2012-2015 Tacoma DRL with Integrated Push Switch Harness
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CleanYota, Apr 10, 2020.
  1. Jul 13, 2021 at 10:16 PM
    #81
    2015ToyotaTacoma4x4
    2015ToyotaTacoma4x4 Active Member
    2015 Toyota Tacoma TRD OFF-ROAD
    no i removed the junction block and just put it back the way it was, but even with the block it didn't make a difference
  2. Jul 13, 2021 at 10:19 PM
    #82
    2015ToyotaTacoma4x4
    ok so cut the green on the turn and tape it. and for the corner just cut and tape.
    perfect :) i don't know how to thank you, really thank you very much
  3. Jul 13, 2021 at 10:20 PM
    #83
    caribe makaira
    Caribbean, Puerto Rico
    For the corner, no need to cut. Remove the connector, tape the exposed ends (connector side and side marker side)
  4. Jul 13, 2021 at 10:22 PM
    #84
    2015ToyotaTacoma4x4
    oh yes i will do that even better, didn't thought of that makes sense
  5. Jul 13, 2021 at 10:23 PM
    #85
    caribe makaira
    For the DRL feature, cut white wire on position 19 of C11 (and tape ends). That's the connector under the steering wheel going to the light switch.
  6. Jul 13, 2021 at 10:25 PM
    #86
    2015ToyotaTacoma4x4
    so i can just cut this under the dashboard to disable the the DRLs ambers?
  7. Jul 13, 2021 at 10:26 PM
    #87
    caribe makaira
    It's the remaining wire to activate the feature.
    Mine does not have the wire.
  8. Jul 13, 2021 at 10:28 PM
    #88
    2015ToyotaTacoma4x4
    ah so i just cut them there to disable the amber light in front?
  9. Jul 13, 2021 at 10:29 PM
    #89
    caribe makaira
    Them...no. Just the white wire on position 19. DRL select.
  10. Jul 13, 2021 at 10:35 PM
    #90
    2015ToyotaTacoma4x4
    okay just the white one here on C11
    ok so now since i have the best expert on the internet i have one last question :)) you know you give someone a small finger and they take the whole arm :p (joke) but i have one more big question.
    in germany i need to install a red rear fog light 21W light its like a brake light, with a dashboard switch. my question is, where would i be able to get power for the light/switch only when the ignition is on?
  11. Jul 13, 2021 at 10:40 PM
    #91
    caribe makaira
    Does the Tacoma have a 7 pin towing connector?
    When is it required to be ON?
  12. Jul 13, 2021 at 10:46 PM
    #92
    2015ToyotaTacoma4x4
    its only on when its foggy and i need to have a foglight switch that has an indicator light. in germany you can only use front fog lights when its very foggy or its a ticket and the rear needs one for the safety
  13. Jul 13, 2021 at 10:47 PM
    #93
    2015ToyotaTacoma4x4
    hm i don't know but ill check never really use the tow hitch. ill make a picture
  14. Jul 13, 2021 at 10:52 PM
    #94
    caribe makaira
    You could use the fuse that powers the Back up lamps (reverse) with an add-a-fuse. Then snake the wire to the switch, then under the carpet out the bottom of the driver's seat plug to the frame, to the rear location.
    2015ToyotaTacoma4x4 likes this.
  15. Jul 13, 2021 at 10:52 PM
    #95
    2015ToyotaTacoma4x4
  16. Jul 13, 2021 at 10:56 PM
    #96
    caribe makaira
  17. Jul 13, 2021 at 10:57 PM
    #97
    2015ToyotaTacoma4x4
    ok perfect, i ordered all the items already on eBay just waiting for everything to come in and i was just trying to figure out whats the best way to get power with only the ignition on.
    i really appreciate the huge help and the time you spend explaining all the details to a NOOB heheh
    #97
    Dekoy909 likes this.
  18. Jul 13, 2021 at 11:05 PM
    #98
    caribe makaira
    Let us know if they allow you to drive in the Autobahn.:burp:
  19. Jul 13, 2021 at 11:15 PM
    #99
    2015ToyotaTacoma4x4
    hahah :) I am german and still have my german drivers license :D the tacoma will be a bit slow on the Autobahn but i love my truck and got used to driving slowly now for many years. I used to drive 255km/h in my moms OPEL OMEGA when the trees on the side become a wall and the broken white lines in the middle a solid line. in 2010 i visited my mom and took her golf VR6 and drove around germany and many times i missed my exit its just way too fast heh.
    but i will post some pictures here when i am doing the TUV at the german TUV station and let you know if the work paid off :)
    But really many many thanks Caribe Makaira and who knows i may run into more problems (smile) and you see a message again:) nice meeting you
  20. Jul 13, 2021 at 11:27 PM
    #100
    caribe makaira
    No problem.
