2012-2013 AFE CAI NOW AVAILABLE!
Discussion in 'Performance and Tuning' started by sdoheny, May 13, 2013.
  1. Jul 10, 2013 at 5:14 PM
    #121
    NiceTaco
    NiceTaco Canadian Redneck
    Ontario, Canada
    2012 TRD Sport
    Aero Turbine 2525, Front bilstein 5100's @1.75, rear 5100's, 1" Toytec rear block, Devil Horns, BGF AT's, 18" Moto Metal 962's
    are you guys using the rubber cover for the extra inlet or letting the air flow in from there also? I am running it without at this point.
  2. Jul 10, 2013 at 5:34 PM
    #122
    tacodane
    tacodane The Slow But Getting Somewhere Build Vendor
    Dane
    2013 Tacoma Prerunner SR5
    Led Interior Lights AFE CAI Stage II, Aero Turbine 2525 Muffler Snugtop Cab-Hi shell TRS Retrofitted Headlights
    I installed mine. i don't know if it makes a difference
  3. Jul 11, 2013 at 5:24 AM
    #123
    sdoheny
    sdoheny [OP] Well-Known Member
    Seth
    Tampa, FL
    Sport
    N-Fab Text black 3 main tube, led interior lighting, sylvania ultra head lamps, led map/dome/license plate, rail mounted bed lights, trd skid plate, Aero Turbin muffler swap, MRBP Black Exhaust Tip, weather tech, fuel trophy, duratrac 265 70 17, plasti dip badges, Icon stage 4 suspension, TRD shift knob, AFE CAI, Raptor Light MOD.
    I spoke to an AFE engineer about this and he wrote me the following....
    "The auxiliary air inlet is to allow extra air flow for those folks use their truck for towing or in high altitude areas where the air is thinner. It allows extra air flow to the engine. The only time that you may see any hot air from the engine compartment is when you are at an idle, waiting for the traffic light to turn, train crossing, etc. At that point you are not under any throttle pressure so it really doesn't matter what the air temp is. As the vehicle starts moving forward, the cooler outside air is pushed into the filter area and forces whatever air that is in there into the engine and is replaced by the cooler outside air."
  4. Jul 11, 2013 at 10:49 AM
    #124
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I think gadget got 5hp with the plug off..... Or he was told its good for 5hp from an afe rep.
    Something about the air swirling around the entire filter element iirc.... I don't care tbh, just throw in it out there in case u wanted to search for it.
  5. Jul 11, 2013 at 11:06 AM
    #125
    STiLL WILL
    STiLL WILL MY NAME ISN'T WILL
    Matt [again, not WILL]
    CA
    2013 Tacoma T|X Pro TRD Supercharged 4wd 6MT
    All kinds of badass shit. Click on the link in my signature to see.
    Got this installed on my '13 a few weekends ago. I opted for the Pro Dry S filter. Definitely woke up the TRD s/c I have on it. Loved the sealed design, and the fitment was spot on.
    My only complaint would be the flimsy emissions pump relocation bracket....I can see it getting weaker over time and letting the bottom of the pump strike the top of the solenoids on the passenger side header rail.
  6. Jul 20, 2013 at 9:23 AM
    #126
    NBBAZ
    NBBAZ Well-Known Member
    Arizona
    2000 Toyota 4runner Sport 4x4
    Anyone running this AFe CIA with a snorkel, like Safari or Airflow? Is it possible?
  7. Jul 20, 2013 at 6:09 PM
    #127
    Lord Helmet
    Lord Helmet Well-Known Member
    Nick
    SoCal
    Not with a snorkel but a ram air scoop by volant super easy to do :thumbsup:
  8. Jul 30, 2013 at 5:10 AM
    #128
    sdoheny
    Seth
    Tampa, FL
    Sport
    anyone notice if the intake is louder without the plug? I read on some FJ forums that it should be.
  9. Jul 30, 2013 at 7:47 AM
    #129
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
