2011 TRD lift kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USMCBEANZ, Jun 11, 2011.
  1. Jun 11, 2011 at 3:58 AM
    USMCBEANZ
    USMCBEANZ [OP] Member
    Barstow, CA
    2011 TRD Off-Road Edition
    Stock (for now)
    I want a 3" lift on my 2011" TRD off-road. I have found many companies who make them however I hear that the truck will not be level. I talked with a rep who recommended I use a front leveling kit with rear 1" blocks. Has anybody done this and can I still fit a 32" tire with a 17" rim without trimming? I can't go any higher on the lift due to the vehicle stability control.
  2. Jun 11, 2011 at 2:48 PM
    IdealError
    IdealError Active Member
    Orange County, CA
    09 PreRunner SR5 Sport
    6" Fabtech lift, 18" KMC XD Addicts on 35" Toyo MT Tires, 8000k HID Lights/Fogs, T-Rex Billet Grille, Viper 5900 Remote Start/Alarm, LED Projector Headlights, 15% Tint fronts, 5% Tint back, Eclipse Head Unit
    I have a 2009 with VSC... I run a 6" Fabtech lift with 35" tires. You can run a 6" if it's in your budget :) and it should be level... no reason that it wouldn't I imagine.
  3. Jun 11, 2011 at 2:54 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Avoid leveling kits all together. and you can fit 32's on stock suspension.
  4. Jun 11, 2011 at 3:07 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    before everyone starts recommending a bunch of crap...what do you plan on doing with your truck and what is your budget?
  5. Jun 11, 2011 at 4:28 PM
    berry79
    berry79 Well-Known Member
    Homestead, FL
    08 DBL Cab LB
    I did 3" in the front and 2" AAL in the rear and my truck sits perfectly level.
  6. Jun 11, 2011 at 4:56 PM
    blkbelt42
    blkbelt42 Well-Known Member
    2016 AT Black DCSB 4x4 TRD Sport Loaded!
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Start TRD Pro Grille ECT always-on mod by MESO OV-Tuned ROAV Dash Cam
    does any lift to the tacoma require dealing with the carrier bearing? thought I read
    that here.
  7. Jun 11, 2011 at 6:09 PM
    black_magic2010
    black_magic2010 Well-Known Member
    South Texas
    10 Tacoma TRD Sport DBL Cab
    I did the ready lift on mind. It's a 3 inch up front with blocks in the back. No problems with vibrations or the other crap everyone always complains about these kits. Sits level and not even the infamous tacoma lean. I guess if done right you shouldn't have any problems. My taco is a double cab short bed. And the kit didn't come.with anything for the differential.
  8. Jun 12, 2011 at 11:11 AM
    USMCBEANZ
    Barstow, CA
    Stock (for now)
    I spoke with a rep a toytech an they suggested going with Bilstein 5100's all the way around with Eibach springs in the front and a AAL in the rear. The whole kit was about $700-$800 dollars depending on which AAL I used. I have seen a example of this kit on a 2010 and it is exactly what I'm looking for. I would also use front spacers in order to ensure it's level
    I also spoke with Fabtech and talked to them about their 6" lift. Seems like either is a good option if I decide to go higher. Thanks guys!
  9. Jun 12, 2011 at 11:13 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    My thought is, why put a cheap ass lift on a brand new truck? Why not spend a little more and get a quality lift and do it right the first time...?
  10. Jun 12, 2011 at 11:16 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    If you are going with the eibachs and the 5100s then there is no reason the get spacers... The springs will give you 1.6" of lift and the 5100s can give you either .85" or 1.75"... that with an aal for the rear and you will be good to go.
  11. Jun 12, 2011 at 11:32 AM
    SPORT
    SPORT Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    Guess we ought to ask if you're wanting a Mall Crawler or a fully functional overland vehicle.
    If a Mall Crawler, then suspension spacers ought to be fine; just don't get all crazy like. I know quite a few who have had no problems, but there are also those on TW who have.
    However, if your not going for show and want performance, it seems Bilsteins or OME's are the way to go. There are quite of few here that are more than willing to assist if you choose to go that direction.
    For now, I went with a 3" spacer and an AAL level kit, until my existing parts wear out in 30-40k miles. At which point, I'll sell the spacers and go for a true suspension lift.
    Hope this helps
  12. Jun 12, 2011 at 12:44 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Spacers won't wear out, all they are is a solid piece of metal, it will be your ball joints and shocks that go.
  13. Jun 12, 2011 at 12:59 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Guys, when he says level, he MAY mean left to right, and be talking about a packing spacer for "taco lean"
  14. Jun 12, 2011 at 3:25 PM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    If you don't do crazy I say get 5100s all around and use stock springs for now . It will get you 2.5" for the front
    get 1.5" AAL if you have Toyota TSB or 2" AAL if you don't have TSB . Ur truck will sit level and total cost around $ 400 bucks (parts and labor). Then get bigger wheels and tires ( if you have more $$)
  15. Jun 13, 2011 at 4:52 AM
    blkbelt42
    no carrier bearing issues or vibrations that so many complain about??
  16. Jun 18, 2011 at 11:16 PM
    USMCBEANZ
    Barstow, CA
    Stock (for now)
    Well from the research I've done it looks like the 5100's with a stronger spring and a AAL is a pretty solid option. I don't want to go ridiculous with it and go 6". I do take my truck off road quite a bit considering I work in the Mojave desert. As long as I can fit 17" rims with at least 32" tires and have a little more aggressive stance I'm happy with a 3" lift. The truck has bilstein's stock and is already a lot taller than stock taco's so I think I'll be fine.
  17. Jun 18, 2011 at 11:41 PM
    blkbelt42
    anyone know if JUST adding the 5100's to get a small lift in the front
    requires any addition parts/adjustments?
  18. Jun 19, 2011 at 5:59 AM
    xwillx93
    xwillx93 Well-Known Member
    Will
    Stuart, FL
    09 Tacoma
    MBRP "Cool Duals" dual side swept exhaust, Volant Intake, Blacked Out Tail lights, Touchscreen Kenwood DDx616 with a 10" Kicker CVR in a custom Box, 2 Kicker Comp 6" Speakers, Removed front and rear mud flaps, Weathertech Floormats, Kobalt Slim Toolbox, Chevrolet Air compressor
    no sir. if you set them at 2.5" some people are saying replace uca's..some dont. im going to purchase all 4 bilsteins with 2.5" in the front, run 270/75r17's, then look into the toytec 3" lift with 2" AAL :D but no,running just the bilstein's is perfectly fine
  19. Jun 19, 2011 at 6:00 AM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Whoever is giving you your info is seriously misleading you. You can go higher with VSC.
