2012 - 2015 Tacoma Faux Pro Grille
Discussion in 'Automotive Group Buys' started by CaliRaisedLed, Apr 27, 2018.
  1. May 16, 2018 at 2:54 PM
    #701
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp
    Hell no. I'm in the same boat.
  2. May 16, 2018 at 3:32 PM
    #702
    cdex8357
    cdex8357 Well-Known Member
    charles
    2013 tacoma
    pro comp 3' lift
    So is this to color match paint existing surround or new color match surround
  3. May 16, 2018 at 3:34 PM
    #703
    12tacop
    12tacop Well-Known Member
    2012 DCSB SR5 Barc Red 4x4
    She didn't give me a pass to spend 200 on the grille!
    JayRolla likes this.
  4. May 16, 2018 at 3:51 PM
    #704
    JayRolla
    Colorado Springs
    Dealers sell color matched surround for around $200 to replace the chrome. Cleaner look like the trd pro and sport has.
  5. May 16, 2018 at 3:52 PM
    #705
    JayRolla
    Colorado Springs
    Damn. This is wife's rig so maybe she will let me get it.
  6. May 16, 2018 at 3:53 PM
    #706
    12tacop
    Yeah just tell her you did it for the children. LOL
  7. May 16, 2018 at 4:31 PM
    #707
    stlntaco
    stlntaco Well-Known Member
    Jake
    California
    ̿̿ ̿'̿'\̵͇̿̿\з= ( ▀ ͜͞ʖ▀) =ε/̵͇̿̿/’̿’̿ ̿ ̿̿
    Just got mine. Everything looks good but the outside screws are definitely too short.
    HellaNasty likes this.
  8. May 16, 2018 at 4:45 PM
    #708
    cdex8357
    charles
    2013 tacoma
    pro comp 3' lift
    We need to start a new thread for this.
    TegoTaco, 12tacop and dome like this.
  9. May 16, 2018 at 6:04 PM
    #709
    Lefkos
    Lefkos Well-Known Member
    Winston
    Las Vegas
    PreRunner
  10. May 16, 2018 at 6:33 PM
    #710
    dome
    dome Well-Known Member
    Joel
    Bay Area
    2015 TRD OR DCSB 4x4
    Here's the unboxing and subsequent install... (for reference, the before and after photos are spaced exactly 30 minutes apart according to the EXIF data from the photos so the install was probably ~20 min, taking time to snap pictures)
    Yup, it's a box.
    First look inside
    "TOYOTA" badge section comes bagged separately, neat.
    Looks like there are some small imperfections on the paint of the letters on mine, not a huge deal -- but this might seem pretty indicative that the paint might not do well after some abuse from road debris. Whatevs it's a small area of paint and a Chinese knock-off, all things considered, expectations are met.
    (bottom of the 'O')
    (top right of 'A')
    (some scratches on the bottom of the 'T')
    You also get some screws for the TOYOTA section...
    You'll probably find like me and several others that 4 of these should be longer and as a result do not really thread in...
    Moving on...
    I wonder if there's a light bar that might fit into that mid section in lieu of the TOYOTA letters...
    Backside...
    "Assembled"...
    Screws on the back... the outer ones are the ones that should be longer. For me at least, the bottom ones wouldn't even thread at all and just popped out if I put even just a teensy amount of pressure to pull the letter logo assembly off there.
    Installation
    You'll need at least a 10mm socket driver, a flat head screwdriver, T20 torx driver, and you'll also find some needle nose pliers handy for the weather stripping.
    Remove the top 10mm bolts and outer plastic fasters.
    Nothing fancy for those fasteners, just stick a flat head in there and pop the middle up.
    Here's what it should look like, then you can just pull the whole thing out.
    Do yourself a favor and move the top part of the grille up and off of the area where the 10mm bolts fasten it for the rest of the removal.
    It's really tough to see here, but if you look just underneath the headlight assembly where the headlight and grille meet, there's a clip you need to release. You can just push these out from behind the grille towards the front of the truck. There's one on each outer bottom corner of the grille, and a few in the middle.
    Here it is off... take note of those bottom clips so you know where to push to get it off. Also note the T20 torx screws, take those out, there were like 12 of them?
    There are two types of clips/tabs you're going to deal with. These are the easier ones.
    These clips/tabs will probably be the biggest pain in your butt, but be patient and you shouldn't end up breaking any... Unless you're doing this in the cold, then you might break some brittle plastic. It was probably like 65F when I was out doing it and nothing broke, be careful.
    I started with the bottom middle and worked my way around the edge.
    Here's the trick I used on the stubborn tabs, just shove your flat head in there and gently pry the inner tab and outer tab apart. Note that only ONE side of the inner tab is actually doing anything so only bother with that side.
    Don't forget to transfer the weather stripping over too. Here's where the pliers come into play. Again, be gentle and take your time. There's also some foam tape on the stock grille, but I'm just going to put some new foam tape on the new grille later instead of trying to reuse that old stuff. It's also worth noting here that two of the holes for the weather stripping in the new grille insert were just a tad bit too small for the stripping fasteners and as a result required a LOT of pressure to shove them in. These two holes are the ones where you need to access the fasteners from the FRONT of the grille, the giant gaping plastic area where the 10mm's go.
    Here you can see the difference in the thickness of the plastic in the new faux grille... notice the gap in the "tooth" for tab and that it's not even touching the new inner plastic of the faux grille. This was not the case with the stock grille, but hey Chinese knock-off, thems the haps.
    Before
    After (yes, the new grille also caused my truck to teleport)
  11. May 16, 2018 at 6:35 PM
    #711
    pwmullen3
    pwmullen3 Active Member
    Pat
    757
    2009 Tacoma DCSB TRD Off-Road
    NEWB
    AMAZING.
  12. May 16, 2018 at 7:18 PM
    #712
    2ndGenOffRoad
    2ndGenOffRoad Active Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4
    Schmell Fab Sliders
    Looks good!
  13. May 16, 2018 at 7:29 PM
    #713
    2ndGenOffRoad
    Los Angeles, CA
    Schmell Fab Sliders
    Here's a quick before and after picture. May give you guys an idea of how much a color match surround makes a difference.
    J'sBeasTRD likes this.
  14. May 16, 2018 at 8:04 PM
    #714
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    Looks great, did you do the hood wrap yourself or buy a precut?
  15. May 16, 2018 at 8:08 PM
    #715
    J'sBeasTRD
    J'sBeasTRD Well-Known Member
    Central Coast Cali
    15TACOMATRDOR 4X4DCSB6SPD...
    Turned out great!12027E04-D74C-4AB5-BD1C-79DA8515E533.jpg FBA607C8-A250-4785-9D3B-00B7A911AB1B.jpg
    2ndGenOffRoad likes this.
  16. May 16, 2018 at 8:09 PM
    #716
    2ndGenOffRoad
    Los Angeles, CA
    Schmell Fab Sliders
    Thanks! Got it done at a local body shop. It's a "custom" wrap. AKA Expensive sticker.
  17. May 17, 2018 at 7:20 AM
    #717
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    2013 Super White Tacoma DCLB TRD SPORT
    You should paint your valence black.
  18. May 17, 2018 at 7:25 AM
    #718
    JayRolla
    Colorado Springs
    Imo that makes it look cheap. Also grille gets lost in all the black .
    You want to paint match or leave chrome.
  19. May 17, 2018 at 7:30 AM
    #719
    Boyk1182
    Boyk1182 Well-Known Member
    Clearwater, FL
    2014 Toyota Tacoma 4x4
    Definitely a subjective thing, I can't stand the chrome, anything would be better to me.
  20. May 17, 2018 at 7:36 AM
    #720
    dome
    Joel
    Bay Area
    I plan to color match the surround, but that's a later thing.
