2012 AC - Troubleshooting Steps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oyster Taco, Sep 10, 2020.
  1. Sep 11, 2020 at 10:36 AM
    Oyster Taco
    Oyster Taco [OP] Well-Known Member
    Grant
    Western Washington
    2012 Tacoma DCLB
    Kings, TC UCA, Dakar HD, OME sports, drawers, canopy, awning, racks galore.
    I did a bit this morning. Both feel about the same, though it would make more sense for me to have the passenger side be colder, as that's where the air comes into the cabin.
  2. Sep 11, 2020 at 10:39 AM
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    So I've heard this before, that all AC systems lose charge, but I've also understood that there's no reason for it to do so without a leak, it's a closed system. So should I assume I have a leak? or should I have it topped off and see how it goes?
  3. Sep 11, 2020 at 6:23 PM
    Bishop84
    Bishop84 Well-Known Member
    How do you find a leak on an empty system? Unless it had dye or a major leak you won't find it. It's preference. I always make sure a system is 100% charged before I diag it. Including leaks.
    12TRDTacoma likes this.
  4. Sep 15, 2020 at 9:59 AM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    @harpharperharp
    Any luck with your AC diagnosis?
    No luck here but haven't done much. I waiting on friend that runs a shop to get back in town
  5. Sep 15, 2020 at 11:26 AM
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    I haven’t done anything yet. Going to check pressures, compressor, and barring the compressor just not turning on or clutch wheel being weird, going to get it refilled and see how it lasts. Figure then maybe in a couple weeks I could compare pressure notes, and figure out if it’s a leak, or my compressor is going.
    At least that’s my plan for now.
  6. Sep 15, 2020 at 12:05 PM
    DiscoYaker
    SE USA and Alaska
    Gotcha, well ill do the same and let you know what I come up with
  7. Sep 16, 2020 at 12:24 PM
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    So looking like my condenser is the issue. I was checking the pressures (60 low, 60 high) and I see a leak on my condenser. Low is supposed to be between 25-40 and high is supposed to be 225-250.
    I think it's weird that the lower is now higher....any thoughts on this? It doesn't seem too hard to change out the condenser, but a bit overwhelmed with getting a shop to pull the old charge.
  8. Sep 16, 2020 at 12:26 PM
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    Whoops, checked the pressures with the car off. Gotta do it again.
  9. Sep 16, 2020 at 12:53 PM
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    Could anyone tell me how much oil I'd need to add to my condenser when installing? Got a trip next week and gotta get to this!
  10. Sep 16, 2020 at 1:08 PM
    Checkers10160
    Checkers10160 Well-Known Member
    Chess
    Westchester/Fairfield
    '16 Access Cab Long Bed - 4cyl - 5MT
    Stock
    Just so OP is aware, if the refrigerant is empty (Or almost empty) it will not come on at all, even with the AC button pressed. I think it does this to protect the compressor. You will need to jumper it with a wire or paperclip
  11. Sep 16, 2020 at 1:11 PM
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    Hey, my compressor and AC does come on. Low side sits at 0 when the AC is on full blast, high side is at 73 ish. still some stuff in there.
  12. Sep 16, 2020 at 1:14 PM
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    It is for sure my condenser. Feeling pretty confident the more I look into it. Only worried about oil amounts and getting the right orings. Hoping to find a condenser local so I can get to it asap.
  13. Sep 16, 2020 at 1:19 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    1.4 oz. for the condenser. I used the GPD kit. One 0 ring and one seal washer is all you need.
  14. Sep 16, 2020 at 1:22 PM
    spitdog
    You should also add a little dye in the system. It makes it easy if there’s a next time.
    Oyster Taco[OP] likes this.
  15. Sep 16, 2020 at 1:23 PM
    #35
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    Is there a way to add some dye to the oil? Then go get it long vacuumed and recharged? Trying to avoid the dye injector kit for $200
  16. Sep 16, 2020 at 1:25 PM
    #36
    spitdog
    Yes, I added the dye and pag oil at the same time with a big syringe right in the condenser
  17. Sep 16, 2020 at 1:26 PM
    #37
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Pressurize refrigerant circuit to ~200 psi with nitrogen (or shop air in a pinch). Spray everything with soapy water. Look for bubbles.
  18. Sep 16, 2020 at 1:31 PM
    #38
    Oyster Taco
    Grant
    Western Washington
    2012 Tacoma DCLB
    Anyone have any suggestions on an autoparts store brand condenser to buy? I'm seeing some reports the top mounts can be different. I'd love to do the denso from rock auto, but leave for a trip to Utah Wednesday or Thursday next week and need to get moving. Just wanting one that fits first try.
  19. Sep 16, 2020 at 1:34 PM
    #39
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is all excellent advice for anyone needing to diagnose their AC system. :thumbsup:
    I've always felt that this amount of refrigerant was too low for the truck. I'm starting to wonder if overcharging the system wouldn't be such a bad thing on these trucks.
    Agreed though. Delphi is a garbage brand and Toyota screwed up something royal for using their junk on these trucks.
    This is another piece of awesome advice for anyone needing to diag their system.
    po35042[QUOTED] likes this.
  20. Sep 16, 2020 at 1:35 PM
    #40
    spitdog
    I wanted a Denso but they didn’t list one for a 15. So I was going to get a spectrum, but they were out of stock. Ended up with one from a radiator place in Miami. Got it on eBay for $75 plus free shipping.
    Perfect fit, but I needed to pull the rubber bushings from old condenser and stick in new. You will probably have to do that also.
    #40
