2011 tacoma double cab sound system help
Discussion in 'Audio & Video' started by KILGORE76, Mar 30, 2016.
  1. Apr 12, 2016 at 8:31 PM
    KILGORE76
    KILGORE76 [OP] Well-Known Member
    Beaufort,sc
    2011 toyota tacoma double cab
    I do have polyfil..Ill try the crossover points if that don't work,Ill just live with it...lol!!
  2. Apr 13, 2016 at 7:58 AM
    ike3000
    ike3000 Well-Known Member
    Cascading crossovers (which what happens when you use two crossovers on top of each other) introduces additional phase shifts, which could be partly to blame for the horrible sound. I would start with only using the head unit crossover just because it's easier to adjust while listening to music. Turn the amp crossover all the way up to the highest setting. I would also recommend putting your subwoofer level flat and EQ flat on your head unit, and using the amp gain to set level. You should really only be subtracting from the sound at the head unit (reduce subwoofer level or lower certain EQ frequencies), because adding signal is the easiest way to cause distortion. Especially if the sound processor quality is less than stellar. You can make small boosts to problem frequencies, but I would try to keep it less than a couple of dB. If you find that a certain frequency needs to boosted dramatically for a better sound, then cut all other frequencies and increase head unit volume knob or amp gain accordingly.
    Also make sure your subwoofer and mids phase are set properly (if you can). I start with disconnecting the sub and play a beat heavy track with just the mids. Flip the phase on one of the mids and see if the music sounds better and punchier. If it does then leave it alone, if not, switch back the phase. Then connect your sub and listen to the same track. Flip the phase on the sub and see if it gets better. Leave the phase on which ever sounds better.
    Judging from the amount of boost you have on your sub frequencies, I'm suspecting you're having phase issues or the amp gain is set too low.
    good luck!
    KILGORE76[OP] likes this.
  3. Apr 13, 2016 at 3:37 PM
    KILGORE76
    Beaufort,sc
    The amp gain might be set to low but i set the amp with the DD-1 distortion detector,Ill try what you said..Ill get back to you..Thanks!!!
  4. Apr 13, 2016 at 4:04 PM
    KILGORE76
    Beaufort,sc
    Getting better! If i can just turn the gain up on the amp without distortion i think ill have the bass set!Got the level flat and the crossover all the way up on the amp,The headunit crossover is at 80hz for the sub,The high pass for the 4 channel is at 100 hz...Bass boost on the headunit is 0,Subwoofer level is at 0.
  5. Apr 13, 2016 at 4:51 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Sweet - sounds like things are coming together! Fingers crossed.
    Good post Ike. Phase never occurred to me.
  6. Apr 13, 2016 at 6:22 PM
    KILGORE76
    Beaufort,sc
    thanks!
  7. Apr 13, 2016 at 7:14 PM
    KILGORE76
    Beaufort,sc
    Do you guys like processors?
  8. Apr 13, 2016 at 7:27 PM
    rob feature
    rob feature Tacos!
    Colorado
    Yeah, why not? It's WAY more control. The simpler the better though IMHO - as in either head unit or amp-mounted.
  9. Apr 13, 2016 at 7:42 PM
    mahon
    mahon Well-Known Member
    Eric
    You should prolly up your battery ground. Make it the same gauge as your power wire.
  10. Apr 13, 2016 at 7:49 PM
    KILGORE76
    Beaufort,sc
    What prossecor do u think? Should i do a big 3?
  11. Apr 13, 2016 at 7:56 PM
    mahon
    Eric
    Nope, ive always read that you should have the same size wire for both. If you are running high amps through the battery it should also be grounded at the same capacity. Just make sure you arent bottle necking anything with the factory 8 gauge or what ever it is.
  12. Apr 13, 2016 at 8:02 PM
    rob feature
    rob feature Tacos!
    Colorado
    You're around 900W right? 900W/13.5V~67A ignoring efficiency. So call it 80 amps balls out. How much extra capacity is available in the 2nd gen? Using extra lighting, etc?
    Processor? Change the head unit to maybe a PRS80? Gobs of directions to go here though. Gobs.
  13. Apr 13, 2016 at 8:05 PM
    mahon
    Eric
    Models with the tow package come with 130 amp alternators i believe they pull about 60 amps before mods. Technically you are over already and should prolly go with a high out put alt. I could be wrong please correct me if i am.
  14. Apr 13, 2016 at 8:13 PM
    rob feature
    rob feature Tacos!
    Colorado
    I'd say he's fine with the alternator. That 80 amp estimate is at full-disco. Won't hurt to evaluate the stock wiring though.
  15. Apr 13, 2016 at 8:15 PM
    #35
    KILGORE76
    Beaufort,sc
    The factory wire looks like 8 gauge......for my amps im running 4 gauge.
  16. Apr 13, 2016 at 8:16 PM
    #36
    rob feature
    rob feature Tacos!
    Colorado
    I might just do a 4 ga run then
  17. Apr 13, 2016 at 8:17 PM
    #37
    KILGORE76
    Beaufort,sc
    Last question...what double din do u like?
  18. Apr 13, 2016 at 8:18 PM
    #38
    mahon
    Eric
    Yup i agree im running about a 900 watts on the stock charging and have yet to have a problem
  19. Apr 13, 2016 at 8:23 PM
    #39
    rob feature
    rob feature Tacos!
    Colorado
    I have no double DIN recommendation for you...wish I did. I want one too. I understand there are no decent DSP-capable double-DIN head units...at least in a reasonable price range. But think of all the mentos you can squeeze into the pocket below your fancy new single DIN :D
  20. Apr 13, 2016 at 8:27 PM
    #40
    KILGORE76
    Beaufort,sc
    Man i dont know if i could go back to a single din after having a double...lol
