2011 taco lift questions
Discussion in 'Suspension' started by hbryanlopez, Sep 19, 2010.
  1. Sep 19, 2010 at 12:47 AM
    hbryanlopez
    hbryanlopez [OP] Well-Known Member
    herby
    mcallen, tx
    black out headlights bilstein 5100s toytec 2" aal procomp 7089 nitto terra grapler 285/70/17
    I recently got my 2011 taco and have some lift questions. I've done some searching but very limited on 2011s. I bought a set of bilstein 5100s. would like to set it to 2.5" to fit 285s but was wondering what the rear block should be on a 2011 with 2.5" in the front. toytec has 1-1.5 rear blocks and they also have 1 1/2 rear aal. but both of these are listed as 2010 tacomas. would these be any different from the 2010?
  2. Sep 19, 2010 at 2:23 AM
    08WhiteTRD
    08WhiteTRD Well-Known Member
    Benjamin
    Marysville, NorCal
    2008 White 4x4 TRD Sport
    Fox Suspension 2.5 Front and 2.0 Rear, All-Pro Skids, BAMF LCA Skid, Leer 100R, Scangauge II, WeatherTech Floorliners, WeatherTech window visors, Satoshi grill with HomerTaco mesh, Sockmonkey Tailgate Decal, BHLM, Center Console lock, ImMrYo Rear-view bracket, Rally Armor mud flaps, Crawford Eco-Block, USA-Spec PA-15
    Everything is the same on the newer tacomas as far as I know of. You should be fine. From what I have seen, it's only small cosmetic changes.
  3. Sep 19, 2010 at 3:47 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    no blocks use an aal
  4. Sep 19, 2010 at 3:48 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    oh and i would say a 2" aal if you dont have a 4 leaf pack "tsb"
    and a 1 1/2" if you have tghe 4 leaf pack
  5. Sep 19, 2010 at 3:51 AM
    hbryanlopez
    herby
    mcallen, tx
    thanks guys, i will check my taco if it has a 4 leaf pack. so the 2" aal should level me with the 2.5" front right?
  6. Sep 19, 2010 at 4:06 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i have 5100's at 2.5 stock springs and the non tsb spring pack with a 2" aal and its level....
  7. Sep 19, 2010 at 6:10 AM
    hbryanlopez
    herby
    mcallen, tx
    cool thanks for the info, i just checked my 2011 taco and it has the 3 leaf pack
  8. Sep 19, 2010 at 12:36 PM
    Blk04SR
    Blk04SR Well-Known Member
    SoCal
    07 TRD Offroad PreRunner
    A Few...more to come!
    I second the aal.
