2011 Taco,Bilstein 5100 series adj set at 2.5, Max tire size??
Discussion in 'Wheels & Tires' started by AcidEagle, Mar 20, 2011.
  1. Mar 20, 2011 at 4:00 PM
    AcidEagle
    AcidEagle [OP] New Member
    '11 Dblcab TRD sport black badge
    Bilstein 5100 Adj to 2.5, Westin bullbar, Westin oval side steps, Goodyear Duratrac 285/70R17, KMC XD797 Spy wheels 17"x9", Blacked out badges
    I currently have a 2.5 inch lift in the front and want to put 285/70R17 Good year duratrac tires on. The wheels are 17x9 with a -12 offset. The dudes at the shop are telling me I need to cut the cab mount back and weld in a plate to fit this size, but I am positive I have seen it done without. whats the consensus???
  2. Mar 20, 2011 at 4:48 PM
    Sawick
    Sawick Still not worthy!
    JB MDL, NJ
    16 TRD Sport
    T4R TRD Pro Wheels, LED lights, Tonneau Cover, ICI running boards, AVS window/bug
    Probably going to have to trim the flaps, and possibly some other stuff to make it work. I dont know about welding anything though. Plenty of posts here about this same topic, most end up trimming. 4.5bs and -12 os usually are the recommended specs if I remember.
  3. Mar 21, 2011 at 6:08 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Wheel specs are good, but the shop is right, a lot of people end up chopping their cab mount to fit that size without rubbing.
  4. Mar 21, 2011 at 10:43 PM
    AcidEagle
    Thanks for the info, as it turned out the cab mounts needed to be cut. Off-Road-Warehouse San Diego did the job and it turned out great. The 285's fit perfect after that. I still need to do some minor tweaking on the wheel well liner. Here's some pix.
  5. Mar 22, 2011 at 12:51 AM
    Sawick
    JB MDL, NJ
    16 TRD Sport
    Glad it worked out!
