of working :)
    reading thru the threads on the Suspension TSB problem it seems the 3 pack leaf springs are replaced with a 4 pack and new shocks. Well my 2011 double cab only has 3 leaf springs and skinny little shocks in the rear. Is it possible my new 2011 suffers from the rear Suspension TSB problem?
    the one documented here http://www.tacomaworld.com/forum/2n...s-who-performed-suspension-tsb.html#post71869
    If so how could i go about getting it fixed since the TSB only states thru 2010?
    thanks
    dan0
  2. Mar 30, 2011 at 12:09 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    Load it up with about 300 or 400 pounds and drive it around. If you have a really harsh ride going over speed bumps and bumpy roads then you should get them swapped out. If you don't really haul much around in the bed of your truck and like the ride the way it is then don't change them.
  3. Mar 30, 2011 at 12:12 PM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    Even when/if they include 2011 with the TSB fix it will not totally solve the problem. My truck had the TSB 4-pack installed and it still sags to the bump stops with a full load of firewood. The TSB will help but it's not a quick fix for the problem.
  4. Mar 30, 2011 at 12:53 PM
    Gregg
    Gregg Well-Known Member
    Gregg
    New Jersey
    2010 Access Cab TRD Sport 4x4 Magnetic Grey
    Here is the TSB that includes the 2011 Tacoma.
    T-SB-0359-10 Leaf Spring TSB.pdf
    I changed the name of it to make it easier to locate.
  5. Mar 30, 2011 at 12:58 PM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    You don't need to do it just because you can. Stiffer leaf pack = harsher ride quality, so unless you really think you are going to be maxing it out on a regular basis I would leave it alone. I don't take mine in unless its really a problem they might mess up something else in the process.
  6. Mar 30, 2011 at 1:04 PM
    Umrunner
    Umrunner Caltanian
    Bay area, and Missoula, mt
    '11 DC OR Timberland Mica. 6 speed.
    Leer 100xr with adventure package, bfg at's, weathertech's, demello sliders, billie 5100's all around, URD short shifter, Diff breather mod. BDF lightbar. Grillcraft grill. PIAA 520 severe weather driving lights. Other random stuff as well.
    I had 4 guys in the truck, and a bit of ice fishing gear, not a ton of weight, and was riding the bump stops in my 2011 dcor. Post tsb, not an issue, and i find the ride to have been improved.
    Do with it what you will, but the truck is better imo, post tsb. Besides, i like knowing that 4 guys and some gear isnt too much for my tacoma. My old 4runner was overloaded many times, and never once hit the bump stops...
  7. Mar 30, 2011 at 3:12 PM
    dan0
    swamplands of sc
    Thanks for all the input and info.
    I dont load it down a lot but on occasion I'll toss the riding mower in the back or a few bags of fertilizer.
    Guess I'll load it down and see how it shakes out.
    thanks
    dan0
  8. Mar 30, 2011 at 4:21 PM
    Jimsc
    Jim
    Greenville, SC
    Dan that sounds like a plan. You have a brand new truck, so give yourself some time with it before you do something you might regret.
  9. Mar 30, 2011 at 4:29 PM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
  10. Mar 30, 2011 at 4:57 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Mine are on dealer order and will be replaced as soon as they come in. The "11s" only get springs and an alignment shocks are latest rev. The 4 leaf springs are stock for Canada so they can't ride all that poorly. Maybe they are putting the US springs on the Canadian trucks that they take off because of the hard ride!
  11. Mar 30, 2011 at 5:06 PM
    Gregg
    Gregg
    New Jersey
    You have until your 3 year/36,000 mile warranty is up to decide if you need it done.
  12. Mar 30, 2011 at 6:31 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    My 2005 DC bottomed out over speed bumps or any bumps with 4 people or a load in the bed.
    My 2010 (also 3 leaf springs) does NOT... So, they improved the springs (at least on my Baja made 2010 truck).
    I find it hard to believe that they only made some better springs since 2005 and some Tacos are still bottoming out up to this model year?
    The 2005 harsh ride was solved with Ride Rite air bags and Bilstein 5100 shocks... was perfect after I did that... Dealer wouldn't help and I didn't know about TW or TSB back then.
  13. Mar 31, 2011 at 10:05 AM
    JKD
    JKD Well-Known Member
    The first and probably only important question is: do you experience an actual problem?
    I've loaded down my '09 AC with 500+ pounds now, and driving it around even on rough country gravel roads there is absolutely no problem with the rear suspension. I have the factory 3-leaf springs.
  14. Mar 31, 2011 at 10:54 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Toyota did something new to the 2009's which I believe they thought would mitigate the bottoming out issues. Obviously it does not. See my post here about that.
    Anyways, I had the TSB completed on my 2009 4x4 OR DC in September 2009. My problem report was simple. I was bottoming out with my camping gear in the bed while driving on a gnarly back-country service roads. I knew something wasn't right and did some searching and found TacomaWorld and the rest of you good folks.
    I read about the T-SB-0305-08.pdf for the rear springs, and it seemed like it would solve my problem.
    Next I verified the parts numbers for my factory leaf packs were identical to replaced parts in the TSB. The part numbers are on the top of the springs.
    I took pictures of the underside of the truck bed to show where the bump stops were hitting.
    It was very clear I was bottoming out because it was dusty as hell everywhere except where the bump stops make contact. Duh? this should be a no brainer. I printed the TSB and went to the stealership.
    To make a long story short, the approval for the TSB came not from the dealer but from a regional guy who works for Toyota and services the southern California region. At the time the '09's were not officially covered by the TSB.
    Here is a picture of the updated leaf pack:
    I bought the truck to access the many remote areas of the southwest while camping and climbing. After many months of wheeling I can say confidently that I feel that my truck is much better equipped to do that now.
    However, based on how I use my truck I don't expect the TSB springs to last beyond three years, at which point I'll probably go with some custom springs.
    PICS
  15. Mar 31, 2011 at 12:12 PM
    mac360
    mac360 Well-Known Member
    Long Beach, Ca
    2017 Tacoma OR DC LB
    Loaded my 2010 ac with 700lbs.. Bottomed out.. Had them replaced yesterday per TSB ride is a little stiffer and definitely lifted the rear. Dealer ordered them had them in within a day and replaced in 3 hrs and free alignment.
  16. Apr 20, 2011 at 7:04 PM
    YOTATXTACO
    YOTATXTACO New Member
    EDMOND
    TX TACO
    NONE
    Just had mine done today on a 2011 TRD 4 door, it does ride a little rougher but I like it to ride like a real truck so its not a problem for me. They added a leaf and new shocks
  17. May 18, 2011 at 10:28 AM
    chabro
    chabro Well-Known Member
    Houston
    2011 SR5 4x4 DC
    2011 DC SR5 done today. Rear was noticeably lower with camper and tool box. Dealer changed no problem. 4 leaf pack. New spring numbers are 48210-04571 and 48210-04211. Sits good and feels much better.
