2012 4.0l Taco bad gas mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sheltoncox, Aug 19, 2019.
  1. Aug 19, 2019 at 12:25 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Ima gonna have to search this out...
    It is almost time for the second set of plugs, oil change, tyre roto...
    eon_blue[QUOTED] likes this.
  2. Aug 19, 2019 at 12:32 PM
    Gixerkiller
    Dennis
    Taylor, TX
    Inter web says there is a filter under the drivers door on the frame, it also says that 2nd gens are in the tank...
    Gonna look at the rig itself once I get home.
    Dropping the tank ain’t so bad on these rigs...
  3. Aug 19, 2019 at 1:29 PM
    eon_blue
    Azusa, CA
    hmm the one under the driver door on the frame is how mine is but it's the 3.4l v6, unless you guys have a secondary one in that location. Or maybe it's different depending on the year/model/drivetrain etc
  4. Aug 19, 2019 at 1:34 PM
    Gixerkiller
    Dennis
    Taylor, TX
    I’m gonna look under the rig in a few, then we all will know if the 15 pre runners have an external at least...
  5. Aug 19, 2019 at 1:39 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I get 14mpg , maybe 15 city. Been getting that since day one.
  6. Aug 19, 2019 at 3:47 PM
    Gixerkiller
    Dennis
    Taylor, TX
    @eon_blue Confirmation that there is no external fuel filter under the drivers side of a 2.5 gen pre runner. Have not looked on the fuel rail to see if there might be a strainer filter in it. Someone who has taken a 4.0 apart might know. So, it is true that the chinsy fuel pump toilet paper filter is 100% there and maybe to only filter in the fuel system.
    Poor design imo. If the tank one fails, all the crap goes straight to the fuel rail and into the stupidly expensive injectors...
  7. Aug 19, 2019 at 3:47 PM
    eon_blue
    Azusa, CA
    yup that's why the URD kit is so popular even for guys that don't need the high flow fuel pump it comes with, they just want the external fuel filter that it's designed with
  8. Aug 19, 2019 at 3:50 PM
    Gixerkiller
    Dennis
    Taylor, TX
    Added to ever growing mod list....
    (Know of any 7 figure jobs for non college grads? Got truck mods to pay for!!):rofl::rofl::rofl::rofl:
  9. Aug 19, 2019 at 4:03 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I get and have always gotten about 13.7 mixed driving or so and 17 all highway, both with and without the supercharger, without and WITH armor and my OE equal sized 32 load range E tires.
    I chalked it up as normal.
    Usual range out of the tank before I trip the light on is between 208-225 miles per tank.
  10. Aug 19, 2019 at 4:09 PM
    808matt
    808matt Well-Known Member
    hawaii
    19 Ranger
    have you checked your air filter?
    eherlihy likes this.
  11. Aug 19, 2019 at 4:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    They change the gas formula everywhere, Louisiana too.
    What do you consider proper PSI? The door jamb may say 29-32 PSI, but that is for best ride in an empty truck. If you look on the tires most P rated tires say 44 PSI max pressure and that is meant for carrying heavier loads. I run 38-40 PSI all the time. The ride is a little stiffer, but it makes 2-3 mpg difference in my experience. Plus if i have to haul or tow a heavy load I'm already inflated and don't have to stop and add more air to the tires.
    Torspd likes this.
  12. Aug 19, 2019 at 8:08 PM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    formula??????
  13. Aug 20, 2019 at 7:24 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    That blows, on street all seasons I got 18 mpg last tank.
    SR-71A likes this.
  14. Aug 20, 2019 at 7:31 AM
    Littlemule1
    Littlemule1 Well-Known Member
    2015 SuperWhite Tacoma DCSB TRD Sport
    Try disconnecting battery for a while start out with fresh fuel strategies.
  15. Aug 20, 2019 at 7:50 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Maintenance, fuel pump upgrade with external filter, HP Tuner.
  16. Aug 20, 2019 at 7:57 AM
    #36
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    OPs only option [​IMG]
