2011 tacoma best way to level
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jodyc, Sep 27, 2011.
  1. Sep 27, 2011 at 6:21 PM
    Jodyc
    Jodyc [OP] Member
    Jody
    Jersey
    11 Tacoma Trd sport
    just got a new trd sport short bed i need to level it bad.ive been tooling around the forums for a couple weeks ,it seems the best way is to go with the bilstien 5100s. and what is a tsb4 i think it the leaf springs i looked and i have 3 leafs.is this something the dealer will do for free? or do i get aal and which one. i would like to put on some new shoes also it has 17in wheels now do i go with 16s so the tire looks bigger? i really dont want any issues.i just want to do it the right way!!!!! also whats the biggest tire i can go with?dont mind if i have to do minimal trimming. thanks cant wait to get started ill post pics
  2. Sep 27, 2011 at 6:52 PM
    jeremy.allen
    jeremy.allen Well-Known Member
    Jeremy
    The Ville, Ky
    07 DC, OR
    3" Lift with OME 885's, 5100's front and rear, alcan add-a-leaf. Banks Monster Exhaust, on the way: MM951C 17X9 and 285 MT/R's...
    Most people on here will say stay awa from spacer lifts. Billstein 5100's are the best way IMO to level your truck. You are currently running 265.65.17 size shoes stock. If you only want to level your truck, the billstein's set at .85 or 1.75 should do the trick. If you want to go one tire size bigger (265.70.17) the billstein's set at 1.75 should be suffecient with either a 1.5 inch bock or an add-a-leaf. If you go a full 3 inch lift setup, you can stuff a 285.70.17 with little to moderate trimming. Hope this helps.
  3. Sep 27, 2011 at 10:37 PM
    Chris135
    Chris135 Well-Known Member
    Regina,Sk
    2011 Tacoma DCLB SR5 TRD Sport
    Debadged Bilstein 5100 shocks in front OME 885 coils Icon 1.5"aal 16" fj cruiser Trd rims 285/75/16 duratrac tires 1.25" spidertrax wheelspacers (4) Tinted front windows Grillecraft upper grille Custom Trd boxside decals Allpro front bumper Piaa 510 fog lights Box mounted ammo can Rear diff breather BHLM Tinted front windows Rolltop tonneau cover Hand controls (for wheelchair users)
    i have 5100 billys set at 2.5 with an 1.5 icon aal in the back. I fit 285/75/16 tires with no trimming and light rubbing on tight turns. However i must say that my back end is stiff as hell when going over bumps. Best way to decide what you want to do with your truck is research lots using the search feature. it is our best friend.
  4. Sep 28, 2011 at 1:19 PM
    Jodyc
    Jodyc [OP] Member
    Jody
    Jersey
    11 Tacoma Trd sport
    Ok so I called the dealer there goin to put on the new leaf springs now what should I set the 5100s at 1.75 or 2.5 to level it out also will 285/75/17 fit
  5. Sep 28, 2011 at 1:22 PM
    Jodyc
    Jodyc [OP] Member
    Jody
    Jersey
    11 Tacoma Trd sport
    Also should I change out the leaf springs from 3 to 4. And will that give me any lift In the rear
  6. Sep 28, 2011 at 1:23 PM
    georgeandkanoa
    georgeandkanoa the point is simply this
    jeff
    calgary
    07 tacoma trd
    bilstein5100's front tinted windows access cover pioneer stereo weathertechs grillcraft grill kc's behind cbi sliders
    mine are set at .85,and I'm from Canada and already have the additional leaf, and mine is perfectly level
  7. Sep 28, 2011 at 1:30 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    If you're getting the rear leaf TSB done then you are already going to have 4 leafs and you won't notice much lift after it all settles.
    I would just get that done and then go from there - no point in rushing it.
    Search around for the 5100 settings, it's all over the place.
    Fink
