2011 v6, sounds like an exhaust leak under acceleration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by builthatch, Nov 26, 2010.
  1. Nov 26, 2010 at 8:07 PM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
    i'm assuming this is normal, since i've found others that have asked about this elsewhere, but i just wanted to run it by you guys here to see if anyone else has this sound goin' on.
    the truck is brand new, literally, and when i took off from the lot, i was like wow, it sounds like a little exhaust leak on the passenger side under acceleration. but then i noticed at idle, when standing outside, both sides of the engine are pretty tappy at the manifolds so it probably has to do with the stamping of the manifolds, thin wall or something.
    it's a truck, so i don't expect it to necessary sound like a sedan, but it did surprise me a bit. i'm pretty anal and it doesn't really bother me for some reason :shrugs:
    any input is appreciated though ; )
  2. Nov 26, 2010 at 8:13 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Bring it back and have them look at it?
  3. Nov 26, 2010 at 8:27 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    i probably will, we'll see. like i said i researched it a bit before posting this and it seems it is pretty common with no real problem or resolution to said mystery sound. if i didn't find anything else about this i probably would be more alarmed.
  4. Nov 27, 2010 at 12:22 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    yea. the aluminum engine can transmit a lot of noise. It does kind of seem exhaustleakesque when accelerating near a wall. But its just reflected noise.
  5. Nov 27, 2010 at 3:02 AM
    2TRunner
    2TRunner Well-Known Member
    Ohio
    I wondered about that as well. I run with the I4 and wondered if something was wrong with the exhaust when I got it. Quit worrying about it about a day afterwards and have really enjoyed the sound since then.
    Pulled another 08 Tacoma into the garage this week, I4/Access Cab and it had the same sound.
    I was at the gas station yesterday, heard a vehicle start up, turned around to find the Taco I knew was pulling away from the pump.
  6. Nov 27, 2010 at 3:09 AM
    KalamaKid
    KalamaKid Well-Known Member
    Socialist Republic of Oregon
    same shit as everyone else
    See if you can get a new gasket installed? maybe the tech who installed it didn't torque your sh*t properly when they installed the exhaust?
  7. Nov 27, 2010 at 4:13 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I'm surprised you guys don't hear something like that during your test drive. I know I would never accept a vehicle with that dramatic an engine noise. None of the other Toyota vehicles have this right? Why does the Tacoma have to be the lucky one? My stepsons '10 Highlander is so frikkin quiet you would think it was electric. I would at least demand an answer-hell at least a theory from the boobs at the dealer as to what exactly it is!
  8. Nov 27, 2010 at 9:44 AM
    frano
    frano Member
    Western MA, USA
    2011 Tacoma Double Cab
    My 2011 V6 has what I thought was an exhaust manifold leak under acceleration on the right side. The truck now has 1,000 miles on it and the noise seems to be getting less as the miles rack up. I thought I'd talk to the dealer to get their opinion.
  9. Nov 27, 2010 at 9:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Toyota spends a little more money in the NVH department on their cars and crossover vehicles, than they do on the trucks.
  10. Nov 27, 2010 at 9:57 AM
    island808
    Jedediah
    hawaii
    all my toyotas have been fairly clackety on the engine noise. I've never thought of owning a "luxury car" so I can't say as I know if they are capable of making a quiet car.. BUt I have owned toyotas from 72-2010 and all are kind of clackey.
  11. Nov 27, 2010 at 10:46 AM
    joes06tacoma
    Joe
    Central Coast, CA
    Mine does it too. There's a TSB on it, not sure if your 2011 will have the updated parts (exhaust manifolds?) automatically or not. To me it just sounds like a noisy import engine without self adjusting lifters. Just the nature of the beast.
  12. Nov 27, 2010 at 11:33 AM
    Ridgerunner
    Frank
    San Francisco
    Then why does my 2001 not have this problem? Seems to me this is a 2nd gen flaw that IMO is bullcrap to accept for the money you pay for these trucks. Seems to me that you guys are cutting Toyota a TON of slack. I have even heard this noise coming out of 1st-gen V8 Tundras around here too. It sounds like sh*t to my ears because it wrecks the beautiful V8 sound. Anyways I guess if it dont bother you and it doesnt hurt anything then whatever. It bugs me because I may want another Tacoma one day and this would stop me.
  13. Nov 27, 2010 at 1:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Cast iron block vs. all aluminum block. Yours still ticks, but its not as noticable as on the 1GR engine.
  14. Nov 27, 2010 at 1:32 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Tacoma tick, normal.
  15. Nov 27, 2010 at 6:04 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    haha, "tacoma tick", i like that!
  16. Nov 27, 2010 at 8:44 PM
    Ridgerunner
    Frank
    San Francisco
    Mine doesn't. No tackytacotick here whatsoever.
  17. May 3, 2011 at 10:32 AM
    Michaeltb9509
    Michaeltb9509 New Member
    Rhode Island
    TRD - Off Road
    Just picked up a 2011 Tacoma Access Cab - TRD Off Road. Been back to the dealer already to complaing of the ticking noise while idling. So just searching and googling and now a member of this site, I guess the"Toyota Tick" is normal? My2004 never had sounded like a Timex Watch!!
  18. May 3, 2011 at 10:38 AM
    Woodsy211
    Woodsy211 Well-Known Member
    480 miles and mine does the same thing. the 4.0 engines are noisey mofo`s
  19. May 3, 2011 at 11:07 AM
    leveltwo
    leveltwo Well-Known Member
    put a flowmaster muffler on and you wont hear the engine as much...
  20. May 4, 2011 at 5:42 AM
    Michaeltb9509
    Rhode Island
    TRD - Off Road
    Thanks - All for the comments! Didn't think a new truck with less than 500 miles would sound like a ticking time bomb!
