2012 4L TRD synthetic oil type?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badhaircut, Dec 11, 2018.
  1. Dec 11, 2018 at 9:46 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  2. Dec 11, 2018 at 9:47 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    The 10 filters for x dollars might work for some. I hear ya. My local dealers get $5.41 for a 90915-YZZD3 as well as the paper carts 04152-YZZA5(4.0L 4Runner) & 04152-YZZA1(3.5L V6)
  3. Dec 11, 2018 at 9:48 AM
    jmanscotch
    jmanscotch Well-Known Member
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Ok...you're the one who commented on my intervals though :confused:
  4. Dec 11, 2018 at 9:48 AM
    Hunter4950
    Hunter4950 Well-Known Member
    Correct
  5. Dec 11, 2018 at 9:49 AM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    :boink:
  6. Dec 11, 2018 at 9:56 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Amsoil SS 0W30 at 10K intervals and 5K Toyota filter changes here.
  7. Dec 11, 2018 at 9:59 AM
    Lester Lugnut
    Yep - another oil thread OCI battle. It's your truck and your money. Change every Saturday if you want.
    blu92in99 and BassAckwards like this.
  8. Dec 11, 2018 at 10:07 AM
    ARB1977
    North Texas
    Amsoil SS 0W30 10K intervals with 5K Toyota filter changes.
  9. Dec 11, 2018 at 10:36 AM
    Hunter4950
    12,500k Oci based on oil analysis
  10. Dec 11, 2018 at 11:14 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Look up what even a 5w30 is when "cold" that is under 180*f..... its still WAY too thick to properly lube a motor, this is why i run 0w-30 even in hot summer months here in socal. even at 115*f ambient its still thicker than 30w at operating temps but MUCH thinner than a 5w... its a no brainer to run 0w-30 wherever an Xw-30 is required.
    At operating temp the motor is relatively stable as far as oil temps so all of them are going to behave right around a 30w oil. But under that 0w-30 will be thinner and better to lube a motor with.
    BassAckwards likes this.
  11. Dec 11, 2018 at 11:36 AM
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I regret coming in here.
    Do what you want with your truck brother, my point wasn't to debate well known scientific properties of oil. Things like "oil that's too thin for its operating environment won't lubricate effectively", as an example.
    My responses were to the OP and thus just my thoughts on his questions since he didn't seem to know these properties well. If you wanna run 0W30 in hot southern California, for reasons that make sense to you, go for it :thumbsup:
  12. Dec 11, 2018 at 11:37 AM
    96carboard
    96carboard Well-Known Member
    So if you ignore everyone who is speaking from their asses, Toyota says that 0w20 is fine;
    Now it actually says 2010 onwards, but there were no noteworthy changes from 2005-2009, so basically, ANY 1GR engine will be fine with the 0w20.
    So its your call.
    But I would suggest that whatever you pick, make it a 0w, because that's the "cold pump" value, and the lower the better, especially when its colder out.
    Lester Lugnut likes this.
  13. Dec 11, 2018 at 11:41 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Then why does Toyota recommend it?
    Hunter4950 likes this.
  14. Dec 11, 2018 at 11:50 AM
    Hunter4950
    Hmmm
    jmanscotch likes this.
  15. Dec 11, 2018 at 11:55 AM
    #35
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    Maybe because "thickness" isn't the only variable in the equation. Oil needs to be thin enough to flow, thick enough to stick around and lubricate, along with all the other specific things that are weighted out when deciding a oil spec for an engine they design.
    :santa:
  16. Dec 11, 2018 at 11:59 AM
    #36
    TacomaMike37
    13' DCLB MGM
    Toyota engineers dont know shit if you ask me!
  17. Dec 11, 2018 at 12:17 PM
    #37
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I mean...they have done a great job designing our frames, front diff bearings, drive shafts, leaf springs, u-joints, the composite beds and 7-pin trailer harnesses. Faced with all those accolades, I'm not sure why you'd doubt them.
    jv_74 likes this.
  18. Dec 11, 2018 at 12:21 PM
    #38
    Hunter4950
    Exactly! They want the engine to blow the hell up!
    jmanscotch[QUOTED] likes this.
  19. Dec 11, 2018 at 12:26 PM
    #39
    jmanscotch
    Jake
    Colorado Springs
    2021 TRD OR DCLB
    I mean...mine does have a consistent tick to it, I'm hoping it only does it for another 300,000 miles though.
    jv_74 and Hunter4950[QUOTED] like this.
  20. Dec 11, 2018 at 12:28 PM
    #40
    Hunter4950
    Mine has 178k miles on it and doesn't burn a drop of that thick ass 5w-30 oil
