2011 tacoma 4.0 engine swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by richforkhugger, Apr 16, 2012.
  1. Apr 16, 2012 at 5:40 PM
    richforkhugger
    richforkhugger [OP] New Member
    Scott
    26330
    tacoma 4x4
    Have a 2011 taco double cab sport 4x4 with 4.0 auto got her wet engine is locked up wondering if 4.0 from 2009 toyota tacoma will fit ?
    Thanks
  2. Apr 16, 2012 at 5:57 PM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    Yes, I am fairly sure the 2009 is when the new connectors were used through the wiring harness. Based on those storms that rolled through last night, where you located? Or was it just offorading?
  3. Apr 16, 2012 at 6:02 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Holy suck. :(
    No way to take it apart and rebuild?
    Im guessing you pulled the plugs and cranked it in hopes of getting the water out?
  4. Apr 16, 2012 at 6:12 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Sucks man. How'd it happen? What are you going to do with the old engine block?
  5. Apr 16, 2012 at 6:39 PM
    richforkhugger
    Scott
    26330
    tacoma 4x4
    Brother borrowed her and parked her in the creek. Thats a whole story in its self. Would rather swap engine than take the time to rebuild, May need a core, Looking for a engine wondering what model years will fit?? Removed plugs drained 8 quarts of water from engine replaced oil & starter , soaked cylinders with oil no water in tranny,diffs or transfur case, cranked engine at least 1000 times with plugs out lubing cylinders along the way sounded ok no abnormal noises installed plugs coil packs etc. Tried to start turned over afew times and locked up tight removed plugs relubricated cant turn her over with starter or breaker bar on front of the engine??
  6. Apr 16, 2012 at 6:43 PM
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
    ouch i would hurt my brother if he did that to my truck. hope every thing works out
  7. Apr 16, 2012 at 7:30 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Insurance will pay for it. Thats why you have it. Be ready for the rate hike.
  8. Apr 16, 2012 at 7:38 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Stupid cali smog laws.
  9. Apr 16, 2012 at 7:43 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    The derps always gotta fuck shit up. Hey bro I gots me these long headers braaap brraap.
    Sucks that it's like that with engines. Should allow for a few year window for repairs.
  10. Apr 17, 2012 at 3:54 AM
    MikeyLikesIt
    If his old ECU is good, he should be fine. That is the only way they would be able to tell.
