2011 Tacoma - Prewired for fogs, camera, overhead console?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tunngavik, Sep 19, 2010.
  1. Sep 19, 2010 at 8:37 AM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing
    The thread title says it all. Was wondering, for those who have a 2011 Tacoma - do they come prewired for the fog lights, backup camera and overhead console like the 2010's, 2009's....
    Thanks!
  2. Sep 19, 2010 at 8:39 AM
    mattleegee
    mattleegee Well-Known Member
    Tacoma, WA
    2018 WRX
    Most likely yes, they do this at the plant to save money actually, doing them all the same way and that way options could be added very easy
  3. Sep 19, 2010 at 5:30 PM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '10 Access SR5 4x4 4cyl
    FWIW not all 2010 came pre-wired for fog lights. For instance, my 2010 SR5 Access 4x4 is not pre-wired for fog lights.
  4. Sep 19, 2010 at 6:11 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Even if the trucks are pre-wired, they don't have the most necessary parts you'll need, fuses, relays, switches, etc. So, the actual wires may be there, but installing those parts would be a pain in the ass.
  5. Sep 19, 2010 at 7:37 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    4cyl are not prewired for fog lights- I believe the camera is a yes, but I am not sure about the overhead- I have not checked mine yet...
  6. Sep 30, 2010 at 8:08 PM
    Tunngavik
    Alberta, Canada
    Thanks for the information.
    Anyone else out there with a 2011 can check the overhead console / camera / fog lights?
  7. Sep 30, 2010 at 8:38 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    I pick up my 2011 tomorrow. I test drove one just like it. I can answer yes to overhead and camera. Didn't test out fogs. I can let ya know tomorrow after I get it.
  8. Sep 30, 2010 at 9:47 PM
    Tunngavik
    Alberta, Canada
    That would be great - thanks for doing that! Congradulations on the purchase - what trim level did you purchase?
  9. Sep 30, 2010 at 10:20 PM
    wolfdog2314
    Brush Prairie
    I'm picking up a 2011 trd sport. Double cab short bed. In black. I'll put some pics up tomorrow if I get the chance!
  10. Sep 30, 2010 at 10:33 PM
    Tunngavik
    Alberta, Canada
    Isn't the TRD Sport automatically be prewired for a camera, fogs and overhead console as these come as options.
    Some of the base and SR5 packages were prewired even though they were not installed with these options.
  11. Oct 1, 2010 at 5:56 AM
    wolfdog2314
    Brush Prairie
    I guess I don't quite understand the question... I just know that the trd sport has the back up camera, overhead display, and more than likely the fogs. I'm sure there's someone else here with an 11.
    I couldn't sleep last night, getting mine in a few hours!
  12. Mar 18, 2011 at 7:52 AM
    gwatk
    gwatk Member
    have an 11 base model access cab. Its prewired for overhead console. Dont know about the other accessories
  13. Mar 18, 2011 at 10:20 AM
    flyfishinMT
    flyfishinMT Active Member
    AK
    2011, AC, 4wd, auto, 4cyl
    K&N filter, Leer 180, WeatherTechs, PopnLock, OEM knock off fogs, Duratracs, 16" FJ Wheels, Avid Lightbar, KC Daylighters
    4x4 base, SR5 doesnt have anything for fogs. Camera yes, dont know about overhead console. Saw a post a while back that wiring is there but it doesnt have the compass or outside temp sensor. Id like to put the console in mine, but...
  14. Feb 7, 2012 at 11:48 AM
    CK4500
    CK4500 Well-Known Member
    Red Deer, AB, Canada
    2011 Reg Cab
    FYI
    I just removed all the covers on my tail gate to install a OEM backup cam on my 2011 Reg Cab 4x4 Taco. All prewiring is in there. Took 15 minutes.
    Now on to wiring it up to my Pioneer AVICX930BT
  15. Feb 7, 2012 at 1:57 PM
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    So let me get this straight...
    On my 2011 4 cylinder SR5 Access Cab, there is pre wiring for the overhead console but not the fog lights? (I already have a backup camera)
  16. Aug 16, 2014 at 1:03 AM
    Armcphail
    Armcphail Member
    Aaron
    Chatham,Ontario
    4 cyl sr5
    I have a 2013, was not prewired for fog lamps, I installed a camera in the tailgate I have yet to find the overhead wires. Anyone found them in a 2013 4cyc
