2011 won't start. Battery? Electrical
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xOZx, Feb 19, 2012.
  1. Feb 19, 2012 at 1:36 PM
    xOZx
    xOZx [OP] Well-Known Member
    IL
    2011 Tacoma Double Cab SR5 4X4
    885x Coils, Bilstein 5100s, Deaver add a leafs
    I went out to try and start my truck today and it turned over once the clicked like a low battery. Put on the charger and it will not turn over. had on 2 amp all day and still not.
    Put the starter on "Jump" (high amps) and it still won't
    One thing odd, when i turn on the dome or radio or anything, it flashes on off constant.
    Thoughts?
  2. Feb 19, 2012 at 1:40 PM
    myname150
    myname150 Well-Known Member
    The flashing...hmm, maybe your battery cables could have gotten loose?
  3. Feb 19, 2012 at 1:41 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Thats what i thought, but usually the engine wont even crank at all when its an aftermarket alarm.
  4. Feb 19, 2012 at 1:42 PM
    xOZx
    IL
    I pulled the cables and cleaned (no corosion at all). I have no aftermarket electical gear at all.
    It's so wierd this flashing. Even the dome...like it's intentional. It is consant, not intermittant or anything.
  5. Feb 19, 2012 at 4:21 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Call the dealer tell them to come fetch it should be under warranty.
  6. Feb 19, 2012 at 4:22 PM
    myname150
    If you can, try swapping in a new battery and see if that fixes it.
  7. Feb 19, 2012 at 4:29 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    07 4dr 4x4 V6
    Fog Light Mod
    iirc flashing interior lights mean engine is toast.
  8. Feb 19, 2012 at 4:36 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    I would have the dealer come get it, since charging/ jumping battery is not working. Odd that the dome light is flashing......
  9. Feb 19, 2012 at 4:38 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    +1, You should be covered under the Toyota Care and Road side Assistance. Why F with it when you can have the dealer figure it out.
