2011 Tacoma cummins + mid travel feeler
Discussion in '5 Lug' started by disc0monkey, Aug 5, 2012.
  1. Aug 5, 2012 at 11:03 AM
    disc0monkey
    disc0monkey [OP] All right. I believe ya. But my Tommy Gun don't!
    Hey guys so after a year with fat bobs lift. I'm thinking about fiberglass fenders, tc mid travel, and a cummins 4bt diesel.
    I have two questions, how do I lift the rear more to match the front?
    And what is my current 2011 engine and 5spd trans worth with 20000 miles on them?
  2. Aug 5, 2012 at 11:07 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  3. Aug 5, 2012 at 12:50 PM
    disc0monkey
    Why?
  4. Aug 5, 2012 at 12:55 PM
    disc0monkey
  5. Aug 5, 2012 at 1:00 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    a cummins swap is BIG $$$$$$$$$$
  6. Aug 5, 2012 at 1:35 PM
    disc0monkey
    Oh my bad
  7. Aug 5, 2012 at 1:36 PM
    disc0monkey
    Yes it is.
  8. Aug 5, 2012 at 1:36 PM
    disc0monkey
    What makes it big money? Where bc I don't see where the money is?
    Motor is around 4000 plus computer and harness. Fuel pump and lines 600.
    I will do all the work myself. I have a mn12 stage 3 T56 in the garage.
  9. Aug 5, 2012 at 1:38 PM
    disc0monkey
    Fixed lol
  10. Aug 6, 2012 at 5:48 AM
    disc0monkey
    anything to match rear for a mid travel?
  11. Aug 6, 2012 at 5:54 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Curious as to why you want the diesel? The money you're going to spend on a new motor could be put into your current engine and still have plenty of money for suspension and bodywork upgrades.
    Don't get me wrong, I want to see this get done, just wondering what the reasoning is?
  12. Aug 6, 2012 at 6:01 AM
    dieseltoys
    dieseltoys Well-Known Member
    When you add a 970 lb. engine up there, your long travel wont be as long. You also may want to get any loose fillings fixed at the dentist prior to firing that bad boy up...
  13. Aug 6, 2012 at 6:09 AM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Okay heres the challenge, Drop the 4bt, Make it fit a straight 6!!!! Come on do it! lol
    Cummins 5.9 HO!!!
  14. Aug 6, 2012 at 6:13 AM
    dieseltoys
    I'd love to see an ISB 2.8 in there. Now, those are cool engines.
  15. Aug 6, 2012 at 6:25 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    What about the tranny? Would a cummins bolt up to it
  16. Aug 6, 2012 at 6:50 AM
    dieseltoys
    No, they use a completely different setup and the A750 transmission controller needs CAN +/- signals from the 1GR ECU (combined unit) in order to control shift points. You would need to use a GM transmission. Basically, everything that makes the Toyota good you'd be removing from the vehicle and replacing it with a chinese built engine and GM transmission.
  17. Aug 6, 2012 at 7:41 AM
    disc0monkey
    The reason I want the diesel is because I want more torque and I don't want to wait for it. I also think I can get north of 35mpg highway.
    The trans will be a stage 3 T56 that I already have ready to go, which will bolt up with the chevy adapter. I think the clutch situation can be worked out by machining the LS clutch for the cummins crank.
    I messed up on the Title, I am looking for MID TRAVEL!!
    I figure I can get the proper coils for the weight of the new engine. That is the reason that got me thinking Mid Travel in the first place was to get the right springs for the added weight and take out the spacers from the fat bobs.
  18. Aug 6, 2012 at 7:56 AM
    disc0monkey
    I'm open to any type of diesel. Whats are the pro-cons to this one?
  19. Aug 6, 2012 at 8:00 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    If you can do it I would love to see a diesel in a taco
  20. Aug 6, 2012 at 9:15 PM
    Midnight Drifter
    Midnight Drifter Well-Known Member
    Anthony
    Monroe Twp, NJ
    2TR W/T
    Flowmaster dual exhaust
    Jeez, why not just overboost a D4-D? Come on man, stay in the family!
