2011 V6 AT Only?!?!
Discussion in 'Toyota Trucks & SUVs' started by MemphisSlim, Mar 25, 2011.
  1. Mar 25, 2011 at 11:37 AM
    MemphisSlim
    MemphisSlim [OP] Member
    2004 Tacoma 4x4
    My apologies if I've landed in the wrong forum ... newby and all that.
    Anyway, to date I've had/have an '81, '92, and '04 Toy PUs, the latter 2 are 4x4s and all have been manual trannies. I'm considering getting a new Taco but am concerned as there seems to be no way to get a 4x4 V6 with a standard tranny! Amazing ...
    Are the ATs with electronic transfer case controllers worth it? Thoughts, comments???
    Thanks...
  2. Mar 25, 2011 at 11:42 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Doesn't di2nd gens have 6spd standard transmissions I've test drove one and I liked it but a lot of people said that it doesn't drive like a normal 5spd so id say go check your local dealer they should have one and try it out and if you like it great but the new AT they have now is very efficient and is very smooth and worth looking into but me personally id still get the standard
  3. Mar 25, 2011 at 11:45 AM
    Sport11
    Sport11 Well-Known Member
    Kingsport, TN
    Dodge Ram 1500
    I have a 2011 4x4 DoubleCab Sport with a 6-speed manual transmission :thumbsup:
  4. Mar 25, 2011 at 11:57 AM
    ser240z
    ser240z Well-Known Member
    Scott
    Monterey Park, CA
    09 Dbl Cab 4X4 6spd
    When I bought my 2009 it depended on configuration. I couldn't get a long bed TRD O/R DoubleCab with a manual, so I got the short bed.
  5. Mar 25, 2011 at 12:05 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    You can't get a long bed with a manual... 4x4 v6 in reg cab & dc short bed are avail.
  6. Mar 25, 2011 at 12:10 PM
    SManZ
    SManZ el tráfico más lento se queda derecha
    Haymarket, VA
    '10 Supercharged 4x4 Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    smh.
  7. Mar 25, 2011 at 12:13 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You can't get a DCLB Offroad period .
  8. Mar 25, 2011 at 12:20 PM
    MemphisSlim
    2004 Tacoma 4x4
    Thanks all ... I guess I should have been more specific as it's my impression that the access cab with the V6 only is available in the AT? I 've come to like the space that comes with this cab but also don't want to go to the double cab as the bed's too short... so, the 4x4 with access cab and V6 only comes with AT, right? And, if so, I wonder what they were thinking?!?
  9. Mar 25, 2011 at 12:27 PM
    MemphisSlim
    2004 Tacoma 4x4
    Hmm .. maybe it's a Memphis problem as when I go to the toyota.com site and select the build a tacoma option it won't allow the V6 + Access + Manual ... if it's available as Whippersnapper02 says above, perhpas it's not in my zip? That doesn't really make sense but they as for your zip code before the build options are allowed.
  10. Mar 25, 2011 at 12:34 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Nice that you can get the OFF ROAD TRD in a manual, for those who want it!
  11. Mar 25, 2011 at 12:34 PM
    MemphisSlim
    2004 Tacoma 4x4
  12. Mar 25, 2011 at 12:35 PM
    MemphisSlim
    2004 Tacoma 4x4
  13. Mar 25, 2011 at 12:40 PM
    MemphisSlim
    2004 Tacoma 4x4
    Thanks again ... very strange...
  14. Mar 25, 2011 at 12:43 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    09 TRD-Off Road PreRunner
    TRD cat-back with Spintech prostreet muffler, AFE Pro dry S intake, 16" SCS F-5, 3.5 BS, 305/70 GT Radial MT, King extended travel front/rear, 2" add-a-leaf, Maxtrack Spindles, Sway bar delete, DSM UCA, All Pro IFS skid, Cab mount chop, bed cab locks, Black badges, cali raised amber LED fogs, 6K FX-R Morimoto projectors with 55watt ballast, fog mod, cheap rear dust lamp from autozone, Hellas 500 behind grill, Color match Satoshi Grill, Hood scoop, rear bumper by BTF, color matched Glassworks bed caps, Wet Okole seat covers
    V6 6spd 4x4 is available. Tell your dealer to locate one for you.
    Some argue the manual is heavy and not all that great, and that the gearing is spaced far apart.
    The plus side is the 6spd is a little faster, but gets worse MPG as the 6th gear is higher then the 5th gear in the AT. So far my manual hasn't failed me yet, and I bought it because it's 1000x more fun to drive.... in my opinion, but to each is own.
  15. Mar 25, 2011 at 6:42 PM
    Sharpie
    Sharpie Ready to travel
    South TX
    2011 V6 TRD Sport 4x4 M/T Pyrite
    Depends where you go, but I've heard this before. My V6 4x4 Access Cab TRD Sport's a 6-speed manual though. In fact, all the 4x4s at the dealership I went to were manual if they were better than the base model. Maybe it's a regional thing? I don't know if I could have got an AT unless I special ordered it. My preference was for manual, so no problems.
  16. Mar 25, 2011 at 6:49 PM
    Sixfeathers
    Sixfeathers Well-Known Member
    Kreg
    Maryland
    2011 Access Cab
    Led lights: Replaced Bulbs in front,Fog Light modification, Westin Nerf Bars, TS mod,
    I drove both the manual and the Auto. The 6 speed was with the AT was very peppy on leave a little slugish between 35 and 45,. The manual was not even fun to drive, and I love MT. I decided to buy the AT. The other poster mentioned there is a slight difference withing mileage.
  17. Mar 26, 2011 at 1:25 PM
    BenJammn5
    BenJammn5 RN
    San Jose
    I agree that they are very close.
    Although not entirely proven or measured w/ the exact same truck, LSD/locker, I would say by the seat of my pants (and I drove both before purchasing) that the 6spd definitely 'felt' faster. I also dragged an auto and beat it, but that is all subjective, how many miles on the truck, mods etc.
    Either way, the manual is more fun and when it comes down to driving, and actually enjoying the drive, the manual is superior. But the other side could argue, and I understand that.
