2011 Tacoma 4.0L rough idle & underpowered - any ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by streetlightning, Jan 1, 2011.
  1. Jan 1, 2011 at 9:10 PM
    streetlightning
    streetlightning [OP] Member
    Denver, CO
    '12 Tacoma TRD T/X Pro
    Hey there,
    I've got a problem with my new 2011 Tacoma that the dealership can't figure out. They're trying, but I thought I'd see if anyone experienced the same problem.
    On Thanksgiving night, the Taco was idling in a parking lot and all of a sudden started idling rough. I didn't think much of it as thought it would go away. The next week, I drove to Salt Lake City (500 miles) and on the highway, it quit... not sputtered out... it just quit at 75MPH. I got it over to the side and it restarted and I was on my way again. The next day... same thing. It quit. This time, it didn't want to restart and when it did, the engine as well as the traction control light remained on. I took it to a dealer in Wyoming where they reset the misfire codes and told me I had water in the gas. They did not confirm this, but it was their speculation.
    Upon returning to Denver, I took it to my dealer where they told me I had water in the gas. Again, not confirming any gas. I told them I'd run a few hundred gallons of gas through it since the problem started and would continue to prove there was no water in the gas.
    The next week, they took a closer look and confirmed the truck does have a strange idle. They checked compression on each cylinder, spark gaps on each plug. They richened up the fuel and leaned it out only to find neither affected the rough idle.
    Its a 2011 with 12,000 miles. I bought it back in August and its not my first Tacoma. Its my fouth since 2004 and my third 4.0L VVTi (2006 and 2008) so I know exactly how they should run, especially with a trailer. My fear is that they are going to say this is normal. The real problem is when you put a trailer behind it. It is severly underpowered. I own three trailers and do a lot of towing. About 20% of my driving is towing a trailer. I towed my empty flat bed over the weekend and the cruise control wouldn't hold the truck at 70 MPH which should be no problem. Back in September, I drove this truck to Texas and back with this trailer and it ran great... just as it should.
    So, I'm looking for any thoughts on what this problem could be or how to approach this as its been in to the dealer three times and they can't fix the problem. Its a major problem when paying $500+ a month and not having a 100% working truck.
    Thanks in advance and happy new year!
    Warren
  2. Jan 1, 2011 at 10:04 PM
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    Sounds to me like you have an intermittent short or bad connection in the wiring somewhere, which can be a real pain in the butt to find. Possibly relating to the fuel pump circuit. Do you have any ideas what codes were set if any? Incorrect fuel pressure can cause rough idle or engine shutoff if low enough. Did you run the gas tank low when this happened first?
  3. Jan 1, 2011 at 10:08 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
  4. Jan 1, 2011 at 10:42 PM
    streetlightning
    Denver, CO
    Blaze- The codes were PO300, PO305 and PO306 all relating misfires both individual cylinder and multiple cylinder misfire.
    Both times the engine quit, it was well above half a tank of gas. I've now driven this over 2500 miles with the engine problem. Its crazy and its starting to get irritating. These 4 liter engines run so well and tow my trailers perfect, but this is a pain in the butt. I don't know what to do if they say they can't find the probelm so I'm trying to help them find the problem.
  5. Jan 1, 2011 at 10:47 PM
    satcom221
    satcom221 Well-Known Member
    Rick
    Mercer Island, WA
    2010 Silver Streak Mica Double Cab SR5 4x4 SB
    Tail gate anti-theft, Backup camera anytime, anytime Fog Lights, always on 12v plugs
    Warren,
    I had a 96 Jeep Cherokee (replaced it with 2010 Tacoma) that did that exact same thing for a few months and kept getting worse and longer to restart. It ended up being the crankshaft position sensor. In my case it could have been just out of adjustment but with over 210,000 miles, I had it replaced - cost me $400 but I didn't have to worry about the engine cutting out at 70 on the highway. Even though its a new vehicle might ask the service folks to take a look at it. I hope you find something out soon.
    Rick
  6. Jan 1, 2011 at 11:47 PM
    BlazeTaco
    PA
    4.0l 6sp SR5
    Hey one of those codes is camshaft sensor a range/performance error. check for loose wiring or exposed copper around the top portion of the engine towards the front of the cylinder heads. Your engine has variable valve timing it uses the sensor as a reference of where to adjust the cam to in correlation to the rest of the engine. That can cause some major issues like you described if it getting incorrect timing readings.
  7. Jan 1, 2011 at 11:58 PM
    streetlightning
    Denver, CO
    I typed one of the codes as PO360 instead of PO306. I think they're all cylinder misfire codes. I also believe that this problem has something to do with the cam/valve timing. I don't fully understand the VVTi and how it works, but know enough to know that its more likely the cause.
    I think there are many people out there with this problem, but most people won't notice it 1.) because it seems normal and have nothing to compare it to and 2.) because they don't tow very often. Hopefully, they'll find this and issue a TSB on it.
  8. Jan 2, 2011 at 12:23 AM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    Your engine cutting out at 75mph is NEVER normal!
  9. Jan 2, 2011 at 12:40 AM
    BlazeTaco
    PA
    4.0l 6sp SR5
    well incorrect cam timing could cause lost compression since the valve is not opening or closing at the right time hense the cylinder misfire.
  10. Jan 2, 2011 at 6:50 AM
    shook0002
    shook0002 "The Fuzz"
    Joe
    Philly
    '08 Doublecab 4X4 SR5
    3 times back at the dealer, same problem, still no fix. Sounds like a great reason to lemon law it and get another one.
  11. Jan 5, 2011 at 3:06 PM
    streetlightning
    Denver, CO
    I had the Tacoma back at the dealership today as the Toyota Field Representative was in town. They still haven't figured out the power/idle issue. I mentioned a possible cam/timing sensor and they didn't feel that was the problem. Toyota has authorized the replacement of all six injectors which should go in next week. I hope it fixes it.
  12. Jan 5, 2011 at 3:48 PM
    jg7
    jg7 Active Member
    My $$$ is on the cam position sensor and/or wiring loom leading to it.
  13. Jan 5, 2011 at 4:16 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Heh I like when the deal just throws money at shit they aren't even 100% sure of :eek: :D
  14. Jan 5, 2011 at 4:23 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I predict you'll need to pursue a buyback. So record all your problems and contacts with the dealer/Toyota and save all your paperwork and receipts!
  15. Jan 5, 2011 at 4:38 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Throw the book at them, and lemon law theyr ass.
    Take care
    vbibi:(
  16. Jan 6, 2011 at 4:54 AM
    jg7
    jg7 Active Member
    For lemon law to work I believe the diagnosis must be EXACTLY the same on three invoices or else it doesn't count. Don't let them say it is the O2 sensor one day, Cam sensor next, then injectors. This is how they get around it. Make sure it says something broad like "runs abnormally rough as confirmed by technichian".
  17. Jan 6, 2011 at 5:02 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Contact Toyota and start a complaint saying the dealer can't find or fix a problem.
    If no one can find it or fix it...that's what lemon laws are indeed for. Check out what the process is in your state for declaring yours a lemon and make sure you are following it in case they never find the problem. With three return trips for the same problem I'd imagine you're getting close.
  18. Jan 6, 2011 at 5:12 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Subbed
  19. Jan 6, 2011 at 5:18 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    X2 Look into the lemon laws in your state.
  20. Jan 6, 2011 at 5:23 AM
    rwilso03
    rwilso03 Well-Known Member
    Russ
    Colorado Springs
    2010 DC SB 4.0L 6spd Barcalona Red
    TRD Exhaust, Engine Ticking Fix, Fog Lights Anytime, Locking Center Storage, 4LO Trac Mod, Rear Spring TSB
    This definitely sounds like a wiring issue to me. Maybe a loose ground in the ignition or like before mentioned the VVT System. I have seen one loose or frayed ground wire do some really strange things...
    Oh and yes they are a bitch to find.
